Question about Xerox Office Equipment & Supplies
MY XEROX 3435 NOISY WHEN PRINTING.... - Xerox Office Equipment & Supplies
  • 790 Answers
That unit does not give you too many maintenance optimums.
Try removing the paper and giving it a good blowout.
Posted on May 15, 2014
How to get rid of black lines on printed documents
The lines are most likely being caused by the toner or the fuser. Try doing a print and as soon as the paper starts to leave the tray open the door and jam the job. Take out the cartridge and pull back the shutter and look at the image on the drum. If the line is there you probably have a bad cartridge. If the line is not there, it may be that there is a 'score' mark on the fuser heat roller.
Aug 27, 2014 | Xerox 3435VDN Phaser 3435 A4 Mono Laser...
What is the problem if xerox 6505 is noisy during operation in the imaging area
This is usually from a worn gear in the transport area. Xerox service call.
Aug 06, 2014 | Xerox Office Equipment & Supplies
Printing autocad
Hi kevin,
Go To Below official Xerox Printer Page For Your problem,
Xerox 510 Series Print System with AccXES Controller serial number HFT... Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For Xerox Printer Support
Mar 07, 2014 | Xerox Office Equipment & Supplies
Xerox 7132 printing dots after 35 pages
Check if it is with just one document or with all documents. Can also be coming from the job and not the printer
Apr 07, 2013 | Xerox WorkCentre 7132 Multifunction Color...
Xerox Phaser 4510 - While printing it makes a squeaking noise
One of two things. The fuser bearings get noisy in those.
Or there are several small hard plastic rollers on steel shafts or even mounted on springs they they can get very noisy.
Feb 24, 2010 | Xerox Phaser 4500/YDX Printer
Which wire is the 'ON-PS' switch for the Astec Model SA145-3435 power supply?
I found out that the AT supply SA145-3435 does not have a switch wire like an ATX supply. I have a SA145-3435 my self. To get it to work it must have a +5 volt load (BLACK and RED) and a +12 volt load (BLACK and YELLOW). If it does not have both of these loads it will power down after a 2 second delay when you plug it up. I used 2 small 12 volt bulbs. One for the 12 volt line and one for the 5 volt line. The type of blub I used was a #94 I got from the auto parts store.
Oct 01, 2009 | Dell 145W Power Supply SA145-3435...
Xerox 8560 outputs Cleaning Pages several times a week. The unit is never turned off and only goes into "sleep" mode. Last time it woke up at 1:00 AM and went through the noisy cycle and output the...
There is nothing you can do about the cleaning page. And if its only using 20% of your ink, you're luck normally its 25% of the ink. This is simply how the machine works. Nothing can be done. The Xerox employee was simply trying to give you something to try, but it won't change anything!
Mar 27, 2009 | Xerox Phaser 8560MFP Laser Printer
HI I M JIGNESh patel i was purchase xerox pe in my printer error is lsu how can i solve it pls send me reply
I'm not sure what the problem is or what machine you are using but follow the link below and enter the name of your machine and then the error message and it should help!
http://www.support.xerox.com/go/prodselect.asp?Xlang=en_US&metrics=HDR
Dec 06, 2008 | Xerox Phaser 8500/DN Printer
Xerox Phaser 7400 printing
Reinstall the latest print drivers. This issue has been resolved previously
Apr 22, 2008 | Xerox Phaser 7400/DXF Laser Printer
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
