Question about Air Tools & Compressors
Shutdown warning appear in plc what is the reason for this alarm
I connected 8, 100Ah battery with APC 2.2KVA inverter, now it doesnt give correct battery indication and keep producing beeping noise, whats the problem?
Continuous Beeping (theamber On Battery LED will be illuminated)
This alarm indicates that the UPS has reached aLow Battery condition and will soon shutdown. The UPS can only operate onbattery for a limited amount of time. In order to protect the unit's batteriesfrom discharging too much, the UPS will shutdown and turn off its output. Towarn you that the unit will soon shutdown, the UPS will sound this alarm 2minutes before actual shutdown. With optional Powerchute Plus software, 2minutes can be changed to 5, 7, or 10 minutes to give you more of a warning ofimpending shutdown. If you hear this tone, you should immediately gracefullyshutdown your operating system to prevent data loss or corruption.
Note:This graceful shutdown will occur automatically if Powerchute PLUS software isbeing used.
Constant, Solid Tone (the red Overload LEDwill be illuminated)
This alarm indicates that the UPS has detectedan Overload condition. If this alarm is sounded, try removing non-essentialequipment. The alarm will remain until the load is reduced. To determine ifyour UPS is capable of handling the equipment you want to protect, visit APC'sSizing Guide at www.apcc.com/sizing.
Continuous Beeps for One Minute; RepeatedEvery 5 Hours (Replace Battery LED will be illuminated)
This alarm indicates that the UPS has failed itsSelf-Test of the battery. The unit will continue to sound this alarm until theunit passes the test. Try to let the unit charge for a few hours and thenperform another Self-Test (Press and hold the on/off button until the second'chirp', then release). If it fails and the unit is still in-warranty (twoyears from date of purchase), then contact APC. If the unit fails and its outof warranty, then order a replacement battey cartridge through your reseller,distributor, or from APC's web site.
Apr 21, 2011 | APC Computers & Internet
Can not shutdown /CPU fan allways working
Try the following command......
shutdown [-i | -l | -s | -r | -a] [-f] [-m \\computername] [-t xx] [-c "comment"] [-d up:xx:yy]
No args Display this message (same as -?) -i Display GUI interface, must be the first option -l Log off (cannot be used with -m option) -s Shutdown the computer -r Shutdown and restart the computer -a Abort a system shutdown -m \\computername Remote computer to shutdown/restart/abort -t xx Set timeout for shutdown to xx seconds -c "comment" Shutdown comment (maximum of 127 characters) -f Forces running applications to close without warning -d [u] [p]:xx:yy The reason code for the shutdown
u is the user code
p is a planned shutdown code
xx is the major reason code (positive integer less than 256)
yy is the minor reason code (positive integer less than 65536)
Do reply me if it sort out your prob
Sep 30, 2009 | Abit SG-71 Motherboard
Does not shut down, the CPU fan keeps working for ever
it seems that you shutdown command is corrupted with virus
try the following
Usage: shutdown [-i | -l | -s | -r | -a] [-f] [-m \\computername] [-t xx] [-c "comment"] [-d up:xx:yy]
u is the user code
..........if nothing goes well do tell me for other options......
Sep 30, 2009 | Computers & Internet
Sanyo PLC XU105 Will shut down in 10 to 15 seconds
YOU HAVE A BAD LAMP OR THE LAMP DRIVER BOARD BAD
Aug 24, 2009 | Televison & Video
Sanyo Pro xtra projector - warning light
We have a similar situation with our Sanyo Pro Xtrax. It will be on for about a hour and then the "warning temp" light would come flashing red, and the project would turn off on its own.
Feb 08, 2008 | Sanyo PLC XU33 Multimedia Projector
Sanyo plc-xu35
Sounds like a simple problem to fix but don't ask here unless you plan on signing up...take your projector to a "real" professional who'll actually speak to you.
Sep 12, 2007 | Sanyo PLC XU35 Multimedia Projector
MULTIMEDIA PROJECTOR
have you ever seen the lamp come on? has the unit been used for a prolonged period with lamp on?
May 24, 2007 | Sanyo PLC XU35 Multimedia Projector
Air Tools & Compressors Logo
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
