Fujitsu lh700 I'm trying to reformat my laptop. everything was going ok until they asked to insert recovery disk 1. I have it in the cd-rom but the message just keeps popping up. How should I proceed?
  • 103 Answers
SOURCE: system crashed
well you would have to purchase a operating system from one of your local computer stores to fix that problem. There are other methods but they are very risky and may damage your system so i suggest you purchase the cd and keep it in a safe place after use.
please rate me. thank you.
Posted on May 30, 2008
hardkiss69
  • 43 Answers
SOURCE: Can't find DVD/CD-ROM
Hi, the error code that you have is a known issue from Microsoft that needs a registry tweaks. Error code means "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (code 39)" . You can click on this link for your reference http://support.microsoft.com/kb/929461/en-us
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue.
2. Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
This will surely help you resolve your issue. Good Luck!!!
Thanks
Posted on Sep 28, 2008
  • 100 Answers
SOURCE: IBM Thinkpad R51-Recovery Disc
I have an r-51. are you completely relying on the recovery disks or do you have a copy of windows with a valid key
Posted on Dec 26, 2008
leecom72
  • 4806 Answers
SOURCE: Installed new hardrive on our Compaq laptop, question
Hi there.
Just make sure the boot order is set to the CD/DVD, you can do this by going into the bios or pressing F12 while the computer starts up.
please post back if you need any more assistance.
Regards
Posted on Jun 01, 2009
  • 166 Answers
SOURCE: Trying to use Toshiba "recovery Disk creator"
u need a blank dvd, or tell the program your using regular cd, it will be like four dvd's or like 11 regular disks. in some cases it wont work with either, i have seen it where the program just doesnt know any disk is inserted or blank. if thats the case, update the program or contact toshiba
Posted on Sep 01, 2009
I deleted the administrator my mistake now i cannot login to windows can I reset to the factory settings
hi, hope this helps,
1. Make sure the computer is turned off.
2. If any peripheral devices, except the optional external CD-ROM drive unit
(CE-CD05), are connected to your computer, disconnect them.
3. Turn on the computer.
4. When the message Press <F2> to enter SETUP appears, press F2. The
Setup Utility opens.
5. Insert the Product Recovery CD-ROM disk 1 into the CD-ROM drive.
6. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
7. In Boot Sequence of the Main menu, set CD-ROM Drive to the top of the list;
then, press ESC.
8. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice.
9. Read the message on the screen, and select the operating system which you
had selected for the first time you use the computer; then, press Enter.
You cannot change the operating system from the first choice.
10. Read the message on the screen, and select the way to recover your system;
then, press Enter.
11. Read the message and select Continue; then, press Enter.
12. Read the message and select Continue again; then, press Enter.
13. If you see the message asking you to insert the Product Recovery CD-ROM
disk 2, remove the disk 1 and insert the disk 2; then, press Enter.
14. If you see the message asking you to insert the Product Recovery CD-ROM
disk 3, remove the disk 2 and insert the disk 3; then, press Enter.
15. If you see the message The Operating System has been recovered
successfully, remove the Product Recovery CD-ROM disk 3. The system will
restart automatically.
16. When the message Press <F2> to enter SETUP appears, press F2. The
17. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
18. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice. The system restarts.
19. Set up Windows, following the instructions on the screen. When you finish
the setup, the recovery is completed.
Jun 02, 2011 | Sharp PC UM20 PC Notebook
How do i restore my hp pavilion dv 5000 to factort setting?
There should have been a recovery disk created or included when you bought a laptop. Insert disk if you have it and restart your computer with the recovery disk in the CD drive. Make sure all your documents and personal data are backed up. When the computer restarts it should start restoring your computer to the factory default. There will be a wizard to guide you through the process.
If there is no disk or got lost,then follow this steps:
1.Save any files or folders on your computer with flash drives. Drag and drop files onto the icon of your flash drive.
2.Go to "Start" > "Restart" to reboot your netbook.
3.Hold down "Alt" and "F10" when you see the logo on the screen. The recovery menu will load.
4.Hit "Enter" and then "Next" to see your recovery options. Choose "Factory Restore" to set your computer back to factory settings. Follow the instructions on the screen.
