Question about Sony Cameras
No memory card
I check my SD card with another digital camera and also I check my camera with another SD card. Both were good. But my camera shows "no memory card" message on display, but before that it worked.
Habubnik
  • 114 Answers
SOURCE: cards not working with camera
If you used the SD/MMC memory card in another brand of camera or device, you may need to format the card in your new EasyShare digital camera. (You may have noticed a "Memory Card Needs Formatting" message when you inserted the card.) CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card. To format the SD/MMC memory card or the internal memory of the camera: Transfer images to the computer before formatting the memory card. Press the camera Menu button. Highlight SETUP MENU, and then press the OK button. Highlight FORMAT, and then press the OK button. Highlight an option - MEMORY CARD (deletes everything on the card), CANCEL (exits without formatting), or INTERNAL MEMORY (deletes everything in internal memory). Press the OK button. Highlight Continue, and then press the OK button. Wait until formatting is finished before removing the card. When formatting is complete, the SETUP MENU is displayed. Press the Menu button to exit the menu.
Posted on Aug 29, 2005
mail541
  • 58 Answers
SOURCE: my pentax k100d has a memory card error
Trun the camera off and remove the batteries. Leave it for at least a minute before inserting the batteries. Put the car in and turn the camera on.
The firmware in these cameras can get confused. Removing the batteries for a minuite or two will allow the camera circuits to discharge and so it will reset from start when powered-up again.
If this does not work then the camera may need to be sent away for repair. This need not be expensive it could be as simple as re-programming the camera. (Their program memory is writeable and so it can be accidentally altered under certian circunstsances. It may be possible to do this yourself using the downloadable firmware upgrade, but I would let someone else try thet first!)
However, it is just possible that the new card is also faulty!
Check the cards in your PC by obtaining a SD card reader to allow you to plug it directly into your PC.
For reference I would always recommend inserting and removing memory cards with the camera turned off. I would also use the SD card reader to load the images into the PC. Unplugging devices form the USB port can be harmful to some devices. Check the bottom right of your PC screen for an 'safe unplug' icon when things are plugged in.
Posted on Jan 21, 2009
pontelemon
  • 538 Answers
SOURCE: new sd memory card doesn't work in my digital camera
It will not work with any "sdhc"
Posted on Mar 19, 2009
  • 149 Answers
SOURCE: Card Locked Samsung SL 102 Camera
there is a lock button on the memory card check it if it is SD card or camera might not support the card try 1gb card
Posted on Sep 09, 2009
John Conner
  • 30 Answers
SOURCE: Memory card error message
Cards are coming in different formats and it might be possible that you brought a card which is not suitable or functional with your camera. The other reason could be that we are having options to lock our memory card in digital camera and you might have taken out your earlier card without unlocking it. The system might be broken from inside and this could be a reason that you are still getting a message that memory card is locked. It seems possible based on problem you are sharing.
Posted on May 29, 2010
Who can repair a Gateway DC-T50
Refer to the manual page below - note the last 2 items
If you take the camera and the card to a sales outlet the assistants are usually helpful
Inserting an SD Memory Card(Optional)
All images and video clips taken by the camera can be stored in an SD (Secure
Digital) Memory Card. Even if the camera's power is OFF, the images saved in the
SD Memory Card are not erased. An SD Memory Card can be repeatedly read and
written. You may also expand the memory capacity up to 512MB so that you can
store additional images and video clips.
1. Make sure the camera is off.
2. Slide the battery/SD Memory Card cover in the direction of the [OPEN] arrow.
3. Insert an SD Memory Card :
The front side of the memory card (printed
arrow) should face towards the front side
of the camera.
If the card cannot be inserted, check the
orientation.
4. Close the battery/SD Memory Card cover.
To remove the SD Memory Card, make sure
the camera is off. Open the battery/SD Memory Card card cover. Press
lightly on the edge of the memory card and it will eject.
Note:
If the camera is powered-on without the card, the "NO CARD" message appears on
the LCD monitor.
To prevent valuable data from being accidentally
erased from an SD Memory Card you can slide the
write-protected tab (on the side of the SD Memory
Card) to "LOCK".
To save, edit or erase data on an SD Memory Card,
you must unlock the card.
MultiMedia Card (MMC) can not be used.
You need to format an SD Memory Card before using it in this camera
Feb 19, 2015 | Gateway DC-T50 Digital Camera
Why will my camera not work when I put an sd card in
Check the memory card and memory card slot. If everything is clean and intact, look to see what size card you are using. The camera may not accept SDHC cards, so try an SD card that is 2GB or smaller.
Aug 18, 2014 | Casio Exilim EX-Z120 Digital Camera
Micro sd adapter i keeps in camera it is shows card locked
SD and Mini SD memory cards has a small slide switch on the edge of the card, which write protects data on the memory card or add photos to the SD card. Slide the switch from the LOCK position to the UNLOCK position, which is furthest away from the contacts.
Mar 18, 2013 | Canon Cameras
My camera shows formatt error when i switch on it. the memory card s not getting formatted. oly 2 options r showed format or switch off..... plzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz helppppppppppp.. i
You may have to large of a sd card. If it;s larger than 1mb then you may want to try using another that is smaller. See if that helps you out! Good-luck!!
Apr 06, 2012 | Olympus FE-210 7.1 MP Digital Camera w/...
Nikon d3100 showing no sd card inserted message even after inserting it..please help
The only thing I can think of remove the SD Card, start camera, and go into the menu, check to make sure there are no pictures on the internal memory, if there are! erase them and restart camera and power off, re-install card and hopefully you are good to go. If no change! have the camera shop run a quick check.
Mar 24, 2012 | Nikon D3100 Digital Camera
Camera locks up with SD card
Put the SD memory card into an USB card reader and plug the card reader into the USB port of a working computer to check if the memory card is working.
If the computer cannot detect the memory card as an external storage device and cannot open the files or folders and it cannot be formatted in FAT32 then the SD memory card is faulty and needs to be replaced..
Mar 24, 2012 | Sanyo Xacti VPC-S770 Digital Camera
Memory card says full when i put new sd 2gb card in card won't work on my kodak easyshare cw330 camera
I was checking to see if your camera had a limit to the size of SD memory card and couldn't find a thing so what I suspect is that the SD card lock has been engaged here is a diagram to show you how to unlock it.
Also any new memory card needs to be formatted in the camera before the camera can "read" it.
After pictures have been loaded to the memory card and then downloaded to the computer the memory card needs to be formatted to clean the old pictures off and make the memory card ready to accept new pictures.
Dec 30, 2010 | Kodak EASYSHARE CW330 Digital Camera
Camera is stating No Card when there is an SD card in camera
camera sd card board is faulty you need to relace new sd card board.
Jul 09, 2010 | Canon EOS Rebel XSi Digital Camera
Its saying the memory card is locked. its not
if you have checked the SD card was not locked, you may need to open the camera to check the SD card slot inside,
here is a tips shows you where to check
http://www.myfixtips.com/blog/digital-camera/how-to-fix-a-%e2%80%98card-locked%e2%80%99-problem-125.htm
May 16, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
BenQ C850 Switch from internal memory to sd card?
Try other SD card. 99.99% sure that the card is not good. Borrow your card to someone to check your card with his camera,or Format the card from C850 Menu.
Jan 30, 2009 | BenQ DC E600 Digital Camera
Cameras Logo
23 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
