Question about John Deere Garden
Why does the crank case fill with gas while the engine is running L110 lawn mower
The crank case fills with gas when the engine is running
  • John Deere Master
  • 2,478 Answers
Your float in your carb. mess-up. May have a hole in it.
Posted on May 15, 2014
Testimonial: "Ive had it apart 2 times now. Blew the thing out good with air. Needle looks good. Float is all plastic, seems to be in fine shape. No adjustment on the float at all. Got to be something some place but just haven't hit on it yet"
  • Dennis Key
    Dennis Key May 16, 2014
    Your fuel solenoid may not working. Installed a fuel shut-off to solve my problem.
  • Dennis Key
    I would install a new float and neddle and seat.
  • 68 Answers
SOURCE: I need to find a repair manual for a craftsman riding lawn mower
SearsPartsDirect.com should have your answers
Posted on Apr 26, 2009
  • 153 Answers
SOURCE: air filter fills up with gas and stalls the mower.
bad fuel pump. Rebuild carborator.
Posted on Apr 30, 2009
  • 413 Answers
SOURCE: engine on riding lawn mower surging
Dirty air cleaner.
Clogged fuel filter.
Replace or clean both...
Posted on May 29, 2009
SOURCE: how do I change the gas tank on my John Deere L110
Howdy, I have a jd L110 automatic with 179 hours on it...some times when starting with the brake held down it will not crank...some times it will... I am not sure if it is the switch on the brake or the starting system...Is there any way with out buying a new switch to wire jump the switch to see if it is in the switch or not? thanx, Dan
Posted on Apr 07, 2010
  • 54 Answers
SOURCE: mower smoking and running rough
Check the gas you put in, it sounds like it had water in it.
Posted on Apr 28, 2010
Eliminate smoke
Drain fuel tank. Fill with fresh and add the correct amount of the correct oil.
Take the old fuel, and add it to your car's tank, it should be diluted enough so your car will be fine.
Jul 07, 2016 | Garden
Hard stating flooding
Search Results
    Rider mower carburetor flooding - help ! - YouTube
    ? 1:30
    https://www.youtube.com/watch?v=ZYqtKvLXYtY
    Sep 29, 2010 - Uploaded by Joyce Boncal
    It won't start. ... Rider mower carburetor flooding - help ! .... ( HOW TO ADJUST VALVES) FIX HARD TO START Lawn Tractorwith OHV Briggs ...
    How to stop a Briggs crankcase from flooding with gas Order ...
    ? 11:34
    https://www.youtube.com/watch?v=VhEiLMtPR5M
    Aug 5, 2013 - Uploaded by doublewide6
    If your tractor keeps leaking gas into the crankcase see how you can fix the problem by ... The hard starting is caused by fuel filling the cylinder.
    Basic Troubleshooting - Lawn & Garden Tractors - Cub Cadet
    cubcadet.custhelp.com/.../basic-troubleshooting---lawn-%26-garden-tract...
    Sep 13, 2002 - Engine fails to start, Engine flooded, Crank engine with throttle in FAST... Engine runs erratic or stalls, Tractor running with CHOKE activated ...
Jan 25, 2016 | Garden
22" walk behind Murray (Wal-Mart)lawn mower leaking gas
Fuel bowl is leaking ? or gas line is bad ?
Sep 25, 2014 | Garden
Excess pressure crank case
Either the crankcase breather is blocked or the engine is badly worn, make sure the engine is not over filled with oil.
Feb 18, 2012 | Briggs & Stratton Garden
Describe your 20 Hp 42"
The float an needle are stuck open causing the fuel to drain from the tank or be pumped by the fuel pump into the carburetor bowl, filling it and flooding the engine and filling up the air cleaner. You may even find that it has gone into the crank case sump contaminating the oil. Do not run until you have repaired the carburetor and changed the oil and if air filter got contaminated, that changed too.
I hope this is helpful for you.
Aug 18, 2011 | Craftsman 20 Hp 42" Deck Lawn Tractor
Gas in the crankcase
THE NEDEL IN THE CARB IS STUCK LET GAS RUN IN AND FILLS UP AND GOES IN TO CRANK CASE
Sep 30, 2009 | Garden
13.5 OHV B&S won't stay running, blows gas out carb.
Check to see if the oil is over filled. check if the oil smells like gas, could be a gas leak into the crank case.
More than likely the head gasket is blown internally, causing excessive crank case pressure
Aug 15, 2009 | Parks Optical 13.5hp Briggs And Stratton...
Poulan 6.75 Lawn mower will not start
Remove spark plug, clean and dry. Replace plug. Remove air filter. Spray WD-40 into carb opening; one second blast. Turn over engine, (pull handle). Engine should start briefly and run for 3 seconds.  If not, you are not getting spark to spark plug. If engine starts, you have a dirty carb and you can buy a rebuild kit from manufacture.
May 02, 2009 | Poulan Pro " Pro" Self Propelled Mower
Do four cicle engines need oil fuel misture
Hi. no oil is needed except in the oil tank. there is a separate oil fill point that you can use for the crank case oil section. no need to mix with fuel on the 4 cycle motor. Oil and gas are separate in this situation.
Apr 05, 2009 | Garden
Garden Logo
100 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
