Need to kknow how to hook cables comm scope sva10prs
Tenma 72-2580 scope I want to hook up the scope to monitor the rf wave form and audio wave form on my ham radio how do I do this
I suspect a small antenna could pick up the transmitter level. And the audio I suspect is from the speaker. That is a level the scope could handle. Solder a couple wires to the speaker or hook the scope leads to the speaker output if it is an external speaker rig. I am also a Ham and have a O scope. 2 Channel 30 MHz Oscilloscope with 8 Color TFT Display
Mar 04, 2018 | Radio Communications
Model # AEY12F7G-A Serial # DV041717093X Which wires go where on the compassitor. Fan-Herm-Cool
It is Comm.---- Herm. and fan....
The comm hooks to the incoming voltage... the fan goes to the condenser fan and the Herm. goes to the compressor... there should be a wiring diagram right on the inside of the cover...
heatman101
May 03, 2011 | Heating & Cooling
Dear all. We use twin modem V.3266 of Motorola to connect data from PLC A&B to SCADA via fiber optic cable and Mux (NEC 6000), but now two modem are usually display training status, and data don't...
Hi Mr Q,
You would need a big check-up on:
1. PLC (Comm card - Prosoft ?)
2. Modems
3. Multiplexers
4. Optical Cables
5. RS232 Cables
6. Comm Port Spliter (MOXA?)
7. SCADA System (Oracle Database ?)
Please let me know your above check-up results so I provide further help.
TBT
Oct 26, 2010 | Arris V3229 (6209526200030) Modem
Fax comm error 232 problem
Hello sir ; Why don't try to replace a phone cable or check the wall jack.
Aug 28, 2009 | HP LaserJet 3050 All-In-One Printer
Need help hooking up pin pad
Simply plug the PIN pad cable into the comm port on the back of the terminal marked with a PIN pad symbol. As far as programming, has this PIN pad been injected with the proper encryption key? If you bought it right off the shelf, you will need to send it to your payment services provider for key injection.
Jun 24, 2009 | VeriFone Omni 3700
System will not connect
check the comm cable between the computer and the device make sure that all settings are correct like address, baud rate, comm port connection, and their may be a setting that controls how long the device will attempt to connect this needs to be disabled.
Jun 06, 2009 | Lorex 4 Channel Business & Home Security...
Compaq UPS R3000 XR Comms cable
Hi Jon,
so we could use this link it as a solution for your problem?
http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?lang=en&cc=us&prodTypeId=3447589&prodSeriesId=255222&lang=en&cc=us
Kind regards,
noris017
Feb 25, 2009 | Compaq UPS R3000 XR UPS System
Engine comm error
reconnect your usb cable to printer to computer.then also try tochange that usb cable if pro remains.
Feb 09, 2009 | HP Color LaserJet 2600n Printer
ETX-125 Autostar controller not working
I assume the small red light on the power panel is ON. ???
If it is the scope is receiving power--- check to make sure the cable from the hand controller is plugged in properly-- jiggle the cable to see if you have a loose BAD cable. Before you panic --- try another cable or reverse the ends ---
Before you buy another hand controller try a new cable-- scopestuff.com sells a nice long flexible one for the 497 hand controller.
Jan 14, 2009 | Meade ETX-125EC (500 x 127mm) Telescope
Protron HDTV Cable hook up
if u want true hdtv buy a samsung 1080P LCD
Nov 11, 2007 | Intel VOICE D41JCTLSEURO PFU CT LSGS Comm...
22 people viewed this question
k24674
jasbo
jasbo
