Question about Toshiba Sattelite A105-S2071 Notebook
My toshiba satellite a50, i want to change boot order to usb drive
  • 25 Answers
If you want to change the boot just for one time press and hold F12 during the booting proces but if you want the computer to boot every time in USB mode you must press F2 to enter the bios setup, look for the boot priority option chnage save, exit and restar.
Enjoy
Posted on May 15, 2014
4 Suggested Answers
Pyrhyc
  • 2028 Answers
SOURCE: my toshiba satellite a50,
You need to go into the bios or utility set up. At start up there will be a Toshiba screen, on this screen at the bottom, it will read something like, esc to enter bios, or F1 to enter bios, F10 to enter boot menu, at this point you will need to press which ever it says to go into bios. Bios can also be refereed to as utilities or utility set up. Now, if you change the boot order in the bios, it will always check the CD drive before the hard drive. If you only want or need to boot from the CD drive this one time, then you will need to go into the boot menu at start up. When you get to the boot menu, it will give you a list, then you choose CD drive. If you go the boot menu route, be sure the CD is in the drive when you select CD drive, otherwise it will see there is no CD and skip straight to the hard drive. Keep in mind that on some machines it blows right past the Toshiba screen, so you may have to try a couple of times or just be quick to make your selection as to bios or boot menu.
Posted on Jul 03, 2008
sys_admin
  • 829 Answers
SOURCE: Toshiba Satellite A50
When the system boots hit the BIOS key F2 and in the setup select boot from CDROM and press F10 and exit, Insert the bootable CD and boot the system
Posted on Jan 06, 2009
SOURCE: toshiba satellite a50
try turn the usb on in the bios. it could be switched off. just tick one of the settings that will allow the usb drive to be recognized
Posted on Apr 14, 2009
My Toshiba Satellite A105-S2031 laptop won.t boot up. When I turn on the laptop the two small lights below F 10 and F 11 light off then the computer turns off.
Try removing the battery (in case it's shorted), plug in the power adapter and boot to bios (using F2, F10, etc). Be sure there are no USB memory sticks connected, etc. If you are able to boot to bios, great! Then, it's a matter of eliminating the root cause: either battery or hard drive. If you don't boot to bios, then you're most likely facing a hardware problem. It may be as simple as an unplugged cable.
If you can't boot to bios, consider connecting an external monitor to rule out LCD display problems.
Aug 09, 2013 | Toshiba Satellite A50 Keyboard
How can i go in boot option
Normally when you power on your Toshiba Satellite laptop it attempts to boot the operating system installed on its hard drive.
In some instances you may want to boot the Satellite laptop from a different device, such as an operating system installation CD or a USB drive.
The boot order doesn't have to permanently be set to the hard drive.
It's possible to access the boot order before the operating system loads and change which device is set to boot first.
Turn off the Toshiba Satellite laptop.
Turn it back on immediately and wait for the "press the F2 key to enter Setup" entry to show up on the screen.
Press the "F2" key to access the Toshiba Satellite's BIOS menu.
Use the right arrow key to navigate to the BIOS tab labeled "Boot."
Scroll down to the option labeled "Boot Priority" and tap Enter.
Check through the list of devices and locate the specific device you want to use to Boot your Toshiba laptop, such as "CD-ROM," "USB" or "LAN."
Highlight the name of the device in the list and then tap Enter to make it the top boot priority.
Use the right arrow key again to scroll over to the "Exit" BIOS menu.
Tap the down arrow key to highlight the "Save and Exit" option.
Press Enter to save the new boot order and restart your Toshiba Satellite laptop.
Repeat the procedure when you want to change the boot order back to its original setting.
How to boot your Toshiba PC from CD-ROM, LAN, or diskette
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/bulletin.jsp?soid=403623
Toshiba support
http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=ex&bbid=bb42&url=&dialogID=111194172&stateId=1%200%20111190763
Aug 02, 2013 | Toshiba Satellite 2415-S205 Notebook
How to change disk controller in bios on Toshiba Satellite A135-s2276?
Hello here is the homepage:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1596141&
You need this for the drivers.
And you can downlaod a manual
Press the "F2" key to access the Toshiba Satellite's BIOS menu. Use the right arrow key to navigate to the BIOS tab labeled "Boot."
Read more: How to Change the Boot Order for a Toshiba Satellite ' eHow.com http://www.ehow.com/how_6383103_change-boot-order-toshiba-satellite.html#ixzz2Cn6HdU2k
Turn on or restart your computer and watch for a message during the post about a particular key, usually Del or F2, that you'll need to press to ...enter SETUP. Press this key as soon as you see the message.
Go to boot and select the boot order.Use F4 or F5 to change.
First boot device: Cd/dvd drive
Second: the harddrive.
Leave the bios and save the settings.
Place your windows cd in the drive and reboot.
Now you can install windows again.
Good luck
Nov 20, 2012 | Toshiba Satellite A135-S2276 Notebook
Toshiba A50 Not able to boot from CD
When you load the cd and reboot, when you see the toshiba screen, start tapping F12, see if this brings up the temporary boot menu, if it does choose the cd and watch closely for "press any key". If there is nothing showing, might I suggest you get an external cd drive that attaches by usb. You will then have to get back to the BIOS and set the usb as your first boot device and try to boot again from the usb cd drive. Good luck.
Oct 08, 2009 | Toshiba Sattelite A105-S2071 Notebook
When I turn my Toshiba Satellite A50 on and Windows tries to boot I get the following: Windows could not start because the following file is missing or corrupt: WindowsSystem32ConfigSystem It then says:...
You need the Toshiba CD that says "Operating System"...
If the CD doesn't boot, then boot to the BIOS setup screen and change the boot order.
CD should be listed first.
Re-boot.
Sep 25, 2009 | Toshiba Satellite A50 Keyboard
Toshiba satellite a50 how to boot from external DVDROM USB
Apr 14, 2009 | Toshiba Sattelite A105-S2071 Notebook
Jan 06, 2009 | Toshiba Sattelite A105-S2071 Notebook
My toshiba satellite a50, i want to change boot order to cd drive
Jul 03, 2008 | Toshiba Sattelite A105-S2071 Notebook
Toshiba Sattelite A105-S2071 Notebook Logo
55 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
