I get an error 0x8007045A what does this mean
An error occurred while loading the troubleshooter came up when i tried to troubleshoot my wireless connection. error details:- 1) Package I.D: unknown. 2) Path: ...
Are you running under a limited account? If no, you may have a virus, malware, adware, a browser hijacker, or pups (potentially unwanted programs).
A. If your computer will boot and you can operate it ok...
Download and install Malwarebytes and Superantispyware (Note: If you can\'t do the download on your machine, do it on a friend\'s, put them on a thumb drive, and install them from it). Then scan your computer with each program, and quarantine anything found.
B. If your computer won\'t boot, or can\'t operate properly after boot...
Tap F8 when you are booting, select "Safe Mode With Networking". Download and install Malwarebytes and Superantispyware (Note: If you can\'t do the download on your machine, do it on a friend\'s, put them on a thumb drive, and install them from it). Then scan your computer with each program, and quarantine anything found.
C. If this process finds malware, to keep stuff like that from coming back, I recommend you get the paid version of Malwarebytes.
Good luck.
G
Jul 03, 2014 | Computers & Internet
Dell vostra laptop will not connect to internet
You need to run the "System file checker". Below is instructions on how to do that. You MIGHT need your dell OS disk, should have shipped with your Dell. If you can't find it, any Windows OS disk that matches your existing OS will work.
http://support.microsoft.com/kb/929833
Jun 19, 2014 | Dell Vostro 3500 Laptop Computer (Intel...
I have a R 93 ami jukebox and keep haveing error codes 1and4 what do they mean
Error 4 means the memory backup battery inside the Central Control Computer is dead or very low. Error 1 means factory defaults are being loaded due to a dead battery.
Jun 15, 2014 | Wurlitzer Jukebox CD Player
What does this error mean dryer has error f-01?
The "F1" error means that the dryer's thermistor failed and needs to be replaced. Make sure you check the dryer vent for clogs before installing the new part.
May 04, 2014 | Kenmore Dryers
Erorr code 4003 zebra zxb8
Error Code 4001
System error code 4001 means "The local WINS cannot be deleted." This error code may also display as "ERROR_CAN_NOT_DEL_LOCAL_WINS" or as the value 0xFA1.
Error Code 4002
System error code 4002 means "The importation from the file failed." This error code may also display as "ERROR_STATIC_INIT" or as the value 0xFA2.
Error Code 4003
System error code 4003 means "The backup failed. Was a full backup done before?" This error code may also display as "ERROR_INC_BACKUP" or as the value 0xFA3.
Error Code 4004
System error code 4004 means "The backup failed. Check the directory to which you are backing the database." This error code may also display as "ERROR_FULL_BACKUP" or as the value 0xFA4.
Error Code 4005
System error code 4005 means "The name does not exist in the WINS database." This error code may also display as "ERROR_REC_NON_EXISTENT" or as the value 0xFA5.
Error Code 4006
System error code 4006 means "Replication with a nonconfigured partner is not allowed." This error code may also display as "ERROR_RPL_NOT_ALLOWED" or as the value 0xFA6.
System Error Codes
Sep 15, 2013 | Zebra ZXP Series 8 Thermal Card Printer
Attempting to upgrade my assembled desktop (uses ASUS P5KPL-CM motherboard) from Windows 7 x64 to Windows 8, but receive error 5 times in a row.
How To Repair Error 0X8007045a Instantly Problem: Error 0X8007045a is caused by damaged windows files or broken system structures. This is a critical problem that can cause an unstable operating system, which is typically caused by improper management of the computer.
Solution: Repairing Error 0X8007045a is quick and easy. Please download the Windows repair tool below to diagnose and fix the cause of your problem.
http://simple-pc-help.com/How-To-Repair-Error-0x8007045a-Instantly/
or manually repair :
To resolve this problem, use one of the following methods.
Method 1: Upgrade or reinstall the Microsoft XML parser
To download the latest XML parser, visit the following Microsoft Web site: http://msdn2.microsoft.com/en-us/xml/bb190622.aspx
Method 2: Replace the corrupted files
To resolve this problem, follow these steps:
  1. Copy the following DLL files from the C:\WINDOWS\SYSTEM folder on a computer that is working to the computer that is experiencing the problem:
    • Msxml3.dll
    • Msxml3a.dll
    • Msxml3r.dll
  2. After you replace the files, you must register the files. To register the files, follow these steps:
    1. Click Start, and then clickRun
    2. In the Open box, type REGSVR32 C:\WINDOWS\SYSTEM\MSXML.DLL, and then click OK. You receive a message when the registration succeeds.
    3. Repeat steps a and b with the following files:
      • C:\WINDOWS\SYSTEM\MSXML2.DLL
      • C:\WINDOWS\SYSTEM\MSXML3.DLL
    4. Restart your computer.
Jan 14, 2013 | ASUS Computers & Internet
Error codes
Here are the common error codes for the LG machines.
LG Washing Machine Error or Fault Codes
If you have a LG Washing Machine you may see an error code come up and wonder what it is. Here are the common error or fault codes that will be displayed on the LG machine.
OE
This means that the washer has tried for ten minutes to drain the water out of your machine and the water did not drain out.
UE
This means that the load in the drum is out of balance causing excessive vibration when spinning.
IE
This means that the washer has not filled with water in 8 minutes.
LE
This means that the motor and the control panel are not talking to each other properly
PF
Power Failure – The power has gone out to the machine and then has come back on
FE
This means that there is too much water in the machine
PE
This means that the water level sensor is not working properly
CE
The washer motor has received and over current condition
TE
This means that your heating sensor is not working properly
SE
This means that you had a temporary sensor error
HE
This means that you had a temporary heater problem
DHE
This means that you had a temporary dry heater problem
This will give you a basic idea of what has caused your error code.
Heatman101
Mar 15, 2010 | LG WM2277H Front Load Washer
Code errors on kodak easyshare esp 3
error code 3501 means the front access door is open on the printer. Error code 3502 means the paper tray is empty. The error code 3602 means the print job did not finish printing.
for more hrlp visit CBR Tech Solutions
Apr 10, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