5.Choose your time zone and language when the customization menu appears. Reboot when you are prompted.
6.Restore your saved files from the flash drive.
hope this helps,Goodluck..pls response with your rate and testimonials below for further issues..thanks
Feb 23, 2011 | Computers & Internet
Tried inserting recovery cd-rom in satellite P10 (windows XPHome) and first screen shows message about running Windows98! Aborted process and PC is OK. Is it safe to proceed?
should be. It looks like someone updated that computer from Win 98 to XP - that's why the recovery disks are for Win 98. You should be ok to proceed if you didn't do any of the recovery. Are you able to use System Restore to force computer to revert to an earlier time when everything was working ok?
Jan 09, 2011 | Toshiba Computers & Internet
How do i restore my acer aspire
  1. Eject the CD-ROM tray
  2. Insert the System CD, marked Disk 1.
  3. Select Start, Shutdown, Restart
  4. The System disk will be detected and boot into the graphical menu
  5. Select your language
  6. Click HDD Full Rebuild
  7. Remove the System CD and insert the Recovery CD (Disk 2-1), then press OK.
  8. Press OK to install the displayed OS.
  9. Press OK to agree to the License Agreement.
  10. Choose the partitioning that you would like to use and press OK.
    It is suggested that you use the existing partitioning.
  11. The system will begin to restore the factory software image.
  12. Remove the Recovery CD when prompted and insert the System CD.
  13. The system will reboot
  14. Remove the System CD when prompted
  15. Press the space bar to complete the recovery process
Aug 26, 2010 | Acer Aspire One PC Notebook
When I format my laptop with the disk, it asked me
On the System Recovery Options menu, click Startup Repair. Startup Repair might prompt you to make choices as it tries to fix the problem, and if necessary, it might restart your computer as it makes repairs.
Aug 15, 2009 | Sony VAIO VGN-FS760 Notebook
Laptop froze
Bad News, serious problem!
Either Operating System is corrupt or Hard Drive defective. First Try REinstalling the Factory Recovery Disk Bios. Open CD rom Trey Place Factory System REstore disk. Turn on Computer and you should see "bood from CD, press any key" . Do so and follow instructions. Remeber to DELETE SECTORS when asked and when prompted select NSFS format. Follow instructions , use common sense and it should work.
If the HD is Defective, it will stop loading and indicate it cannot find HD in an error message.
One other thing. IF when you insert the disk and it boots up and does not go into the restore mode look on bottom of screen for BOOT ORDER and select CD ROM as the first boot. If you dont see that then you have to go into the BIOS and reset BOOT ORDER TO CD ROM FIRST. To get into Bias try tapping down f-2 key as its booting. If that dont work repeat with f-10, f 12 and then Delete button if all else fails. Find BOOT ORDER in BIAs and follow instructions on making CD ROM the first boot device. Then Save and Exit. Reinsert Restore disk and wait until you get the boot from cd rom prompt (process upove).
Unfortunately all data will be lost but computer will work fine.
If the drive is defective it has to be replaced. Write me again if that is the case if you want to do that yourself.
Good Luck
Cheers !
Jul 25, 2008 | Computers & Internet
Reformatting my computer
  • Using System Recovery CDs
  • Change the boot order in the BIOS:-
  • Turn off the computer:
  • Disconnect devices that are connected to USB, Fire wire, parallel and serial ports, except the keyboard, the mouse anb Internet Connection.
  • Turn on the computer.
  • When the color screen with the logo appears, press the F1 key on the keyboard until Entering SETUP is displayed. (You only have a few seconds to press the F1 key before the normal startup process continues.)
  • Wait until the BIOS setup program opens.
  • Press the right arrow key to select Boot.
  • Press the down arrow key to select Boot Device Priority, and then press Enter on the keyboard.
  • Change the first boot device to CD-ROM using one of these methods:
  • Press the down arrow key to select the CD-ROM item. Press the + (plus) key to move the CD-ROM item up until it is the first item in the list.
  • Press the down arrow key to highlight the First Boot Device selection. Press the + (plus) key until CD-ROM is the selection.
