Question about Amana AP076E Portable Air Conditioner
I need a manual for portable A/C Technitrend TN09E
We have had the air running for several hours and their is no condensation. And it is taking a long time for the temp control to drop? Is there a manual I can look at on line? Please help me if you can!!
    Problem Solver:
  • 9 Answers
Stick it in a bowl of rice leave it overnight then take it to an iPhone repair place if the rice seams infective
Posted on May 15, 2014
How much water do I need for the air conditioner
I've never seen an air condition device that needs to add water to work. Actually they RELEASE condensation water and you need to collect this water or drain it through a tube
Jul 20, 2015 | Sunpentown Spt Tn-12e Technitrend...
How do I troubleshoot this unit to see why it is not working?
First check the box were the water goes. Not sure if you have a hose going out the window with the plastic hose the air conditioner will not work when the water bucket is full it should have a light on the front of the machine that shows you.
Jul 08, 2014 | Sunpentown TN-09E - Technitrend Portable...
Why is there no condensation?? My portable a/c Technitrend model TN09E has been running for several hous , and there is no condensation. And the temp controll is barely droping. Can you plase help o
The blower fan may be running, but the equipment isn't removing heat from the space. Apparently the compressor is not working. Don't confuse the noises of the blower motor with a running compressor. Check for cool air at the registers. No cool air = no condensation. Cool air, then check your plumbing from the pan under the indoor coil (evaporator). The drain line could be clogged.
May 15, 2014 | Heating & Cooling
Breaker keeps tripping after several hours of runtime. System has 40 amp breaker & is only drawing 31 amps.
electric motors (when they start to break-down) will run normally for hours (and read amps within the tolerance level).
Then after a long run time - the amps will 'spike' and trip the breaker.
This is a fairly common occurance - although there are other things that can cause a similar problem (though less likely), i.e. a dirty condenser coil, an improperly charged unit - or a bad breaker.
Bottom line. I think you need a Service Tech to take a look at the AC.
hope this helps
Jun 06, 2010 | Haier HC48C1VAR Central Air Conditioner
Amana heat pump cuts off for several hours at a time and comes ba
it sounds like it may be iceing up, it takes awhile to thaw then kicks back in and runs until it ices up again, remove access cover, clean condensers gently and thoroughly, don't bend the fins make sure freeze sensers on condensers are making good contact
Jan 31, 2010 | Heating & Cooling
Windchaser PACRWC-HP Portable Air Drainage Issue
obviously condensate sensor is fault. You may need to replace it. Yes it okey to turn it on now.
Oct 11, 2009 | Windchaser Portable Air Conditioner
No water
If the air conditioner is putting out cold air, don't worry about it making water. You may not have enough moisture in the air to produce more water than it requires.
In some types of air conditioners, the water taken from the air is used to assist in cooling the condenser unit. The excess is run off.
Jerry G.
Jun 21, 2008 | DeLonghi CF210 Portable Air Conditioner
Amana AP076E Portable Air Conditioner Logo
89 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
