Why is there no condensation?? My portable a/c Technitrend model TN09E has been running for several hous , and there is no condensation. And the temp controll is barely droping. Can you plase help o
PLEASE HELP!!!
    Master:
  • 613 Answers
The blower fan may be running, but the equipment isn't removing heat from the space. Apparently the compressor is not working. Don't confuse the noises of the blower motor with a running compressor. Check for cool air at the registers. No cool air = no condensation. Cool air, then check your plumbing from the pan under the indoor coil (evaporator). The drain line could be clogged.
Posted on Jul 11, 2014
3 Suggested Answers
  • 8 Answers
SOURCE: The power has been out
what type thermostat do you have and how old are your components
Posted on Nov 16, 2008
  • 10 Answers
SOURCE: Light flashes red at Portable A/C unit
drain system clogged or condensate pump no good
Posted on Sep 01, 2009
Testimonial: "The condensate pump was jammed and causing the water to rise in the tank and thus safety shut-off of the A/C unit. Freed up pump & cleaned water tray."
How much water do I need for the air conditioner
I've never seen an air condition device that needs to add water to work. Actually they RELEASE condensation water and you need to collect this water or drain it through a tube
Jul 20, 2015 | Sunpentown Spt Tn-12e Technitrend...
Everstar portable air conditioning model number
check for dirty condenser coil the condenser hot air will be very very hot more than 30 degrees higher than what is going in
Sep 12, 2014 | Heating & Cooling
How do I troubleshoot this unit to see why it is not working?
First check the box were the water goes. Not sure if you have a hose going out the window with the plastic hose the air conditioner will not work when the water bucket is full it should have a light on the front of the machine that shows you.
Jul 08, 2014 | Sunpentown TN-09E - Technitrend Portable...
I need a manual for portable A/C Technitrend TN09E
Stick it in a bowl of rice leave it overnight then take it to an iPhone repair place if the rice seams infective
May 15, 2014 | Amana AP076E Portable Air Conditioner
Why is Portable AC is leaking?
Condensate should be directed outside. The condensate collection device may be plugged, broken, missing or not draining (overflowing)
Sep 12, 2012 | De'Longhi Delongi PACA120E 12,000 BTU A...
Refrigerator wont run. Clicking noise coming from main board preceded by a short humming noise every several seconds. Unplug for 30 minutes then plug back in and compressor starts up after several clicks...
That condenser fan motor needs to be replaced. You and doing the right thing as far as using a seperate fan to keep compressor cool,buy replacing the fan the compressor will run cooler and click off by being too hot as you have heard/seen.
Find your model number and call your local appliance parts store and see if they have a CONDERSER FAN MOTOR in stock
Gene
Aug 15, 2011 | Refrigerators
When i run the ac it leaks on the floor from the inside n i dont know what to do about this problem.
All portable or window ac units are mounted or standing with the back lower housing at a slope
so that the condensed water buildup from the evaporator can drain into a tray or thru a tube out
the back of the unit, depending on what kind of unit you have you may have to take it apart and
make sure the drain for the condensed water is not blocked. some times these units are not
installed correctly, they will not drain properly and standing water with time will turn to rust and
clog up the tube where it needs to flow from the ac unit. good luck!
Jul 31, 2011 | Windchaser PACR10000 Portable Air...
Indoor ac units floor models
Buy a condenser coil made for salt air. it will be stainless or copper.
Oct 17, 2009 | LG LWHD1000R Portable Air Conditioner
Heating & Cooling Logo
76 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
