Question about 2005 Suzuki XL7 - With factory rails - Base Rack System
What would cause the steering to feel like it's sticking when turning to the right in a curve?
What would cause the steering to feel like it's sticking or a rubber band feeling when turning to the right? It seems to do it more when going straight for a bit then turn to the right in curves or whatever, I also checked the power steering fluid and it's full, does anyone know what it could be?
    New Friend:
  • 15 Answers
Under-inflated tyres. Pump up your tyres. Another thing is it could be is out of alignment. So, it might need a wheel alignment. While getting a wheel alignment, have the mechanic check the suspension bushes and control arm bushes.
Posted on May 15, 2014
What would cause the front suspension of my 4x4 to feel like it is riding on the edges of the tires going around a curve and constantly moving steering wheel from side to side?
I'd have a few things checked out by a pro since it sounds like this can be dangerous. 1st is your front Sway bar and bushings, have your rack and pinion checked out by a pro. Also check your wheel hub bearing assemblies. Final thought, make sure your 4wheel drive is NOT engaged, should be in 2 wheel hi. If in 4 wheel drive while on pavement, all turns will feel squirley and isn't good for your drive train.
Nov 12, 2015 | 2004 Chevrolet Blazer
1992 lexis car replaced thepowersteering pump now it won't turn at all
bleed power steering with engine off pour power steering fluid in the power steering reservoir until fluid stay at full mark on powersteering pump dip stick.wait few minutes then check powersteering fluid again if low add little more when fluid level stop dropping crank vechicle turn steering left to right with out a stop turn steering wheel all the way to the left to all way to right for minute until air bubbles leave the powersteering fluid. when steering wheel feel normal stop engine check check power steering fluid should be at full hot mark if fluid level dont drop air is out the system. dont overfill powersteering reservoir if so you will blow front seal.dont drive vechicle if steering dont feel normal have vechicle towed in garage.
Sep 15, 2012 | Cars & Trucks
I believe It is NOT a tire problem or an alignment problem. It is a gear problem, somewhere in the steering system. It also not the steering box, we replaced this already. There are other gears, like the...
There's a pressure sensor in the power steering pressure line, this sends info to the PCM. Find and unplug the electrical connector to it, some times these fail and send bad info to the PCM and affect the feel to the steering. If that seems to control the symtoms, replace the sensor or leave it disconnected [ the steering will be stiff when low speed turning if left unplugged ] .
Jun 28, 2011 | Chevrolet Suburban 1500 Cars & Trucks
Cannot get my power steering pump that I replaced to stop foaming. I cannot get the air out of the system
CHECK POWER STEERING FLUID LEVEL.SOUND LIKE ITS VERY LOW CAUSING CAUSING MORE AIR SYSTEM.WHICH WILL CAUSE FOAMING.LET VECHICLE SET UNTIL AIRATED FLUID SETTLE DOWN.TURN STEERING TO THE LEFT.CHECK POWER STEERING FLUID LEVEL.ADD FLUID TO COLD MARK LEVEL ON DIP STICK.CRANK UP VECHICLE.TURN STEERING WHEEL LEFT TO RIGHT WITH OUT STOPPING SEVERAL TIMES.THEN CHECK POWER STEERING FLUID.DOING THIS BLEEDS AIR OUT OF THE POWER STEERING SYSTEM.
Jun 19, 2010 | Cars & Trucks
Very hard to go into corners, it seems to fight me while I want it to go into curves.
If the problem is that when you turn the handlebars you feel as if it is almost locked into wanting to go straight your steering head bearings are dented and need replacing.
The denting happens when the steering head bearings not adjusted and loose causing hammering effect denting the bearing races.
May 28, 2010 | 2006 Yamaha MT-01
Feel shake in the floor and steering wheel at around 70 mph and a slight turn on the steering wheel you can feel it a little more. what parts could cause this? already had the wheel balances checked.
Tierod ends. Bad belt in a tire. If you have a bumpy brake pedal, a warped rotor has enougn play to bounce against pads. Also Hub bearings were known to fail after 35,000 miles.
For Hub bearings there may be a Service Bulletin, but your vehicle is going on 10 years old. Usually the side that shakes the most on a opposite curve is the problem side. As in left curve the outside right tire is spinning slightly faster, right side curve its the left side spinning faster.
May 26, 2010 | 2001 Mercury Mountaineer
Where s the power steering top up resivoir on my honda civic 1400 imagine??
Follow your fan belts. One of the belts operates the power steering unit. The resivor should be right there with the power steering unit. It is best to check the level when motor is cold. If it has gone completely dry then you will need to get the air out of it after adding fluid. To do this you add the fluid then turn the steering wheel all the way to the right and then back to the left several times. After the steering wheel feels smooth while turning it then you are good to go. Recheck the fluid first after you have turned the steering wheel back and forth and top it off to the mark on the level stick. Hope this helped, raz
Apr 18, 2010 | 2003 Honda Civic
Help me please.... i bought a used toyota 2004 4runner v6 chain drive 4x4 last year (2009) around june... it has 50/50 tread left on Michelin AT or CT tires. the problem is: whenever i am driving...
CHECK POWER STEERING FLUID IT COULD BE TOO LOW.OR YOU HAVE INCORRECT TIRE PRESSURE.LACK OF LUBRICATION AT STEERING JOINTS.YOUR FRONT END OUT OF ALIGNMENT.YOU COULD HAVE A FAULTY POWER STEERING PUMP.OR YOU HAVE A LOT OF AIR IN POWER STEERING SYSTEM.YOU HAVE TO BLEED AIR OUT OF POWER STEERING PUMP.CHECK POWER STEERING PUMP HOSES.MAKE SURE.NONE ARE LEAKING OUT FLUID.
Jan 14, 2010 | 2004 Toyota 4Runner
When I put my key into the ignition, key won't turn, it's too strong and feels like it's locked. What could be the cause and what can I do to start it up again?
try this take the steering wheel and turn it slightly to the right or left and turn the key at the same time. repeat several times. sometimes the locking detente in the steering column either sticks or gets jammed. this should solve the problem. please rate this....thanks
Sep 26, 2008 | Mitsubishi 3000GT Cars & Trucks
2005 Suzuki XL7 - With factory rails - Base Rack System Logo
56 people viewed this question
Top Rhino-Rack Vehicle Parts & Accessories Experts
Shaun Thompson
Shaun Thompson
Bill Boyd
Jerry Ross
Jerry Ross
Are you a Rhino-Rack Vehicle Part and Accessory Expert? Answer questions, earn points and help others
