Question about Samsung 793S 17" CRT Monitor
How i get part no of flyback - Samsung 793S 17" CRT Monitor
    Novelist:
  • 242 Answers
Look in MDM electronics for cross reference.
Posted on May 29, 2014
I have an RCA 52 inch Model d52w19. It makes a sparking sound when turning on and I can see electricity flowing from what I think is a flyback soldier.
thats a common problem where the flyback will need to be replaced. The RCA repair kit called the 259296 flyback is the correct flyback for your model from www.tvrepairworld.com the flyback comes with installation instructions.
Sep 25, 2011 | RCA Televison & Video
I'm trying to fix my 21 inch JVC TV, its on standby mode i detected the problem it was Horizontal output transistor, when i replace it with new one it work but after 24 days it got shorted again so i...
depending on circuit design in some TVs when flyback becomes defective then (1) only flyback gets deffective or (2) flyback & 1 transistor big in size fixed near flyback gets deffective or (3) flyback,big transistor & resistor or diodes or some times ICs will get deffective ..........so flyback replacement is compulsory + which ever components gets deffective ....... usually flyback gets deffective after 4yrs (between 4yrs to 12 yrs depending on TV brand & usuage ) .............so in your case along with horizontal transistor replace flyback also ..................... Remove that flyback from main board ? using marker make a mark (1 dot on knob & at the same line put another dot on flyback --- these 2 dots should be in same line ) on all the knobs on fly back ....now turn all the knobs one by one in anticlockwise direction slowly until it stops .... Then observe from the mark which you made before turning .. --- you will get an idea which knob howmuch it was turned in anticlockwise direction.... now take flyback to electronic shop & buy same type ( equivalent will not work )......at the shop itself check part number , number of pins & their position of old flyback with that of new flyback ----- everything should match 100% - nothing less nothing more .... it should be exact .... check many shops...now turn all the knobs of new flyback in anticlockwise direction very very very slowly until it stops....now fix it to mainboard very slowly & carefully....don't forget to connect red wire from flyback to TV TUBE ...again iam repeating don't forget to connect red wire from flyback to TV TUBE .... Now observe mainboard carefully whether any connector is not connected ....now connect only tv powercord & stay at a distance & switch on Tv for 2 seconds & then switch of immediately....during this 2 seconds TV gets on & led also gets on continuosly (won't blink) & there should not be any smoke or sounds on main board ...this confirms you have replaced flyback without disturbing other components & not shorted any joints..... so now again switch on tv ..wait 3 or 4 seconds ...led will be on but there won't be any picture ... Don't worry ....in the beginning you have observed howmuch knobs on your old flyback were turned in anticlockwise direction....remember..? see your old flyback again.... Now using suitable screew driver turn all the knobs on new flyback in clockwise direction one by one very very very slowly ...untill as it was in old flyback ( approximately ) --- remember TV is in on condition ... means high voltage will be there ... bymistake if you touch any part of the tv .. you will get very severe shock.... So be very very very carefull ..now while doing this adjustment observe what is happening on the screen - how brightness is changing ... Now switch off tv....connect signal ( antenna or dvd or cable..) & again switch on TV ....so now depending on brightness & clarity of the picture ..looking at the tv screen again you have to turn 1 or all the knobs on flyback either in clockwise direction or in anticlockwise direction very very very slowly ..once you start doing this adjustment practically then automatically you will come to know which knob should be turned . in which direction - & howmuch it has to be turned .... But remember this adjustment is very important .. Sometimes it will take 30mins to finalise the exact position.of knobs .. so take your owntime & finalise the exact position of those knobs..then switch off tv ..fix back the tv cover .. then switch on tv again ....that's all .......100% GUARANTEE again your tv will work normally ....vishnuswamy_23.jpg
Aug 31, 2011 | JVC Televison & Video
My jvc av-32890 makes a click and shuts off 95% of the time.It will not stay on and when it does it is only for a few seconds.
maybe your flyback. check b+ on the flyback. If you dont have voltage you can unsolder b+ pin on flyback and feed a 75 watt lamp to verify if power supply or flyback trouble.I think it`s pin 9 on flyback. look for print b+ on pcb.
Apr 23, 2010 | JVC AV-32890 32" TV
KP-46WT510 is blinking 8 times repeatedly on standby what is the problem?
Replace the Flyback transformer your correct flyback which is used in the WS510 and WT510 models is available at the following link.
http://servicemanuals.vstore.ca/product_info.php/pName/sony-flyback-145328551/cName/flybacks
Oct 28, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Tv turns on then turns off
you need to replace the flyback its the 259296 flyback which is available at the following link and they send free instalation instructions with detailed photos on how to do the replacement of the flyback.
http://servicemanuals.vstore.ca/product_info.php/pName/rca-flyback-259296/cName/flybacks
Feb 27, 2009 | RCA D52W19 52" Rear Projection Television
Replaced flyback
often the old flyback will cause CP150 and CP120 to dome on top when the old flyback goes out. Check the tops of those two capacitors for doming. They are located on the same board as the flyback.
Dec 27, 2008 | RCA HD52W59 HDTV Projection Television
Panasonic PT-53WXD63G Flyback, H.O.T., and Triper
The small wires are disconnected at the focus and screen control block, and the large HV cable is disconnected from the HV splitter.you may have to reuse the large red wire if the new flyback doesnt have the HV lead attached. The Hot is the horizontal output transistor its mounted to a aluminum heat sink near the flyback.
Jul 24, 2008 | Panasonic PT-53WX54 53" Rear Projection...
Phillips flyback
you can get a replacement flyback for your model at the following link you need phillips 32865 flyback HV generator.
Jun 05, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
How to replace flyback acer 14' 11d
hi there, there is a part number of the flyback at the body of it and you can repalce it by telling to the store the number of the flyback transformer. ty
Dec 24, 2007 | AcerView 78ie 17" CRT Monitor
SHARP MODEL 27N-S100
Flyback part number RTRNF0033MEZZ
Nov 10, 2007 | Sharp 27N-S100 27" TV
Samsung 793S 17" CRT Monitor Logo
23 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
