Question about Tetra Garden
Tetra filter Leaking after cleaning
After taking apart & cleaning my Tetra filter (>4,000 gallon) & putting it back together. Water comes out of the top. When I took it apart an ''O'' ring came off. Could this be the cause of the leak? Where does it belong? Any advice would be appreciatated!
Terri
  • 21 Answers
Tetra tech support can help you or email you a new owners manual. Call their toll free number 800-526-0650
Posted on Jun 24, 2009
Why will water not flow through hose into the spray gun with the washer not started as well I started the power washer and the water still does not come out.
My Craftsman pressure washer has a filter in the hose tp the pressure wand. I found I must have had some dirt in my garden hose and these filters were plugged. No pressure at all till I cleaned them out.
Jul 04, 2017 | Craftsman 2500 PSI Briggs & Stratton...
What cause the water heater to take more than an hour to heated up and unable to last longer. Usually its take about 15 min. to heat up and can last longer.
'Rheem 81VP15S point of use' is a single-element, 15 gallon, 120V electric.
Other 'point-of-use' sizes range from 2-1/2 to 6 gallon to 20 gallon.
Electric water heaters have 2 parts: thermostat and element. One is not functioning correctly. Most likely the element caused by sediment build-up.
How to determine if tank has element or thermostat problem:
Do not turn off water going into tank. Put hose on drain valve. Open drain valve. Does water come out like open spigot? If water does not flow, then heater is likely clogged with sediment.
Solution 1: If water flows out like a spigot, the thermostat is probably bad. Read: How to replace thermostat.
Solution 2: Water does not flow, so element is surrounded by sediment build-up and cannot heat water. You need to clean out tank with shop vac, and put in new element ... plan full day and 3 trips to hardware store. Simply draining tank will not remove sediment. Sediment is chunky and will not come out voluntarily.
Buy element before starting:
-Turn off electricity
-Open cover on side of tank, remove insulation (these have to be put back for proper operation of thermostat)
-The are 2 electrical parts >>the element and the thermostat which is located above element
-Element wattage is printed on element and also shows on label on side of tank
-I think Rheem element is held in place with 4 hex bolts
-Take photo of element to hardware store so you have part on hand before removing old element
-If element is 1-1/2' diameter hex type, you need inexpensive element wrench from hardware store + the element
Drain tank and clean sediment:
-Read: To open drain on water heater so water comes out
-Read: How to clean sediment out of water heater
Sep 29, 2010 | Rheem 81VP15S Point-of-Use Electric Water...
I have a tetra tec ex700 which is leaking from the sides of the canister.sice last year i have had 3 replacements sent and all with the same fault.can you advise if its the valves leaking into the motor...
I thought i would share my problem as it is known now thatthis filter has leaking problems.
Mine started leaking every time i cleaned it or just switiched it off i triedeverything i could to stop it but i could not.
I found a write up about the leak on the net there was a fault in a large batchwere water would get into the head caseing
and force itself out down the sides of the filter.
well i found the number which is 02380606070 for tetra which is in germany andthey were very helpful and sent me the parts i needed free of charge clip_image001.gifclip_image002.gif
Filter is spot on now no leaking at all hope i help others if the problemshould happen
Sep 28, 2010 | Vacuums
What is the screw or nob in the middle of the intex 530 gallon pump lid for.
That is an air release valve screw. After you fill you rpool with water - open this screw until water comes out then tighten until sealed firmly. Turn pump on.
This allows the air to be released from the pump chamber "priming" the water flow.
Aug 05, 2010 | Intex Easy Set 530 Gallon Swimming Pool...
Water leaking out the top
Here is a copy of the users manual for these pool filters. It has detailed illustrations about how the filter should be put together.
http://www.backyardcitypools.com/images/hayward/perflex-system-manual.pdf
Jun 21, 2010 | Hayward EC-40 DE Pool Filter with pump
Nespresso Essenza D100 leaking water while brewing
Sounds like a gasket or seal gone or a split pipe.
If it's still under warranty - take it back for free service or replacement.
If you do have to attempt DIY, then a clear silicone sealant may save you the price of expensive gaskets.
Be very careful when taking apart - take notes or photos as it will help put it back together !
I usually put related sub-assemblies together with their screws in separate pots.
Aug 11, 2009 | Nespresso Essenza D100 Espresso Machine
Code LC, I cleaned the filter, won't stop beeping
you need to flush out the rinnai. to do this you will need 4 gallons of white viniger & a circulating pump. #1 disconnect the power. #2 close both incoming & outgoing water valves under the unit. #3 conect a drain hose to the out going flush valve ( flush valves are under the unit & have brass caps) #4 connect pump outlet hose to ingoing flush valve. #5 put pump incoming hose & drain hose from outgoing flush valve in a 5 gallon bucket. #6 pour 4 gallons of vinager into the bucket. #7 open both flush valves. #8 turn on the circulating pump & let viniger pump in the incoming flush valve through the rinnai & out the outgoing flush valve back into the bucket for 45 min. #9 disconct pump from incoming side & close incoming flush valve.( don,t close outgoing vaves at this time) #10 put out going hose in empty bucket. #11 open incoming water to flush viniger out of unit. # 12 disconct outgoing hose , close outgoing flush valve & open outgoing water valve. #13 clean filter & turn on power.
Jul 08, 2009 | Rinnai Water Heaters
Water leaking after cleaning filter
Sounds like a washer problem. Either the wrong ones or did you forge to clean the washers before reinstalling them?
Mar 13, 2009 | Maytag MDB6000 Dishwasher
440 Aprilaire Humitifier small solinoid doesn't open
Make shure that the the filter in the bottom of the valve is clean. Turn water off use a 1/2 & 7/16 wrench to take apart the bottom connection on valve use a small screwdriver and push the small screen out and clean then put it back together.Use the same wrenches and take apart the top of valve clean inside valve and clean small orfice in plastic water line put back together. Make shure 24volts is gettin to valve you should her a click when furnace is running or fan. It may take a couple times to clean. Hope this helps
Jan 11, 2009 | Aprilaire 600 Humidifier
Danby Silhouette leaking
check that the removable bucket did not alter a water guide near the cooling fins
Jun 05, 2007 | Danby DDR600R Silhouette Dehumidifier
Garden Logo
506 people viewed this question
Top Tetra Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Tetra Garden Expert? Answer questions, earn points and help others
