Question about Robinair 92500 Transmission Fluid Exchanger
What kind of transmission fluid is required for toyota camry?
    New Friend:
  • 53 Answers
Check the maintenance section of the Toyota Camry Repair Manuals Toyota Repair Manuals
Posted on Jun 23, 2014
2002 Toyota Camry what kind of automatic transmission fluid does this car take
Check tranny fluid level. If at correct point new oil or adding will not correct anomaly. Need tranny pro to resolve issue.
If you need to add a little standard auto transmission fluid will do the trick. Nothing special.
Jun 06, 2016 | 2002 Toyota Camry
Whant kind of transmission fluid for toyota camry?
Hello, Use Toyota atf type t-iv fluid for transmission.
May 15, 2014 | Robinair 92500 Transmission Fluid...
What kind of transmission fluid for camry?
You don't say whether manual or auto.
manual - a GL-4 75W-85 manual trans oil such as Castrol VMX-M or equivalent
auto - Dexron VI or quivalent synthetic ATF
May 15, 2014 | 2008 Toyota Camry
What kind of transmission fluids can I use in my 2009 toyota camry 4 cylinder?
automatic requires the w s fluid.
if it's a manual trans use gl4,gl5, or 75w90
u can use any brank you would like.
Aug 31, 2012 | Toyota Cars & Trucks
How to change a differential for a 2002 toyota camry
On 2002 camry the fluid cavity is same as transmission, so it gets changed with transmission fluid. I suggest flushing. I am a Master ASE,Toyota Technician. 33yrss. Experience.
Feb 24, 2012 | 2002 Toyota Camry
What type of transmission fluid does a 1995 camry 4cyl use? dexron 1 or 2??
i hav a '94 camry, TOY-SPECS,say DEXTRON III W/(MERCON) but NOT DEXTRON 4 OR 5, THOSE are for diff TRANYS,make sure you buy th right kind....
Apr 09, 2011 | 1995 Toyota Camry
My 1997 Toyota Camry Manual 5 speed is slipping a little bit and i need to know how much fluid the transmission takes and what kind. I also want to know what it means when my rpms go up but your speed only...
Sounds like you need to replace the clutch if the rpm's increase alot and the speed increases a small amount the clutch is starting to have excess slippage. If you go to Autozone web site and search a bit you should be able to find the needed type of transmission fluid and quanity needed.
Dec 05, 2010 | 1997 Toyota Camry
How much transmission fluid does the 2002 Toyota Camry require for a standard transmission?
pint. there is a level line on the stick. it hast to be running to check level and fill running.
Apr 28, 2010 | 2002 Toyota Camry
Type of power steering fluid for 2001 toyota camry
Power steering fluid - Dexron 2 or 3 automatic transmission fluid. Yes transmission fluid. And while you are at it check the fluid level in the transmission.
Since you got the hood up, check the brake fluid, wiper fluid, radiator fluid, battery fluid, oil level.
Apr 26, 2009 | 2001 Toyota Camry
Robinair 92500 Transmission Fluid Exchanger Logo
74 people viewed this question
Top Robinair Heating & Cooling Experts
Paul Carew
Tim Whalen
Are you a Robinair Heating and Cooling Expert? Answer questions, earn points and help others
