Question about Boating
My yamaha 25hp 99 model 2 stroke outboard started making a clicking sound
Started making the clicking sound while I was cruising along in the water. Lost almost all power and had to drive to the boat ramp at a very slow pace as that's all it could do. Suspect lower unit damage?? Any help with identifying it and is it hard to remove and inspect damage. Photo is not my outboard as I am not at home writing this
    Sergeant:
  • 456 Answers
Do compression test if it lost power,sounds like crank bearings.if ok check gearbox oil for metal filings,gearboxes normally don't make funny noises
Posted on May 15, 2014
  • andrew macdonld May 23, 2014
    Did compression test. Too cylinder 135psi bottom cylinder 35psi. Is it hard to check the crank bearings or check the pistons or rings?
    New Friend:
  • 4 Answers
What condition are the plug wires in ? i would run it with the cover off and see if you are losing spark from a plug wires or coil sometimes when the coil breaks down or the plug wires you might hear a clicking sound when it sparks . just a thought?
Posted on Jun 06, 2014
  • andrew macdonld Jun 07, 2014
    I'll try but the plugs appear to be fine. No compression is the big issue. Hoping it may be a reed valve or somethibg
Yamaha 40 hp outboard
Look below lower mountings you will see the shift rod with along nut and a lock nut,undo long nut,do this with motor in reverse gear,some 40s have a stainless plate cover which you have to remove first
Aug 18, 2014 | Clymer Marine Maintenance and Repair...
Yamaha 50 outboard bogs at hi speed
Make sure carbs are clean,check exhaust tube isn't blocked,check resistance readings on charge coil,make sure filters are clean,no fuel leaks in fuel line,tank has open breather,fuel connector not blocked.if this doesn't solve the problem could be faulty cdi unit
Sep 25, 2013 | Clymer Marine Maintenance and Repair...
Yamaha u7e 1974 how to adjuster carbureteor
Hi, Steve for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
How to adjust air mixture screw jet on yamaha 20hp 25hp 2 stroke outboard...
Pilot Air Fuel Screw Adjustment Explained
Yamaha U7E Motorcycle Repair Guide eBay
OEM parts for Yamaha
Yamaha U7E 1972
Aug 15, 2013 | Yamaha G5 Motorcycles
1982 55 yamaha outboard ,water not coming out the water pump hole in strenght
First thing to check: Disconnect the tiny hose between the check outlet and the engine. Disconnect it at the engine side.
With an airgun, blow in the check hole from outside to engine side.
With an airgun, blow out the engine connection.
Start the engine, check waterflow out of the engine connector. If water, reconnect the hose and check the water at the checkpoint.
If still no water at the engine connection: replace the impeller!
Mar 28, 2013 | Clymer Marine Maintenance and Repair...
At speed and then a loud buzzer sounds inside the hand throttle box
this tells you there is a problem with cooling or lubrication ! what engine you got ?
Dec 21, 2012 | Clymer Marine Maintenance and Repair...
2003 yamaha 25hp. outboard four stroke no spark at plug how do u check coil and control modgul
Hi Drxxxxa, for more information about your question please visit the website below. Good luck and have a nice day.
DOWNLOAD 25HP Outboard Repair Manuals
Jun 14, 2012 | Motorcycles
Boating Logo
87 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
