Question about Cell Phones
If i turn it on , it works for 10 seconds then if turns off.
I have to take the battery off and put it back in and it works.Then it shuts of every 10 seconds. well last night i left it on the charger till 10:00 in the morning
  • 389 Answers
You have to test another battery on the phone, it seems like you have a defective battery.
Posted on Jul 04, 2009
My laptop shut down won't turn on it blinks 3 times then nothing
remove all power and battery the hold power button for 10-15 seconds to remove residual power then try power only no battery if works put battery back in reboot. this has worked for me after major bug removed.
May 22, 2016 | Computers & Internet
Battery not recognised/not charging
Turn the computer off, unplug it, take the battery out. Then hold the power button down for 10 - 15 seconds. Plug the ac adapter back in, but do not put the battery in yet. Boot the computer, then shut it back down. Put the battery back in then boot it again. It should recognize the system now.
Jul 31, 2014 | Sony VAIO VPCEA36FM/W Laptop
Toshiba laptop satellite L645D-4040 keeps shutting down
does it shut down and then just start right back up? If it does then press and hold the power button and make sure it shuts down all the way. Then take the battery out and press and hold the power button after the battery is out for about 5 seconds. Then let it sit like 10 - 15 seconds. After that put your battery back in and turn it back on and see if this solved your problem. I think its in a loop to make it keep restarting. Let me know if this helped. Thanks, Herb Stacey
Oct 04, 2013 | Computers & Internet
Mazda rx8 flooded .brakedown come tried to start engine turned over !then starter got hot ,now dosnt turn over just clicks? any wdvice please
Your problem is common in the RX-8. It occurs when you start a cold engine and shut it off before it reaches normal operating temperature. If your car does flood, you can first try depressing the accelerator completely and holding it (which shuts off the fuel pump) and then crank the motor for about 10 seconds (not longer or you may damage your starter). If this procedure above does not work, here is the technique a Mazda dealership will normally use (to be performed at your own risk): 1. Use jumper cables to connect to another car battery. 2. Unplug Air pump connector (the black circular motor housing to the left of the oil filler cap) 3. Take fuel pump fuse out (number 22, a 20 amp, 3 from the top of the second column of the fuse box 4. Crank for 4 seconds, pause for 2 seconds, repeat for about a minute 5. Leave for a minute 6. Crank for 4 seconds, pause for 2 seconds, repeat for about a minute 7. Put fuel pump fuse back in 8. Crank for up to 10 seconds, if it catches but doesn?t start, stop cranking 9. If not started go back to step 3 10. If started, wait 30 seconds for oil pressure to rise 11. Stand on throttle until white smoke stops coming out of the exhaust 12. Disconnect jump leads 13. Leave to warm up on idle for a few minutes 14. Put air pump connector back on (see note 3) 15. Go for a nice long drive to recharge the battery
Dec 27, 2009 | 2004 Mazda RX-8
When i press power, lights and fans come on for 2 seconds, shut sompletely off, then about 10 seconds later, they do the same thing, over and over again, but the computer will not turn on/boot
take out the battery and the mains, hold the on button for 30 sec's, plug the mains back in while holding the on button and it shud *** on... put battery back in when fully loaded up....
Happened to a friends hp laptop and i found this simple fix, should work...
Gerard
Jul 29, 2009 | HP Pavilion DV6700T Notebook
Flashing on and off problem
hi..
Take theb battery out and put it back in.. that will fix ur problem for sure....
rate me.
Jul 21, 2009 | Aiptek A-HD 720P Flash Media Camcorder
Car starts run's 3 seconds shuts down
Your car is equipped with a system called PASSKEY standard on all GM cars and light trucks, try the following procedure to reset the system, the battery being dead will trigger the system.
PASSKEY LOCKOUT RESET GM CARS 1999 UP
1) Put the key in the ignition and turn to the "ON" position. Leave it that way for 10 minutes. After 10 minutes turn the key and take it out. Repeat this process (2) more times (3 times, 30 minutes total) This should reset the passlock system to recognize your key.
Mar 30, 2009 | 1999 Pontiac Sunfire
Won't turn on... just keeps flashing
Either the contacts to the battery aren't lining up correctly or it just needs a new battery. OR the charger isn't charging the battery.
Jan 30, 2009 | LG VOYAGER VX10000 Cellular Phone
Shuts off after turning on
Try changing out the batteries or charging the camera,also with a digital camera they will kill ordinary alkaline batteries I suggest using e titanium
Dec 25, 2008 | Fisher Price Fisher-Price L8341 Digital...
Car stuck in idle
Trying disconnecting the battery again this time for 10 to 15 minutes. Then reconnect and see if it clears the problem.
Nov 28, 2008 | 2003 Mitsubishi Diamante
Cell Phones Logo
Top Cell Phones Experts
Marvin
Marvin
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
