Question about Mitsubishi WD-73733 73" HDTV
Flashing yellow lamp light on a mitsubishi 73" television
  • 1153 Answers
SOURCE: Replaced lamp and now can't get a picture
Hi Sally Jo, Unit powers on and works properly for a while then shuts off with a red lamp LED (lamp error). Suspect bad lamp part # 915P020010 2. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 3. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 4. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 5. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 934C148001. Hope this helps!
Posted on Sep 18, 2007
Slinteriors
  • 8617 Answers
SOURCE: Steady Yellow Lamp Light on Mitsubishi WD-52628
no its just indicating that the lamp is reaching the end of its lifespan,
Posted on Mar 15, 2009
  • 58 Answers
SOURCE: Mitsubishi WD-52525 52-inch DLP HDTV ywllow warning lamp light
that means your lamp it is getting to the end of its life.
sometimes even if the lamp still good the TV will send you that message because that timer is closed to 5000 hours
What you can do is open the lamp door, closed again and the tv will ask you if you replaced it the lamp, and just say yes and that sign will go away
or just simple replace the lamp. 915P020010
Posted on Apr 18, 2009
saidneurot
  • 128 Answers
SOURCE: Mitsubishi WD-73733 73 in. HDTV
Could be the ballast of your tv please check our web page so you can find it http://www.discount-merchant.com/
Said
Posted on Dec 18, 2009
SOURCE: I have a Mitsubishi WD 52628. I replaced the tv
try turning it on hold the menu button for eight seconds menu pops up try reseting the settings again as before you had the problem
Posted on Feb 10, 2010
I have a mitsubishi 73 inch tv model WD-73738. No picture with sound - why is this ?
sounds like the psu. power supply unit. check the caps are not bulged
May 17, 2014 | Mitsubishi Televison & Video
I have a blinking yellow status light on my mitsubishi 73837
blinking yellow indicates no lamp or the lamp door is open. if you had the back off you may have gotten the door switch aligned improperly. the door switch is located just inside the lamp door.
the lamp may also be bad.
lamp part# 915B403001
see website:
http://www.shopjimmy.com/dlplamps?tv_brands_select=Mitsubishi&tv_models=Mitsubishi+WD-73837
Apr 29, 2014 | Mitsubishi WD-73837 73 in. HDTV
I am having issue with my TV it won't turn on and I have a flashing red status light keep flashing can anyone help
Hi, if your tv is between 1-4 yrs old and havent replaced the lamp it might be time to do so.Mitsubishis uses Osram lamps to light up the screen and tend to last from 3000-4000 hrs normally 1-3 yrs.The Red light indicator usually indicates its time to replace the lamp.Heres the lamp you would need http://www.discount-merchant.com/Mitsubhishi-915P027010-915P027A10-Replacement-p/mitsubishi-915p027010-lamp.htm?1=1&CartID=0 On the same link it shows you how to replace it ,have a blessed day.
Apr 18, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
Television is making clicking noise after repalceing lamp
You need to leave a lot more information than that.What is the background of replacing the lamp? Where is the clicking noise coming from? Is the lamp light flashing, etc.? My current best guess is that your ballast may be bad, but more info is always helpful in diagnosing a problem. Good luck.
Mar 25, 2011 | Mitsubishi WD-73734 73" Television
I have a Mitsubishi 73" TV model number WD-73735.
Try replacing the thermal sensor. Located behind lamp in lamp housing shroud.
Jan 18, 2011 | Mitsubishi Televison & Video
I'm sorry, but your looking at an Optical Block Assembly which also includes the DM module. Latest figures are approximately $650.00 to replace. I would have called a service tech out to properly diagnose the problem first. Please let me know if you have any other questions.
Jan 18, 2011 | Mitsubishi WD-73735 Television
Jan 23, 2010 | Mitsubishi WD-52628 52" Projection HDTV
Mitsubishi WD-73733 73" HDTV Logo
14 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
