Question about Dryers
What facts are there about neptune? - Dryers
Who has the true facts on Planet X Nibiru?
Any professional astronomer or astro club.
Nibiru is a mythical planet, sometimes called planet X, based on the old idea that irregularities in the orbits of the outer known planets could only be explained by the existence of a further, large, undiscovered planet.
However this idea, which started in the 19th Century, lost credence when it was found that the supposed irregularities were simply due to miscalculation of the real mass of Neptune.
Then when small objects began to be discovered in the Kuiper Belt beyond Neptune, the idea of Planet X reappeared. One of these objects was Eris, a bit smaller than Pluto, and too small to be a Planet X.
Modern telescopes and techniques have now all but ruled out the idea that Planet X exists.
Edit:Update: Using the latest sensitive observations NASA has discussed the possible existence of a "super-earth" very very far out in an extreme orbit. They have not found it, but say that the orbits of objects beyond the Kuiper Belt seem to suggest its existence.
http://www.news.com.au/technology/science/space/nasa-admits-the-mysterious-planet-nine-is-real-but-says-deadly-nibiru-is-a-f raud/news-story/5037076a579e7e5c642396d307b6aeee
However the idea of a Planet X, or Nibiru, crashing into Earth, has again been dismissed.
Jan 23, 2017 | The Computers & Internet
Name the moons of neptune
On July 15, a 14th moon of Neptune, provisionally called S/2004 N 1, was announced.
Outwards from Neptune, the inner moons are Naiad, Thalassa, Despina, Galatea, Larissa, S/2004 N 1 and Proteus.Next outward from Neptune, Triton is one of four moons in the solar system known to have an atmosphere. The thin nitrogen haze is thought to have evaporated off of the frozen surface.After Triton comes Nereid. Much further out than Nereid orbit five outer moons, Halimede, Sao, Laomedeia, Neso and Psmathe.
http://www.space.com/21977-neptune-moons-planet-facts-infographic.html
Feb 03, 2015 | Optics
I have a maytag front load neptune. The door is locked but does not show that it is lock on the panel, it will not wash but will not open either, how can I get the door open?
they seem to have a issue with the doors on theses machines whirlpool owns maytag now
they were sued very bad for theses issue
The older Neptunes, such as the 2000 Stackers, MAH3000, MAH4000 and the MAH5500A series had some issues which I am sure Maytag has corrected these issues in the newer machines...
There are thousands who have been burnt by the door latch wax motor failure. What happens is the machine will stop spinning because the door latch will fail to lock. Deep inside it is caused by the mechanism that locks the door. The wax motor will draw too much current and damage the control board by burning a resistor (R11) and a triac (Q6).
However, if Neptune owners know to replace the door latch wax motor they can prevent the control board failure from happening. Please tell everyone you know about this important fact.
The older Neptune's also have a couple additional issues such as the moldy door boot and the reliability of the motor / motor control board. All three of these issues were involved in the class action lawsuit a couple of years ago. See http://www.neptunewaxmotor.com for more Neptune information.
In addition, I just now started offering a bearing and seal kit for the Neptunes because when the bearings fail Maytag wants you to replace the whole outer tub for a service quote of around $900 or so. Why replace the whole outer tub? Just replace the worn bearings and 12002022 seal... See http://www.neptunebearing.com for the Neptune bearing kit information.
The older Neptunes run great once you take care of some small details...
Dec 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
I HAVE AN OLDER MAYTAG NEPTUNE FRONT LOAD WASHER MOD# MAH3000AWA. I AM HAVING TROUBLE WITH IT, IT WILL NOT DO THE FINAL SPIN CYCLE IT SPINS WHEN IT WASHES, AND RINSE CYCLE, BUT THE FINAL CYCLE IT JUST...
Maytag Neptune defective door latch wax motor update
by: Anonymous
The older Neptune’s also have a couple additional issues such as the moldy door boot and the reliability of the motor / motor control board. All three of these issues were involved in the class action lawsuit a couple of years ago. See http://www.neptunewaxmotor.com for more Neptune information.
Feb 22, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Smell in Washer
The best suggestion I can givefor this is to use a tablet called Affresh.
http://www.affresh.com/
This is a great cleaner for all HE washers. I hope this helps.
Good Luck!
Feb 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Machine keeps tumbling after wash cycle is completed.
Make sure that the replacement R11 is in fact connected to pins 1 & 2 of the Q6 triac. If the copper trace on the backside is open on either leg of the R11 to the Q6 then the wax motor will stay energized and that will cause the tumbling after the wash cycle.
See www.neptunehelpsong.com for a new funny song that explains the Maytag Neptune door latch wax motor issue.
Jan 21, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Can I eliminate or at least shorten the delay on the door lock feature?
unfortunately there is no way to elimate the wax motor.do not try to jump it out,you will blow the control board.
Sep 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
Dirty sock smell
My suggestion is to contact Maytag. I have the same problem. Maytag can tell you what you can do to reduce the odor. I think the problem originates from the fact that the drum always has water in it and the rubber seal has a bad smell.
Sep 07, 2008 | Maytag Neptune MAH5500B Front Load Washer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
