Question about Kodak EasyShare C613 Digital Camera
Lense i bent..
Ok, so my lense is like, wobbely.. i guess you would say. and it say's the lense error. I had it fix'ed befor. but it broke and this time it wont go back.. I am really upset!
    Sergeant:
    Champion:
  • 248 Answers
When the camera got damaged
the lens assembly became dis-aligned.
As such, it can't retract.
You can try powering on/off several times,
or if you can, try a reset.
But I'm betting the lens is simply off
the rails a bit. The safe thing is to have
the camera looked at. If there's no
visable impact damage, you may be able
to get it repaired under warranty.
However, if your camera is out of warranty,
or if company refuses to repair it for free due
to impact damage, it may cost more to repair
than it is really worth.
The rule of thumb is that if the estimate
for repair is worth of 50% what you paid
for it, you're better off taking that
money and buying a newer and upgraded model.
The one thing you can try is to If you gently,
and I do mean GENTLY push against the lens
with the PALM of your hand as you turn it on,
it may cause it to depress back into the
camera. If that doesn't work, and you can't
reset it or turn it on/off several times,
then you may have to send it in for a repair
estimate anyway.
Posted on Jul 06, 2009
Rear wheel wobbely
Not enough info here. Is it the rim or the hub that is wobbly? If the rim is out of true (and not actually bent) the spokes can be tightened to bring it back into true. If the hub is loose then the bearings need to be adjusted. Either adjustment can be done by your local bike shop for $10-20. A broken spoke can also make the wheel go out of true, this will cost a little more to fix.
Sep 09, 2015 | Huffy 26 in. Cranbrook Cruiser Bike
Lens repair ef
I doubt it is possible to repair. These lenses are mostly made out of plastic pieces. There is probably something broken and/or bent. Lenses are manufactured with extremely great care. When a lens element is only a millimetre or two out of alignment you probably will get faulty images (flare, unsharp, focus shift, etc).
Take it to a repair shop and have them examine the lens if that's free of charge. Without photo's it is hard for me to judge if its total loss or not.
Jan 02, 2014 | Nikon 18-70mm f/3.5-4.5G ED-IF AF-S DX...
My rear passenger axle is bent how do I fix it
Well. t is hard to say how to fix it without first inspecting the vehicle to see what parts got bent. It is also really hard to guess without knowing what kind of car we are talking about and what type of suspension it is equipped with.
Jun 17, 2012 | Cars & Trucks
1975 buick skylark v-8 fan belt broke off while driving could water pump be bad?
check all pulleys that run on that belt for wobbles/looseness. Waterpump will usually leak before it fails. If no wobbes, replace belt. Could have just worn out.
Sep 03, 2010 | Buick Skylark Cars & Trucks
Problem
which rim are you talking about, the bayonet mount?
Feb 08, 2010 | Nikon AFS Nikkor 2470mm f28G ED Lens
Nikon 18-55 f:3.5/5.6Camera error: no lens fitted or non-CPU lens
Remove lens, clean contacts, reattach lens, wiggle it some to seat contacts.
Dec 18, 2009 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
My camera cybershot dsc-170B fell down and the lens is unable to open fully. so error message comes like "please start it again". Please let me know how can i fix the problem..the problem may be with...
Usually the case gets bent and partially obstructs the lense movement. Look at the front of the camera and does the case opening for the lense apear to be egg shaped. If it does stick a small screw driver or butter knife and bent back.
Mar 26, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Dropped my camera bag & my 17-55mm Lens Now will not telephoto
The best way to get it done right after you drop the lense is send it to NIKON NY . They put the lense on a resolution bench test and it make sure the resolution is great ,. This lense is very criticial and it is a must or your wasting your money . The reason is this ., The lense is a wide angle and sometimes photographers have probelms with 17-55mm lenses and sub mirror problems . So its best to be safe than sorry .
Mar 07, 2009 | Nikon 17-55mm f/2.8G ED-IF AF-S DX Zoom...
Kodak EasyShare C613 Digital Camera Logo
46 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
