Question about Fisher and Paykel Dryers
My Dryer stopped blowing hot air, How do I change the element? Model DE62T27L
  • 351 Answers
Not a good number, what brand is it, i can walk through the repair, whirlpoolpartssurplus.com mark
Posted on Jun 23, 2009
Blowing cold air
This model dryer has two heating elements, one for the top and one for the bottom, I suspect that the bottom element is burned out. If you want to attempt it yourself then I can send you a service manual that will walk you step by step through the whole dryer.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Dec 11, 2013 | Maytag Neptune MCE8000AY Electric Dryer
Dryer will not blow hot or cold air
what's the brand name and model number?i don't understand what you mean it won't blow hot or cold air?if you have the vent line off of the back and the dryer is running and you don't feel any air blowing out you could have a bad blower wheel,if you write back let me know if it's running and what it's doing.thanks
Feb 17, 2013 | Dryers
Dryer blows air, but no heat - the dryer powers on, the drums turns and the fan blows air, but the air isn't hot.
There is one of two possibilities:
1.-The heating elements dont come on due to a wire burnt off or the element itself has burnt out.
2.- There is a small electronic device in the element circuit called a thermal overload switch, which has and often does malfunction, stopping the power to the elements.
Best wishes,
Graemevm
Dec 17, 2009 | Office Equipment & Supplies
No longer blows hot air, only cold air
when a dryer does'ny blow hot air,it's normally either the element or the stats on the element.
Nov 01, 2009 | Dryers
Our dryer does not blow hot air? The cloths do not
more than likely the heating element has gone out. if your clothes have no heat then the element is the most likely cause. you can get one for anywhere between $30 - $50. you'll need to know model and serial #'s. usually easy to replace.
Jul 30, 2009 | Estate Dryers
Dryer working but not blowing hot air
Either bad thermal cutoff or bad element .( first 3 numbers missing on model #)
Jul 05, 2009 | Kenmore 800 6983 Electric Dryer
Dryer blowing cold air only
Check your heat sensors, one or more must be OPEN.
Mar 26, 2009 | Kenmore 84052 Dryer
Dryer runs but will not heat. Replaced fuse and
your cycling thermostat needs changed too. the thermal fuse is your last safety measure that goes, which means your cycling thermostat is not shutting down the heat element once it detects the right temp hot air in the blower housing so it let the heat element glow until either the high-limit sensor shuts the heat down or the thermal fuse blows. Change the cycling thermostat and good luck
Mar 06, 2009 | Whirlpool LER4634J Electric Dryer
Kenmore dryer replaced heting element now it does not blow any air
HI danon this dryer its common to have the blower wear out, it slides on the motor shaft, and what they do is wear out the flat in the blower. that could have caused the element to fail. check the blower thanks the appliance doc. please rate my answer. thanks
Sep 30, 2008 | Kenmore 62602 Electric Dryer
Maytag dryer not blowing hot air (2yrs old)
If the vent is blocked, it will not stop the heat, it will only restrict the air flow.
Generally a couple of things can cause the heat to stop.
Either the thermostat or the element.
I would first suggest the element.
It may be fatigued therefore the internal wire within the element becomes fragile and eventually breaks down. Although it is an electrical item, it is mechanically built and can fail.
In some dryers the element is held in clips.
These clips can cut into the element.
The thermostat maintains temeperature but again, it is mechanically built and can also break down.
If you are not capable of inspecting or troubleshooting the internals of the dryer (i.e remove the cover and look for the failurer), then have it inspected by a repairman. There is not too much that can go wrong with a dryer. The most expensive part wuld be the motor that spins the drum.
Sep 16, 2008 | Dryers
Dryers Logo
52 people viewed this question
Top Fisher and Paykel Dryers Experts
Tim Whalen
Craig Butler
Craig Butler
Virgil Watts
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
