Question about Health & Beauty
My jazzy control cords continually blink on and off chair won't move
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 67 Answers
Without knowing the model and some other info- blinking lights most often means low battery, brake/clutch levers in free-wheeling more, or chair is partially tilted and the drive is locked out.
Posted on May 30, 2014
dromtonpa
  • 40 Answers
SOURCE: My Jazzy won't move.
If your batteries are truly charge they should read around 24.5 VDC. And if the freewheel lever is engaged and you still have no movement your probably need to get into a service tech. Also check the circuit breaker on the chair.
Posted on Apr 03, 2009
SOURCE: lights on hand control flash off and on and chair will not operat
There is a series of diagnostic flash codes associated with the controller. The diagnosis depends on which color and how many lights are flashing. If you post the combination, I can help you. Or you can download the Basic Operation Instructions of the Pilot Controller from the Pride website. The codes are listed on page two on the troubleshooting instructions.
Posted on Apr 14, 2009
SOURCE: Jazzy 1121 power chair won't go
It may not be the joystick. I have had the same problem before. The edel cable that goes from the joystick to the back of the wheelchair could be bad. You can try unplugging it and plugging it back into the joystick. Check the prongs on the cable and make sure their not broke. You can also try flipping the switch that is located down by the charger under the chair. The cable is around $200 and the joystick is quite a bit.
Posted on May 16, 2009
SOURCE: Fault codes jazzy 600 power chair
8 lights flashing how can i fix it?
Posted on Sep 20, 2011
  • 104 Answers
SOURCE: Jazzy 1113 Power wheelchair. Batteries are fully
I'd look for a loose connection, one battery bad could be it, but its not likely, you can still move it with low voltage, one low batt., could be joystick. You can get generic trouble codes off your joystick, and call the manufacturer, Pride, 1-800-800-8586.
Posted on Jul 10, 2012
Jazzy chair yellow light on the power control continues to blink. will not turn off.
yes nplug battery charger in and wait till batterys asre fully charged and turn off,if it doesnt u got water or moisture in the joystick and need a new one
Jan 06, 2014 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
Jazzy 1107 power chair won't move
3 flashes indicate that there is a short circuit to the left motor and battery connection. Check wiring and connections
Jun 14, 2013 | Pride Jazzy 1113 ATS Indoor Power...
Jazzy 1113 power chair shows charged but control light is blicking. Chair will not move.
It appears that the controls are in Lock Mode. Unlocking Instructions depend on your type of controller. Go to PrideMobility.com to download the proper manuals for chair and controller.
Feb 11, 2013 | Pride Jazzy 1113 Power Chair
Why are the lights blinking and it won't go
read manual,lights flash when in security mode,everyt model has a unlock procedure with the buttons on the joystick control.
Jan 23, 2013 | Pride Mobility Jazzy 1143 Power Chair -...
Blinking yellow wrench light on pride jazzy 614 HD
Your version has a Dynamic Controls model controller and joystick.
Unplug the charger and engage the motor/brake lever so the chair is no longer in free-wheel mode (con't push by hand)
Turn the chair off, wait 5 seconds, turn the chair back.
If chair still does not run and your wrench is flashing you have a problem. Count the wrench flashes - the flash count indicates the error detected. 3, 4, 5, and 6 flashes indicate and error with the motors.
3=Left motor fault
4=Right motor fault
5=Left brake fault (may not be engaged)
6=Right brake fault (may not be engaged)
Any other fault code usually means the electronics or wiring is bad and not worth fixing.
Jan 06, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
Wont move yellow lights ,flashing
The number of lights that are blinking indicate what the problem is. Visit this site to locate the type on controller on your power chair and you will be able to see that the blinking lights mean:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Try to reset your manual brake release as this is a common problem.
If you continue to have a problem, contact your manufacturer or dealer for service. If your insurance purchased they power chair for you, they may also cover the cost of repairs.
Sep 10, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Blinking lights on quickie p220 joystick chair will not move
Sep 10, 2010 | Pride Jazzy 1103 Ultra Indoor Power...
Jazzy 610 got wet. controller lights blink
Electricity and water don't mix. Allow the controller to dry out for several days. Even if it looks dry, water may have collected inside and fried something.
Aug 06, 2010 | Pride Jazzy 1103 Ultra Indoor Power...
Chair no longer charges, no flashing or blinking, lights,
May 07, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Health & Beauty Logo
89 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
