Question about Garden
My black max 2700psi gasoline powered by Honda pressure washer spray's continuously opon start up, and won't stop spraying. Why?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 165 Answers
Faullty gun, replace trigger
Posted on May 15, 2014
5 Suggested Answers
jmgldsmth
  • 1906 Answers
SOURCE: new Karcher pressure washer won't start
replace the fuel carburetor filter and, or, your fuel tank filter
Posted on Aug 31, 2009
  • 10 Answers
SOURCE: I have the Coleman powermate 2400 PSI pressure
Sounds like the valve in the handle is sticking closed. May have a broken spring, or maybe a part is stuck..
I say take it apart, and the answer will present itself.. Play with it with nozzle out too... Maybe something is stuck after storing so long and will loosen up.. Fingers crossed
Posted on Oct 26, 2009
  • 1388 Answers
SOURCE: pressure washer does not spray consistent flow of pressure
Pressure washers have a pressure regulator/unloader that bypasses the water back into the intake when you let go of the trigger with motor running. If you let the machine run for long preiods in bypass the system could be damaged due to heating of the water being bypassed. The water is in a closed loop. The as the unloader wears it will tend to want to bypass which is what is happening in your case. Dirt trapped at the tip will cause this also. Install clean tip to solve problem. If clean tip did not help then try lowering the pressure by turning pressure regulator counterclock wise. If problem is gone then parts are failing but keep using pump. Good luck.
Posted on Jul 11, 2010
SOURCE: pressure washer - can't figure out soap
Dont use your mouth youll get poisoned, soap will only come out when there is high water flow, ex. with soaper tip (the one with the bigger hole) or no tip. When you have high pressure tip on it will not work.
Posted on Sep 03, 2010
How do I replace the outlet valve on a Honda black max 2700 psi power washer that broke off?
For $290 is savings, I'd work at backing that piece out ... someone has put it on.
Oct 04, 2014 | Honda Black Max - 2700 PSI - Gasoline...
Engine rpm serges sometimes and powernosle pressure drop some times
Gas engine surging and losing power sounds like dirty carb to me.
Pressure washers are often used and then sit for months before being used again. This often creates blockage in carb passages. If you have or install a fuel cutoff valve you can reduce this problem. When you are done pressure washing, turn off the fuel valve and continue spraying water until the carb empties ( the engine will sputter and go out) Next time you want to wash turn on the valve and you should be good to go.
Mar 09, 2014 | Annovi Reverberi Sjv3g27d Pressure Washer...
I bought a new 2600 psi pressure washer. It starts great. The pressure starts out fine. However, when I disengage the spray nozzle lever and then push it again there is along delay before I get any...
Hi. I think the problem may be called either vapor lock or cavitation, or it could be called something else, but the solution is to take the wand apart in the center and let the trapped water escape, then putting it back together before re-engaging the lever.
Sep 14, 2011 | Craftsman 2600 PSI Honda Powered Pressure...
BLACK MAX ACTS LIKE CARB IS CLOGGED BUT GAS AND CARB BOWL FREE..IS THIS AN AUTO SHUT OFF FEATURE? HAVE OIL IN ENGINE AND TRIED WATERPRESSURE AND THEN W/O PRESSURE. -ADVISE?
There could be gunk in other parts of the carb. Id take it off and spray out some of the ports/jets. Be careful of the carb cleaner spraying back in eyes!
Jun 09, 2011 | Honda Black Max 2600 PSI Pressure Washer
I bought a honda pressure washer power boss 3000. I load the gasoline, start the machine, but pressure water is not coming out from the trigger. i tried so many things , but can t get started.
If you are using a water tank for water supply, remove the water supply line from the pressure washer and connect a water hose from a faucet. Turn the water on, then crank the engine. Pull the trigger of the spray gun until water comes out. When then water starts to spray properly the release the trigger, shut engine down with pressure on the line then reconnect the water supply from the tank to the pressure washer. If this fixes the problem then the problem was "air-locked"! Happens alot with new pressure washers that have never been run. If you need any other help, please email me @ davidandlisacampbell@yahoo.com
Feb 18, 2011 | Honda Pressure Washer PSI 3000
Power washer stalls after spraying
Your pressure relief valve may not be working. If that happens when you shut off your spray gun, then pump is dead heading, stopping the motor. If this is the case it stops dead, not coasting. Either replace the pressure adjusting relief valve or remove it, and disassemble it and clean it.
Jul 18, 2010 | Honda Pressure Washer PSI 3000
Honda engine pressure washer won't start
Remove the sparkplug spray isoproxyl (rubbing) alchohol in the cylinder and on the sparkplug this will "dry out the engine" reassemble and, start the engine.
It should start as a "wet with gasoline" sparkplug can not spark nor, will liquid gasoline ignite
May 23, 2010 | Honda 8 HP Engine
New Karcher pressure washer won't start
Aug 31, 2009 | Karcher 2500 PSI Pressure Washer
Power washer problem - water is spraying into my soap dispenser
this can happen if you use the wrong soap, you must use pressure washer cleaner, it does not foam.
Aug 08, 2009 | Psi Blue Max 2200 High Pressure Gas Power...
Gas pressure washer will not start
I have a 5hp honda power washer sat for 2 years it will only run if I spray gas in the carb as soon as I stop spraying the engine stops I have took off carb and cleaned it
May 31, 2009 | Karcher 2500 PSI Pressure Washer
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
