Question about Samsung DV350AGP Gas Dryers
Why isnt my samsung dv350agp/xaa gas dryer that everything lights up but nothing happens when it starts. display shows its runnng thru the cycles.
Power goes on. display showing that cycle is running but tumbler not turning
My model number is Samsung dv350agp, I also opened the top and the belt appears to be fine... Also checked the metal house and it is clear nothing is built up inside of it.
The dryer is almost 4 years old.
Posted on Nov 13, 2015
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
Sounds like broken belt
Posted on Jun 29, 2014
  • 686 Answers
SOURCE: Can I run the dryer vent vertical and how high?
yes
Posted on Apr 08, 2009
SOURCE: My Samsung electric dryer, model DV337AEG is
You have a bad heating element. I just went through the same problem with mine
Posted on Jul 26, 2009
rickead1
  • 1998 Answers
SOURCE: samsung dryer dv317aeg/xaa has code on display
http://www.washingmachinereviews.org.uk/fault-codes/errors-and-solutions/ use this site try this solution is what the company suggests simply folo down the list till u see your error code with there solution if this does not work u willhave t call a tech to do test on your heater as well as the wiring going to the heater
Posted on Jul 26, 2010
SOURCE: My Samsung Dryer (DV218AEB/XAA) Error code HE
invalid heating temp when running. call for service.
Posted on Sep 18, 2010
  • 291 Answers
SOURCE: have a samsung dryer model DV209AEW/XAA. I "hand
Check to make sure your child lock is off first. Hold the time and signal buttons simultaneously for three seconds. Unlikely, but do check. Some of these dryers have a safety switch that the idler pulley has to engage to allow the dryer to run. I tried to find a schematic for this model but could not get one to tell if you do have a safety switch. Look at the arm of the idler pulley and see if it is contacting the switch actuator correctly. When a belt breaks or pops off, sometimes the arm of the pulley will move to the other side of the switch actuator and will not allow the dryer to run once a belt is reistalled. I would also look to see if a wire was knocked off of the motor switch when your belt came off. Good Luck, Appliance Specialists
Posted on Dec 03, 2010
Just plugged in this dryer which I was told it was working when I picked it up. Everything lights up, but when I push the start button nothing happens.
Dear Interpreter1 ,
Try Holding the Start button for 3 Seconds or longer to see if it will start.
Here is a link to the Operating Instructions for your dryer
Good Luck!
JP
Samsung DV209AE User Manual
Jul 14, 2015 | Samsung DV218AEW Electric Dryer
Samsung gas dryer dv350agp/xxa have lights come on but is not working
It could be that you have a broken belt. Can you heat a motor running? Try placing your ear to it when you turn it on, if you can hear the motor running then remove the back panel and see if the belt is in tacit.
Best of Luck
'RR
May 15, 2014 | Samsung DV350AGP Gas Dryers
Drying time goes from 44 to 6 minutes
Check your vent system first to make sure that it is clean. You most likely have a bad thermistor in the dryer. The thermistor senses heat and humidity and is responsible for telling your dryer when to shut off. It is probably reading out of spec
Feb 07, 2014 | Samsung DV350AGP 7.3 cu. ft. Steam Gas...
Any recalls on aluminum dryer drums from samsung? less than 2 years old and seam split
No recalls. Warranty is one year on parts and labor. New drum is 124 dollars.
Aug 07, 2013 | Samsung DV350AGP Gas Dryers
105I have a samsung dryer dv409AER/XAA. Currently, I turn the power on and select a cycle and push the start button. When I push the start button - nothing happens. This occurs for any cycle. There is...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 27, 2011 | Dryers
I have a Samsung DV316BWG/XAA Gas dryer I have power at the outlet, the digital display is working when I set the time and push the start button I get nothing. No error codes and I get 2 blinking bars on...
heatman101
May 25, 2011 | Samsung Dryers
Lights come on and you can choose your cycle but when you push start i hear a clicking at the top but it wont start
YOU HAVE A BROKE BELT,,, WHEN THE BELT BREAKS IT SHUTS OFF A MICRO SWITCH,, THE TIMER WILL WORK BUT NOTHING HAPPENS
Jan 20, 2011 | Samsung DV448AGE Gas Dryer
Dryer will not start
A dryer may not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Apr 11, 2010 | LG DLG5932W Gas Dryer
Kennore gas dryer # 110.87694110
you need to check the door switch and the start button first
Feb 11, 2008 | Kenmore 74602 Gas Dryer
Samsung DV350AGP Gas Dryers Logo
193 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
