Question about Casio FX-115ES Scientific Calculator
How to enter pi on casio fx 300 plus - Casio FX-115ES Scientific Calculator
  • Casio Master
  • 8,073 Answers
Press [SHIF][X10^x]. If it is displayed as the Greek letter Pi, you can still use it as is in calculations.
Please read the manual, it will prove worthwhile.
Posted on Aug 27, 2014
SOURCE: casio classpad 300 plus
install FA-CP1 from disk
COnnect the calc
go to handheld assitant
click install add-ins
choose the game
*games an be found at planet casio, always end in .cpa*
Posted on Feb 08, 2009
SOURCE: Inputing factors on a casio fx-115es calculator
Unless I am failing to understand your problem, just combine like terms to get:
9x^2+2x+4 and then enter those coefficients into the quadratic solver.
That will get you the two answers -- both of them will be complex.
If you wanted to turn those two answers into factors (complex) of the original equation simply
change the signs on each and put an x in front.
Of course, the quadratic formula would also work.
CG
Posted on Apr 28, 2009
SOURCE: how do I enter pi on Casio fx-115es?
Enter your number then press (shift) then (X10x) key. That will enter pi. then press (=) for the answer.
Posted on Jul 05, 2009
  • 8073 Answers
SOURCE: Casio fx-7400G PLUS cubic solver?
First let us repair the terminology.
  1. You can evaluate any expression (find the value of any expression for a particular value of its variable).Store a value in the variable, say X. Key in the expression and press [EXE].
  2. You can consider your expression(should not contain a relational operator such as =, greater than, less than, greater than or equal to, less than or equal to) to be a function Y1(x) = expression and graph it, or generate a table for it. You will have several values of the function calculated at various points.
  3. You can set your expression equal to 0 and find the particular value(s) of the variable (the unknown) that make the equality TRUE. That is called solving an equation.
I am not sure that it has a solver (solving an equation or an inequation) but you can always draw your expression as a function and explore the graph (SKTCH) to locate the roots (or zeros) of the functions (the values of the variable where the function equals zero.) That is called solving graphically.
Hope it helps.
Thank you for using FixYa and for rating this solution.
Posted on Dec 03, 2009
  • 8073 Answers
SOURCE: Problem with Casio FX 260 Calculator
Read the screen capture about the MODES of this calculators. DEG,RAD, and GRAD remind the user that the angle units in trigonometric function calculations and coordinate conversions are in degrees, radians or grads. They have nothing to do with the other calculations you are doing.
You can only remove DEG by changing the angle unit to RADians or GRADs. In so doing, the new unit indicator (RAD, GRAD) will be displayed instead. There is no point worrying about the angle unit indicator unless you are performing coordinate conversions or calculating trigonometric functions or the inverse trigonometric functions.
MODE 9 cancels the FIX display format: decimal are displayed with a fixed number of decimal places (set by the user). After this key sequence the decimal display format reverts to NORM(al).
Posted on Jun 22, 2010
Unable to use pi (instead of 3.14) when using formulas which require pi
If you want to square an expression enclose it in parentheses and raise to the second power.
Jul 27, 2015 | Casio Scientific Calculator Fx-82es Plus
How can you find the circumference of a circle using the FX-ES 115 Plus?
Th formula is PI *dia.
Pi is available on this model using Shift key + X10 key at middle bottom.
So enter Pi then key x (multiply) then enter diameter then = key.
http://support.casio.com/storage/en/manual/pdf/EN/004/fx-115_991ES_PLUS_C_EN.pdf
Nov 10, 2014 | Office Equipment & Supplies
Casio FX-115ES plus decimals to fractions
The display of radicals and Pi is limited. For example only square roots are displayed as roots, standing alone or in some complicated fractions. Pi is shown as Pi, but pi^2 is not. These are limitations you have to accept. So you did not do anything wrong.
Feb 23, 2013 | Casio FX-115ES Scientific Calculator
My casio fx 300 answers questions in exponents instead of decimals, how do i reset this?
Press SHIFT [MODE] then select one of either the "Fix" or "Norm" modes. See page E-8 of this manual.
Feb 10, 2013 | HP Casio FX-300 Plus Scientific Calculator...
How do I enter pi on Casio fx-82MS
Press and release the SHIFT key at the upper-left corner of the keyboard, then press and release the EXP key at the center of the bottom row.
Note that the EXP key has the Greek letter pi printed above it in yellow.
Jan 24, 2013 | Casio FX-82MS Scientific Calculator
How can I revert back to getting answers in pi on the casio fx-85? eg 3/pi etc?
Set Input/Output mode to MathIO.
  1. Press SHIFT MODE to enter SETUP.
  2. Select 1:MathIO
Jun 03, 2011 | Casio FX-115ES Scientific Calculator
I have to multiply by Pi on my exam paper. (I'm wondering where the Pi button is on the Casio Fx-300ES Calculator)?
To insert pi on this calculator press [shift] [x10x] . (you can see the pi symbol above and to the side of this button).
Apr 05, 2011 | Casio fx-300ES Calculator
How do I multiply by Pi. (Where's the Pi button on the Casio fx-300ES)
pi is the shifted function of the x10^x key, middle of the bottom row.
How do I enter pi on Casio fx-115es?
Jul 03, 2009 | Casio FX-115ES Scientific Calculator
Casio FX-115ES Scientific Calculator Logo
171 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
