Question about Kenmore 24902 Top Load Washer
Water will not turn off after filling or after
When the washer wis finished fillinf the cold water wont shut off, therefore flooding my bathroom/washroom area. Nor will it turn off when the switch is in off position. What should I do?
  • 520 Answers
Have a tech change out the solenoid valve in the back of the machine.
Posted on Jun 23, 2009
  • 351 Answers
I would change the level switch and check the level switch hose..whirlpoolpartssurplus.com
My Telmann xqb45-268gps washing machine fills with water, washes, but wont rinse. Help!
WASHER WILL NOT RINSE:
If your washer doesn't go through the washer rinse cycle, the most likely cause is the water valve. What happens is the water valve will stop letting cold water into the washer; therefore, once the washer gets to rinse it will either stop or not do anything during the whole rinse cycle.
This is because when you selected your water temperature, you selected warm/cold or hot/cold. The hot water came in and you didn't notice any problems. When it got to rinse, the cold water the cold water won't come in. Therefore, the washer does nothing.
The item to check would be your water inlet valve. Check it for continuity with a multi meter it should show Ohms or a closed circuit. To test it when water is overflowing unplug the unit and see if it still overflows or continues to fill. If it stops when unplugged. Then it is not a water inlet problem but an electrical signal problem going to ur water inlet valve. Possibly from the panel or board. You can also do a live volt test to see if it is getting the full 120 current, but be sure to unplug unit before testing as this is a live test.
Another test u can do to check the water inlet valve, first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed.
If you still don't have good water pressure, the problem is in your house plumbing and you need to call a plumber. If you had good water pressure the first time you performed the test, the water valve is bad and needs replacing.
TIMER
If your washer doesn't go through the washer rinse cycle the timer may be the problem. Sometimes the timer gets stuck in the middle of the cycle or won't turn at all. If the washer runs, but the timer doesn't turn, the timer is bad and needs replacing.
Do you have anti-flood hoses leading to the machine. If you do there is probably a loose tube in the back causing a small leak. When the hoses detect that water is still flowing after a certain amount of time due to the leak it shuts down and causes the machine to turn off during the rinse/spin cycle
By the way my advice is free cuz God is good!
May 17, 2015 | Washing Machines
It will fill but once full the motor will only spin for a few seconds then stop
IT MAY BE DUE TO A RINSE PROBLEM?
To check the water valve, first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed.
TIMER
Apr 19, 2015 | Washing Machines
Amana washer will not go through rinse cycle
TIMER
Mar 28, 2015 | Amana Washing Machines
My Asko will not fill with water and wash. When I press start it sounds like it is draining yet there is no water in it. I have manually drained it and cleaned out the pump.
TIMER
Mar 17, 2015 | Asko Washing Machines
Lavamat problems
Most likely, your washer's fill valve is leaking. You can probably find replacement valves. I found the AEG LAV1480 parts at several sites.
If your water pipes to the washer have shut-off valves where the hoses connect, turn the water to off after doing the wash. If they don't have shut off valves, have them installed. It's a cheap way to avoid floods when either the valve or the hoses fail. There are some high-end electronic shut-off valves that include a timer so you won't forget to turn off the water. Two simple 1/4 turn shut-off valve (one for hot, one for cold) are cheaper but you have to turn off the water after you finish the load.
To test the shut-off valves when in the closed position, disconnect the hoses from the washer and put a bucket under them. No water should flow into the bucket beyond the water that was initially in the hoses.
I hope this helps.
Apr 29, 2012 | AEG Washing Machines
Washer wont fill up during rinse cycle
all rinse cycles are filled with cold water to keep the clothes from wrinkling.set up the washer to run with just cold water.start it,if no water comes into washer,shut down your house water valve that fills the washer,take off the cold water hose,stick it in the washer or if there's a sink or where ever and turn on the water,if water comes out of the hose then you need a new water valve on the washer
Feb 15, 2011 | Whirlpool Washing Machines
Drum is filling with water after each wash
There is only 2 possibilities for the drum to fill with water after it has finished.
Firstly, if the empty pipe is connected to the sink outlet pipe, the water can syphon back into the washer if the pipe is too low, thereby slowly filling the washer when not in use.
Solution is to lift the outlet pipe higher.than the bottom of the sink.
The other reason is the inlet valve is not shutting off properly.
To prove if this is the case, turn the water off at the valve, if it is hot and cold fill, then turn the hot off only, and wait and see if water comes in over a period of time, if it does not then you need to replace the hot valve.
If water stills comes in with hot turned off, then you need to replace the cold valve.
If cold fill only , turn off cold and wait to see if any water comes in, if it does not, then replace cold valve.
Plz rate my solution.
Thanks.
Jan 29, 2009 | Washing Machines
Hot water runs constantly - overfills
This is often, if not all the time, a faulty fill valve, the fill valve has mechanically stuck open and is not fully shutting off when not the washer is not in use. This normally will become worse and could flood over the top of the washer = big mess .... replace the fill valve. The fill valve is the part the hot and cold water hoses are attached to.
Jan 11, 2009 | LG WM-2277HW Front Load Washer
Cold water will not shut off at end of spin cycle
electriic inlet valve is obstructed, try removing cold water hose direct the hose into a bucket and fill the tub on the warm setting (flushing the cold valve) then try the washer again ..If that doesn't work a new valve is needed
Dec 25, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Water will not shut off, continues to fill
does the water run when you unplug the machine? if so then you have a bad fill valve,
Nov 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
Kenmore 24902 Top Load Washer Logo
100 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
