Question about GPS
Why is my 06 mitsubishi triton engine RG46 is stuttering at low/med rpm whilst warming up
  • 98 Answers
SOURCE: 06 f-150 5.4L low idle code and warm ac at idle.
should idle around 700
Posted on Jun 11, 2009
  • 333 Answers
SOURCE: RPM to low (700rpm) mitsubishi outlander 2.4L 2005
Your throttle body likely needs cleaning.
Take the intake hose off and using throttle body cleaner or brake cleaner, spray a rag and use our fingers to clean the gunk off the throttle plate and the contacting area of the inside of the throttle body.
Posted on Sep 10, 2009
  • 236 Answers
SOURCE: engine stutters. wont go above 300o rpm
most likely the exhaust is plugged (cat converter) you can take it most any exhaust shop & they should test it for free.
Posted on Dec 18, 2009
  • 4793 Answers
SOURCE: Mitsubishi Triton V6 lacks power on acceleration
full power is only achieved when the engine is fully warm(operating temp).so if you accelerate more than, say, a third of the gas pedal,the car will feel sluggish.
this is more apparent when first starting the car in the morning in winter.almost like the car is going to stall.
most wear in the engine is leaving it to idle when cold you should always drive the car straight away from cold.then when hot turn on the a/c if required....
Posted on Jul 05, 2010
heimlich
  • 1978 Answers
SOURCE: cannot control engine rpm mitsubishi lancer engine
Your IACV idle air control valve has gone bad . When you put the car in gear does it take off and accelerate to about 50 MPH without touching the gas pedal ? Had the same problem. Part from Mitsubishi is about $435 PN # MR578268. It is about $30 to $50 dollars on any other car. If this is the problem, the IACV is located on the throttle body and is held on with three screws. I purchased the whole throttle body at a salvage yard for $40, took the IACV off and put it on my throttle body. Car works normal for now, I am looking for another spare. If enough people complain to MItsubishi and www-odi.nhtsa.dot.gov
Posted on Jul 26, 2010
MK Triton not engaging low range
How fast are you traveling when trying to engage? Some low range systems will disengage over a certain mph.
Feb 26, 2017 | Mitsubishi Cars & Trucks
Spark plug gap for 1997 mitsubishi trition 2.4 petrol ute
Spark plug gap does not effect the engine timing so it's not that critical. Thirty 5 (.035) should work just fine.
Otherwise consult a service manual fro your model or call a Mitsubishi service centre
mitsubishi triton service manual
Mitsubishi Triton L200 2006 2013 Workshop Manuals Factory Service Manuals
May 27, 2014 | Mitsubishi Pickup Cars & Trucks
Motor low idle problems
You need a carburator adjustment. I'm guessing it is a 302cid? It's burning too lean
Apr 09, 2014 | 1981 Ford F 150
Why does my new r1 stutter when you take off
Hi, Cw0676313 for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.r1-forum.com/forums/161-09-14-r1-mechanical-help/318586-bike-stutters-low-rpm.html
Engine Stuttering on Take Offs Low RPM FZ1OA Message Board
https://r1videos.files.wordpress.com/2011/04/2002-2003-yamaha-r1-service-manual.pdf
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Apr 06, 2013 | Yamaha YZF-R1 Motorcycles
Car stutters at 2000 rpm range and has a hard time starting when warm
Well, If you have changed all of the above the only thing left is the cat. converter. If they are stopped up the engine will shut down to protect itself, it can't breathe. Look under car and see the cat. converter? Is it purple? kick it and see if it rattles.
Jun 05, 2017 | Chevrolet Monte Carlo Cars & Trucks
Have a 4M41 engine in the 2007 mitsubishi triton and when under acceleration between 2000 - 2600 rpm the engine hunts or surges and then clears after 2600 rpm. It is more noticeable in 3/4/5 gears only...
It needs a programming check of the accelerator pedal via ecu of the engine. All previous activity of the system is recorded in the ecu which can be corrected in the dealership of mitsubishi.
Mar 28, 2011 | 2001 Mitsubishi Montero
Jul 05, 2010 | 1988 Mitsubishi Pickup
WHICH IS MY # 4 PISTON ON MY 06 F150 TRITON 5.4? Also my motor clicks when I get past 3000 RPM's and I lose power. Any help please???
The # 4 piston is on the passenger side last one to the firewall. Your getting a misfire past 3000 RPM and the engine is detecting the knock and is powering down so you wont hurt the engine any more then it is. If there is an Auto Zone around your area, have them scan the truck for any DTC codes free of charge. This should help us address the issues so we can get your F150 running 100% again soon. Good luck and keep me posted.
Sep 02, 2009 | 2006 Ford F-150
1996 Triton GL serious motor surge 3000rpm
Could be the injection pump any black smoke or gray smoke? could also be an injector ?
Jul 27, 2009 | Mitsubishi Pickup Cars & Trucks
GPS Logo
18 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
