Question about Akai PDP4273M Television
How to get the volume down from 100%. It's stuck and reset button doesn't work
The volume button won't turn down. It's stuck at 100%. When I turn the tv on it has fine, colorful lines going across it for about 4 minutes before the picture kicks in.
3 Suggested Answers
IrishDruid
  • 2712 Answers
SOURCE: Volume stuck in 100% flashing
Since this is a digital LCD TV, there is no question of any button being "stuck". It is most likely an issue with the circuitry. You can try a hard reset first, which is the basic step. Unplug everything, including cables and power supply, wait about 1/2 hour and replug everything. Should the hard reset work, well and good. If not, you will have to take the TV in for servicing. I do not recommend a DIY if you have no prior experience, as there are very sensitive parts within.
However, if you would like to try a DIY, you will first need to get your hands on a service manual. I recommend the following site:
http://servicemanuals.vstore.ca/
They also help you procure the needed parts and provide free diagnostics and help while you repair the set online (provided you buy the manual from them, of course)
Hope that helps! If there is anything further I can assist you with, please let me know. If you are satisfied with my response, kindly take a moment to "ACCEPT" my solution.
Cheers!
IrishDruid
Posted on Sep 08, 2008
  • 267 Answers
SOURCE: Volume Control
check the up volume button on the set. it sounds like it is stuck in the on position. You can open the back and disconnect the wire harness to the control buttons. This will verify if the volume up button is the problem.
Posted on Feb 11, 2009
I have samsung galaxy I. my phone was turned off and when i turn it on it doesn't start as it stucks on samsung and doesn't start up. i took off the battery off and on but it still not working
hi,
try to hard reset your phone first by doing this procedure...
To Hard Reset Samsung I9000 Galaxy S
1. Turn the power off. If your Samsung Galaxy S is frozen, pull the battery out and reinsert it
2. Hold the Volume Down button
3. Press and release the Power button
4. You are now presented with a menu that allows for Fastbook, Recovery, Clear Storage, and Simlock
5. Select Clear Storage by pressing the Volume Down button
6. Press and release the Power button
7. Now simply confirm your decision: Volume Up for YES and Volume Down for NO
If YES is selected, all data including third-party applications will be deleted from your Samsung I9000 Galaxy S. Once the wipe is complete, the phone will reboot to its factory fresh state.
if you do the above procedure and nothings happen ,its time now to re-flash your phone to its original version and a certified mobile technician will do that for you...thanks for trusting fixya
Oct 01, 2012 | Samsung Galaxy S GTI9000 Smartphone
Htc inspire 4g stuck on lock screen and won't unlock
Please note that all data will be deleted from the HTC Inspire 4G as a result of this procedure. This process may or may not delete data stored on the microSD card. We recommend backing up all of your personal data before proceeding.
First, try this:
  1. From the main home screen, tap menu
  2. Tap Settings, then Privacy
  3. Tap Factory data reset
  4. Tap Reset phone
  5. Enter your password if required, then tap Erase everything to confirm
If that doesn't work, or if your phone is frozen:
  1. Turn the power off. If your HTC Inspire 4G is frozen, pull the battery out and reinsert it
  3. Press and hold the Power button until the device turns on
All data including third-party applications will be deleted from the HTC Inspire 4G. Once the wipe is complete, the phone will reboot to its factory fresh state.
Aug 29, 2012 | HTC Inspire 4G Smartphone
Wont go into phone mode
Assuming you've tried pulling the battery and booting it again, you could try doing a hard reset on the phone (this would erase all data on the phone), by starting up the phone while holding down the volume up button while turning the phone on, waiting until you get a white screen with 3 skateboarding androids on it, and select clear storage (use the up/down volume buttons to move the cursor, power button to select), then volume up to confirm. If the phone still won't boot up after doing that, you're going to have to take it to a store, as that boot menu is the only thing that you can get to come up if it won't boot all the way up.
Nov 10, 2011 | HTC EVO 4G Smartphone
Trying to unlock google password and it want let me get out of it
leave the phone on take the battery out this should reboot the phone
Oct 07, 2011 | HTC EVO 4G Smartphone
Turns on, but buttons don't respond.
If you have a remote,just press down on the volume up button and roll it around in circles.It sounds stuck and that sometimes will help unstick it.Also do it on the TV's button.If that doesn't work please let me know and we'll try something else.Good luck!
Aug 01, 2010 | Polaroid FLM-3232 Television
Samsung 40 hd tv the vol will not come down from 100 percent . I try to turn the vol down and it will not turn down. what can I do. tks mike
I presume that the volume will not turn down from either the remote control or the volume buttons on the side of the tv. If the volume down button works on the side of the tv then the remote control is suspect to be faulty. If neither remote or tv volume buttons work then check whether the channel buttons work on the tv (not remote). If none of these work then check the input connection from the buttons /infra red reciver to the main pcb. This is a push on cable connector. As a point, also check that the volume up button on the tv is not stuck in, and feels the same as the other buttons when pressed.
Apr 24, 2010 | Samsung LCD-TV LE40S81B 40 in. HD-Ready...
Volume won't turn down
Try the setup program. When you get to the main setup screen, look for a reset all to standard setting. That may solve the problem. If it doesn't then the sound module may need to be replaced inside the TV.
Apr 11, 2009 | iLO 3200 32 in. LCD Television
Hi, I have a samsung le32r74bdx lcd tv and the volume has just gone to 100 and i can't turn it down?
First, start by unplugging set to try to reset. Then make sure that all settings in audio menu are correct. Also look for stuck volume up button on set and on remote. Sometimes buttons get lodged under surrounding frame. Also try to push volume down button on tv and watch for display on tv to see any change. If when you release button volume increases by itself, remove batteries from remote to eliminate it as cause. If nothing you try works expect to replace main pcb. You can probably price it online with model number. Good luck, Russmann.
Jun 09, 2008 | Samsung Televison & Video
Volume
confirm that volume contro plus (+) button does not stuck inside.
try to apply good contact cleaner in volme button and press it many times until it released.
Mar 08, 2008 | Akai CF2791 27" TV
Televison & Video Logo
15 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
