Question about Sharp LC42SB45U 42 in. LCD TV
Pop the cover off my tv - Sharp LC42SB45U 42 in. LCD TV
  • Sharp Master
  • 10,074 Answers
On the back cover there arrows pointing to screw holes. Tale all those screws out and the back will come off.
Posted on Sep 12, 2016
Tv won't power up
just had this problem, heard a pop, tv off, removed back cover,checked blogs, disassembled power supply-- external ac to dc convertor, no screws, use small flat blade screwdriver, tap along sides at seam all along until it appears to pop apart. check capacitors and solder connections. My was an over heat issue, after removing plastic and cover aluminum heat sink basically, cooled down fixed crack solder and works-- will order a new one suggest you keep this i a cool spot. not next to a cable box! happy as the blogs are grim.
Jan 16, 2014 | Westinghouse UW40T Series UW40TC1W 40" LED...
Tv has picture, no sound, just popping/clicking
Probably the internal power supply has failed. It can happen even though your TV was stored and covered.
Dec 06, 2013 | Haier HL32R 32 in. LCD TV
Lines disappear mostly if the tv is switched off for about 15 seconds and start popping slowly and spread all over in few minutes. Is it a motherboard or t-con board problem? The problem was caused by a...
remove the back cover of your tv shut off your light then observe if there is sprkling in the inverter section, that's the cause of popping sound,,
Sep 09, 2013 | Televison & Video
some sets have screws in the back all around the front cover and some come off by taking bottom speaker grill off first and you will see screws that holds the cover. And some have a template that pops off and screws are underneath it.
Dec 26, 2010 | Toshiba TW65H80 TV
Crack appeared in the screen of my TV
sony lcd tv warranty 365 day not cover all damage proble
Sep 18, 2009 | Sony KDL-40XBR4 40 in. LCD HDTV
No Picture, Power light Blinking 3 times then repeats
3 times blink shows lamp cover is removed or not installed properly on TV.
Please take out lamp inside TV and check, seems its broken as you heard loud pop.
Aug 28, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Menu pop up
there may be an issue with the push button on the side flaking out check and see if it is sticking on the cover if not I would replace that board
May 27, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Panasonic DLP
If it has "Popped" then I would expect a rather catastrophic failure, and Lamps don't go "Pop.. they just fail more likely a Capacitor, Resistor, maybe even a semiconductor... so it's off to a reputable repairman get a "quote" and proceed from there.
Jul 22, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Sharp LC42SB45U 42 in. LCD TV Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
