Repair m-audio bx8a monitors - Audio Players & Recorders
  • 3,368 Answers
What are you tying to repair, the case, speaker, etc.??
Posted on Jun 18, 2014
2 Suggested Answers
SOURCE: M-audio Bx8a's one monitor very low volume compared to other.
NO, I HAVE HAD TWO PAIRS OF THESE SPEAKERS. tHE SECOND PAIR I HAD FOR TWO WEEKS AND SAME PROBLEM, EITHER LEFT OR RIGHT SIDE GOES OUT.
I Insert a compressor on the stereo buss to protect the speakers from transients and they just loose the woofer everytime.
They cannot be trusted, DONT WAISTE YOUR MONEY.
Sam J.
Chief Audio Engineer
AudioWorkShop Studios
www.audioworkshopstudio.com
Posted on Jan 30, 2010
Hi i have a set of bx8a and one of them when it is on the woofer pumps out uncontrollable even when no music is playing please help
If the woofer is motor boating....going in and out, like a flutter,
likely a power supply issue on the power amp board, in back of the speaker. This would need to be repaired. Since these are powered speakers, if for example, a power supply capacitor were bad,
it can do that. If under warrantee, find an authorized repair center near you. Contact manufacturer.
Hope this helps.
Nov 26, 2014 | M-Audio Bx8a Deluxe Power Studio Monitors...
M audio studiophile BX8a deluxe has very hot back panel when on after a few minutes
There is a problem with the amplifier internal to the unit, most likely from the main power transformer. Return to the place of purchase, or a service center for repair/replacement.
Jun 27, 2011 | M-Audio Studiophile BX8a Speaker
I have recently purchased a set of M-Audio Studiophile BX8a Deluxe studio monitors. I can't register them for warranty because I can't find any serial number on the monitors or box that they came...
Call M-Audio and ask them about it... It is POSSIBLE that your speakers are counterfeit. It has been happening with high value audio equipment. There has been some failures of this product as well. Also contact the company you bought them from. There is a lot of grey market stuff on Ebay... I hope that wasn't your source.
May 30, 2011 | M-Audio Studiophile BX8a Deluxe active...
I HAVE THE M-AUDIO SP 5B MONITORS AND ONE OF THEM WON'T THROW OUT ENOUGH POWER TO PUSH THE SPEAKER WITHOUT MAKING A BUZZING DISTORTED SOUND. IT'S NOT THE SPEAKERS BECAUSE I TESTED IT ON THE OTHER SPEAKERS...
It sounds like the speaker might be "blown". If you take the cover off... looking at the speaker, does the speaker's cone have a crack? Or is it separated around the edge... if so, it is blown. Most of the time this can be fixed... but you will have to take it someplace.
Is there a company in your area that professionally installs car audio systems? If so, they usually can repair speakers, or they will know who can.
Mar 02, 2011 | M-Audio Studiophile BX8a Speaker
I have a pair of m-audio bx8a deluxe monitor speakers. I need to know how hook my iPhone up to them or just one of them. I tried using a adaptor and plugging into the trs input but the music is distorted....
The conection you made is not quite right. This is because the TRS (and the XLR) connectors at the back of the BX8a are for balanced signal. You have to use either this cable or connect both middle and ground point of the TRS connector at the ground. In other words the ground from the ipod must be connected with ground AND middle ring of both BX8a and the ring of the ipod must be connected with on BX8a TPS tip and the tip of the ipod must be connected with the other BX8a tip. I don't know if you are familiar with soldering connectors, in this case post me back to make a schematic for you with the connections.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Feb 17, 2011 | M-Audio Studiophile BX8a Speaker
Sam J.
Jul 29, 2009 | M-Audio Studiophile BX8a Speaker
BX8A studiophile monitors distortion problem
it could be a loose connection or the cone is cracked inside , the only way to find out is to open and take a look inside ,check the connections , the 2 wires from box to speaker, ALSO CHECK where the cone meets with the magnet , hope this helps AJ
May 14, 2008 | M-Audio Studiophile BX8a Speaker
Audio
Sounds to me like the voice coil is damaged. But without hearing it I wouldnt be able to tell you. If the voice coil is damaged there is no way to fix it.
Mar 07, 2008 | M-Audio Studiophile BX8a Speaker
Connect BX8A speaker to PC
Hello waddragon,
First, let's start with the BX8a. Those are powered speakers (built-in amplifier in each) so, you do not need a pre-amp. What you need to connect them to your computer is a 3.5mm to XLR cable OR a 3.5mm to 1/4" TRS cable, also known as 3.5mm to two 1/4" mono plugs (the back of the BX8a has inputs that accept either type). Cables are available at most any electronics stores. Make sure you buy a long enough cable to run from the back of the computer to where the speakers will be.
It sounds that you only have one BX8a which means you'll be listening to only one channel of the stereo output. In any case, make sure before connecting the speaker(s) to the computer that speaker power is off and volume control is at minimum. Connect the 3.5mm cable end to Line Out 1 jack of the X-Fi sound card and either the XLT or TRS ends to the speaker(s) input(s). Play some audio content on your computer, turn on speaker(s) and slowly increase volume to a safe level. Everything should work fine.
Let me know how it goes.
cancerags
Dec 28, 2007 | M-Audio Studiophile BX8a Speaker
46 people viewed this question
 Grubhead
Grubhead
