Question about Refrigerators
Ge gth22kbrarww defrost thermostat - Refrigerators
2 Suggested Answers
Sea Breeze
  • 4654 Answers
SOURCE: GE refrigerator model GTH22KBRARWW will
Very possible that the defrost heater is burned out. Unplug and remove the rear wall in back of the freezer. If frozen over defrost with a hair dryer or let a bucket of hot water sit inside the freezer for a while. After defrost we need to inspect the WR51X10038 or 880036 Defrost Heater to see if it's burned out. If yes the you will need to replace the heater. If we find nothing wrong inside the freezer then we need to have a look at the mother control board. I will help you go through these test if you want, Let me know what you find, Thanks, Sea Breeze
Posted on Aug 21, 2009
My GE model GSH25KGMB BB side by side refrigerator is not cooling on fresh food side. Freezer and ice maker side working fine. How should I troubleshoot this?
On your model I would go straight to the defrost heater and defrost thermostat and check them first after defrosting the evaporator first with a hair drier. Both parts need to be replaced=> WR51X10055 Defrost Heater Assembly 25953576-emtx2i4tcmlh0qfjbwwrn2z1-2-0.jpg and the=> WR50X10068 Defrost Thermostat APPLIANCE 911
Nov 11, 2015 | GE Refrigerators
How to replace defrost timer
There is not a defrost timer on a model PSC23NGN. If your model is the=> PSC23NGN and the refrigerator is not defrosting the problem is most likely the Defrost Heater and Defrost Thermostat that need replaced. The heater is item location 230 and the defrost thermostat is item location 240 in this photo=> HERE
The part numbers for the Defrost Heater are WR51X10055 Defrost Heater Assembly The part number for the Defrost Thermostat WR50X10028 Defrost Thermostat
I am here if you have questions, Thanks John Tripp
Appliance 911
Contact me here.
Jul 06, 2014 | GE PSC23NGN Side by Side Refrigerator
I have a GE side by side model gss221fphww.The freezer is icing up and the refrigerator part is not cooling well.
johnnybur64, That is a typical sign that the defrost heater and defrost thermostat need to be replaced, Those models have very little problems with the motherboard section that tells the defrost to come on. Most times just those parts defrost heater=> WR51X10101 and defrost thermostat=> WR50X10068 will be all you will need. Unplug remove rear panel and defrost with a hairdryer to speed things up. When that defrost heater burns out you can see it easily through the glass tubes, I always replace the defrost thermostat because it is cheap insurance that you will not need to go back inside. You also can find these parts here=> GE Artica Profile Technical Information
If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, Thanks, Sea Breezed28e6ff.jpged3daa8.jpg
Feb 01, 2010 | GE Refrigerators
I have an older GE Profile side by side not defrosting, have continuity in element when warmed thermostat kicks off and I have replaced the timer, still not defrosting. Model #THP21PBSMWW S/N SL238841
Need to check and see if the element is heating up when it goes into defrost. If the thermostat is bad it will not go into defrost. I purchased a new heating element for my GE and it came with the element and thermostat together. Also make sure the fan is running in the freezer this moves the heat through the coil as well as the cold temp when in freeze mode.
Nov 15, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Require numbers for defrost heater, thermostat & timer of GE 24ZF
You need some more numbers to be sure you get the right parts. Look here to see possibilities. Click your and then search for defrost. It should show all the defrost parts. http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=TFG24ZF
Sep 23, 2009 | Refrigerators
Our GE profile freezer/frig - frig side has ice on coils
Sounds like the automatic defrost system is not working. The usual problem is the defrost heater, the defrost thermostat, or the defrost timer. If any of these parts are bad, it will not defrost.
Aug 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE refrigerator model GTH22KBRARWW will not keep cold
Aug 21, 2009 | GE Refrigerators
GE TBX18BLJ --Freezer comp frosts/ices up. Defrost
The next step would be to unplug the refrigerator and remove the rear panel and defrost so that you can unplug the defrost heater on one end and check the continuity. 305175 Defrost Heater and defrost thermostat Part number 3489. If you change the defrost heater you should also change the defrost thermostat. Let me know the results. Remember above 60 degrees the defrost thermostat will show open with your OHM meter. Sea Breeze
http://appliancepartsse.blogspot.com/
Aug 15, 2009 | GE Refrigerators
My GE fridge is not defrosting the coils in the back. What's up?
if u have frost build up in the freezer it will affect the temperature
and it needs to defrost
problems could be
defrost timer.
thermostat.
terminator.
heater s.
unit problems (unlikely) if even frost coating.
Jun 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Model tfx24f defrost not working.
Replace the defrost heater and defrost thermostat located behind the freezer panel inside the freezer compartment.
Jun 12, 2009 | GE PSC23NHN Side by Side Refrigerator
Refrigerators Logo
29 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
