Question about First Years The by Tomy Sway N Soothe Auto-Rocking Bassinet
How to make it sway
Hello I this The First Years Sway N Soothe Auto Rocking Bassinet To sway because mine doesn't work after replacing battery .. And does battery quality matter?
Need assembly instructions on how to put together sway n soothe bassinet from first years ... Now Please about to donate it to Joplin Relief Missions
If you notify sway and soothe bassinet's makers first years, it should have a set of instructions on line to print out..if not call them/email them and get them to send you some. Good luck!
Jun 05, 2011 | Toys
I need a part number for the rear sway bar linkage.
There two an upper and a lower.
lower sway bar link Napa part # 1031355 cost about $75.00.
Upper sway bar link Napa part # 1031356 cost about $70.00.
Jun 16, 2010 | 1997 Mazda MPV
Eddie Bauer Musical Rocking bassinet # 10330
Pain in the **** to find parts for. If you need parts I will sell you some of mine off of my bassinet
Jan 03, 2010 | Eddie Bauer Musical Rocking Bassinet...
Rocks sideways when driving, feel like you are on a boat
Have the shocks/struts ever been replaced? The rocking is normally caused by worn out shocks and/or sway bar bushings. When the shocks go, you normally will experience a rollercoaster type up and down motion when you hit bumps (the springs are bouncing and the shocks are not dampening/rebounding properly). If you do not have this up and down rocking, but just sideways, check your front and rear sway bar bushings for wear or damage to where they connect to the frame. If the mount has broken or come loose, it will not prevent the sideways sway. You should also see a sideways lean going around corners.
Dec 31, 2009 | 2002 Jeep Grand Cherokee
199 dodge caravan
Video: Broken Sway Bar Link Removal & Replacement (Dodge Caravan 96-07 Chrysler Town and Country)
Sep 03, 2008 | 1999 Dodge Caravan
Clunking noise while normally drivin an hitting bumbs or turning right
I don't think that there is a part on your car called the rocking arm. But there is set of bars in the front end called the sway bar. The sway bar helps the car handle correctly and it is critical. I am no expert so I would visit your local dealer or mechanic.
Aug 30, 2008 | 1998 Pontiac Grand Prix
I have a creaking,clunking noise on front passenger side of 91 ford escort
Try looking at the sway bar link on each side. If they move easily by hand then they likely need to be replaced. You can do a sort of self test by rocking the car up and down at the front fender tire well. If you can hear it clicking when you rock it, it is likely that sway bar link. Good luck!
Aug 09, 2008 | 2002 Ford Escape
Replace parts
You can call 1-800-544-1108 to get replacements parts.
Jun 26, 2008 | Eddie Bauer Musical Rocking Bassinet...
Replace parts
call 18005441108 -- they will provide you with any replacement part needed -- just have credit card ready!
May 07, 2008 | Eddie Bauer Musical Rocking Bassinet...
Rocking mechanism doesn't work and can't find replacement parts. There were no instructions included with bassinet.
I have the same problem, the only "function" switches I can locate is the "on/off" switch & volume control for our "rocking Bassinet." Also - no instructions
Feb 10, 2008 | Eddie Bauer Musical Rocking Bassinet...
First Years The by Tomy Sway N Soothe Auto-Rocking Bassinet Logo
Top First Years Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a First Years Baby Gear Expert? Answer questions, earn points and help others
