Question about Whirlpool 4378411RB InLine Ice and Water Filter
How to fix a whirlpool 4378411rb refrigerator icemaker filter that is leaking
  • 409 Answers
SOURCE: whirlpool gold refrigerator icemaker leaking water
hi there,
sounds like the ice or water actuator or paddle is broken. purchase a new paddle and replace it.
the reason you have leak is because you have warm air entering through the broken part into the freezer.
can you provide me with the model # and i will send you a part breakdown.
Posted on Sep 16, 2008
  • 236 Answers
SOURCE: whirlpool refrigerator leaks
the drain hole at the bottom rear is blocked. a pipe cleaner run down it should clear it out.
Posted on Apr 09, 2009
ginko
  • 19396 Answers
Either the inlet valve is stuck or the icemaker solenoid is shored.
Most likely the second one.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Posted on May 22, 2009
woodchuck789
  • 4070 Answers
SOURCE: water leaking from icemaker on outside
If this is your water dispenser leaking
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Posted on Jul 08, 2009
EllaWatson25
  • 725 Answers
SOURCE: Whirlpool Gold refrigerator water leaking
If it's flooding, it's NOT the drain pan. It's probably the water valve has gotten stuck in the open position. Hope this helps!
Posted on Aug 21, 2009
Ice machine won't make ice! kenmore 363.9537883 bought whirlpool filter 4378411RB water comes out of door but pressure isnt good. Told me i needed a new filter. Is this the problem or something else?
The filter is for water AND the ice maker. The ice maker expects a certain amount of water to flow into it during the fill time. If no water flows at all into the ice maker, then suspect the clock mechanism of the ice maker.
Aug 14, 2016 | Kenmore Refrigerators
I cant find the filter on my hotpoint no frost refridg.number csx22gr where is it.
your model number doesn't come up.if it's an older machine some didn't come with water filters,you had to add an inline filter on the copper water line,you would run your copper,go down the cellar or behind the machine,cut the copper and the filter connects in between the copper where you cut the line.if you do have a filter it could be in the fridge section top right side or down in the bottom kickplate.i found your model the a was missing after the b baww.it doesn't show a filter,this is an older unit,check behind or in basement,wherever the water line goes and see if there's a filter added into it,if not you can cut the copper and add a filter yourself.home depot sells them
http://www.homedepot.com/p/Whirlpool-In-Line-Refrigerator-Water-Filter-4378411RB/202204720#.Ug7jNxXD_X4
Aug 16, 2013 | Hotpoint 21.7 cu. ft. Side-by-Side...
My icemaker is malfunctioning. I put a water filter in and purged the system but it is now leaking water from the icemaker. I found it iced up so I removed the ice and turned the icemaker off. What do I do...
run it a few more times to get the air out and to give it time to level out when you replace a water filter the pressure is increased and air will stay in the lines until it purges completly and settles down
Aug 23, 2009 | Whirlpool GX5FHDXT French Door...
Water leaking from icemaker on outside
Jul 08, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool gold refrigerator icemaker leaking water
Apr 04, 2009 | Whirlpool GS5SHGXKQ 25.3 Cu. Ft. Gold Side...
Try to find out if this unit needs a filter for the icemaker
Your refrigerator will not accept nor was designed to use a whirlpool water filter. No a filter is not required. Yes an in line filter can be installed prior to the connection at the inlet valve if you desire.
Apr 02, 2009 | Whirlpool ER6AHKXPQ Top Freezer...
Icemaker working somtimes
check water filter or water valve to change icemaker you have to have model#
Mar 31, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
hi there,
Sep 09, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool 4378411RB InLine Ice and Water Filter Logo
87 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