  • Start the recovery:-
  • Press the Eject button on the top CD-ROM drive, and wait for the tray to open. Insert the System Recovery CD #1 and close the tray.
  • Press the F10 key to save the changes and exit BIOS.
  • With Yes selected, press Enter.
  • The recovery window automatically starts; wait for the onscreen instructions to display, and then follow the instructions:-
  • Press R, and then press the F key again.
  • Click yes to perform the full system recovery.
  • Insert the remaining CDs when directed.
  • When the recovery program finishes, click Restart to restart the computer.
  • Before the computer restarts, the CD tray ejects. Remove the CD
  • Return the BIOS to the previous setting
  • When the color screen with the logo appears, press the F1 key on the keyboard until Entering SETUP is displayed. (You only have a few seconds to press the F1 key before the normal startup process continues.) Wait until the BIOS setup program opens.
  • Press F5 Key to Set Default Settings in BIOS.
  • Select yes and press Enter.
  • Complete the recovery
  • After the computer restarts, a series of startup screens appear. Complete Microsoft Windows setup as follows:
  • Complete the registration process, and then reconnect the devices that were disconnected earlier.
  • Reinstall software that did not originally come with the computer.
  • Write data files that were previously saved on the backup CD or diskette you made from the hard disk.
Jul 04, 2008 | Computers & Internet
Dell 710M Problem
Hi mod22, click on this link for the latest driver software for the Inspiron 710M notebook.
http://support.dell.com/support/downloads/devices.aspx?c=us&cs=19&l=en&s=dhs&SystemID=INS_PNT_PM_710M&os=WW1&osl=EN
You most likely received restore CD & windows CD with the dell. If you didn't than the download site above will be a must for drivers.
The error message SMART = Self-Monitoring, Analysis & Reporting Technology. It is not the same thing as drive testing. It’s actually a part of the drive electronics & it tests its self. There is a 50/50% chance after turning off SMART in the bios you're drive will continue to function.
We do not want to wipe you're drive because there are other partitions that dell has in place.
This partition is needed to restore you're drive & OS.
Try this.
1- Start up the computer & press F8 or F12 every two seconds to give you windows boot-up options.
2- Insert Windows Installation / Recovery CD into cd-rom drive, high light the cd-rom drive & press enter.
3- Let the installation process continue until it prompts you to "Press R to repair". . This should then take you into the DOS mode.
4- Type in FIXBOOT & when prompted, press "Y" to start creating the new boot partition. If everything goes right, you should get a message saying the partition was corrupted and a new one was created successfully.
5- Remove the CD and reboot your system, everything should be ok now.
If not than put you're Windows CD or recovery CD into the cd-rom drive. Again press the F8 or F12 key every two seconds at boot up until the windows boot device window loads. Choose the cd-rom drive. If you are using the recovery cd follow the prompts on you're screen. (Best choice).
If you're using the windows CD choose to format the C:\ & install windows fresh. Last option. If you know or can find the name & model of the hard disk drive, you can go to their web site & download tools & utilities software. There will be software for you to make a bootable CD that can test & fix the hard disk drive. The object of doing this is to keep the drive running rather than going through this again or buying a new hard drive. The Mfg's software will also let you know if the drive is going. (Chances are the software will repair the drive).
Good Luck!
If you have a problem with anything above just let me know & I'll try to clear up any issues.
Mike
Jul 02, 2008 | Dell Inspiron 710m Notebook
Want to erase drive
If your Laptop is purchased with Recovery Disk, you can use that disk to restore the default setting of your laptop. It usually FORMAT your hardisk and erase all programs and files saved on your Hardisk. If Recovery Disk is not available then you can simply use your provided Windows Installer to format your Laptop and install a Fresh Windows on your Laptop, be sure to format the Whole Disk Drive to erase the files.
Jun 11, 2008 | Dell Inspiron™ E1505 PC Notebook
I want to format my compaq presario sr2173wm. how do I do this
you can go to your DOS, or go to run, type cmd. and go where it says C: if you are not there already and type C:/format or C:/format.exe and that should work or you could also insert an operating system disk and boot from disk and reformat the drive that way.
Hope this helps.
Apr 10, 2008 | Computers & Internet
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
