Question about PSB Image 4T Speaker
Where can I purchase a PSB Image 4 tweeter replacement?
M-Audio MX8a tweeter - Where can i purchase a replacement?
You may not find an exact match, but you should be able to find a suitable replacement that is the correct size and impedance from SimplySpeakers.com :
Replacement Speakers
I would recommend replacing both L & R tweeters, especially if its not an exact match replacement.
Jan 19, 2015 | M-Audio Studiophile BX8a Speaker
Where can I source a replacement tweeter for cerwin vega e-712
the exact replacement tweeter can be purchased from midwest speaker company
google it
Sep 27, 2012 | Cerwin Vega E-712 Main / Stereo Speaker
Harman Kardon Soundsticks III repairs
I've juste purchased a brand new Harman Kardon soundstick 3 and one of the tweeter isn't well fixed (its loose inside)... how can I open the tube and replace the tweeter in its position?
Tanks!
Jan 11, 2012 | Audio Players & Recorders
My aftermarket speakers (4) in my truck are acting up. # out of the 4 aren't putting out any sound except the highs from the tweeters... No rips or tears, what is going on? I believe they are DS...
sounds like you have blown tweeters in your kicker speakers. Depending on how loud you play them, this can occur. For your next purchase, I recommend components. They are usualy made better and have individual speakers for separate frequencies. Good luck
Sep 02, 2011 | Kicker Car Audio & Video
Polk rti6 tweers blown...4 speakers.....can these tweeters be repaired
It may be possible to have the tweeters repaired by Polk however if you have the skills your least expensive route would be to replace the tweeters and install them your self. I would recommend using the internet to find replacement tweeters either through Polk or possibly Ebay, or Amazon. Each tweeter has 2 wires that must be removed before uninstalling. Note the polarity and where they connect. red is + POSITIVE , BLACK IS - NEGATIVE
Apr 15, 2011 | Polk Audio RTi6 Main / Stereo Speaker
Hello again. Sorry to say my knowledge is lil... I want to replace stock deck. Here is the stuff i want to put in it. Could you take a look and give an opinion if maybe i cant get away without putting a...
ok as for the deck just get the wiring harness for your car so you dont have to cut the old one out and that would eliminate the need for a wireing diagram with that done you should be able to hook all speakers you want to the stock spot so for a tweeter just hook it up with the door speaker there arnt any extra cords....you will only need a amp for a subwoofer unless you choose to put your mids and highs on one and if you didnt want to change your deck hook up the tweeters would be the same way hope this helped
Mar 30, 2010 | Car Audio & Video
Defect woofers
If you can get the same woofers, then yes you should be OK, pull the units, get the part number off the back and then try Google for a source.
If you can't find a exact replacement then you are looking at replacing all of the woofers, rule of thumb is that you do not want to mix speakers, you end up having one speaker sounding different than the other, so what ever you do to one, you need to do to the other. In that way what tonal changes that happen will happen to both speakers and they remain matched.
Now if you need to find replacements, you need to replace with like impedance speakers, and try to find a speaker very similar to what you are replacing. Just don't throw anything in the cabinet, if the impedance isn't correct not only the sound could be bad, but you could also damage your Amp or Receiver.
john
Aug 17, 2008 | PSB Image 4T Speaker
Wharfedale Modus One
The tweeters are probably blown, i had the same problem.
You can test this by placing the cable on the dismanteled crossover at the back of the speaker. colour blue/yellow.
No high volume please.
See http://www.hometheatershack.com/forums/diy-speakers/4549-wharfedale-modus-one-six-crossover-pics.html
for pictures.
If the tweeter is blown it can be dismanteld with the aid of a screwdriver, horizontally.
Place it between the tweeterbowl and the ring which has the mark wharfedale on it. The tweeter comes loose. On second hand sites you can buy little speakers, like modus one or two's with the same tweeters for a good price and put them on your larger speakers.
This how i repaired 2 of my 4 modus eights.
good luck Danny Mol
the netherlands
Jan 15, 2008 | Wharfedale Modus One-Six Speaker
PSB Image 4T Speaker Logo
67 people viewed this question
Top PSB Audio Players & Recorders Experts
Andrew Taylor
Andrew Taylor
Terry Weaver
Terry Weaver
Are you a PSB Audio Player and Recorder Expert? Answer questions, earn points and help others
