Question about Icom F5021 Vhf Mobile 50w 128ch W Magnetic Antenna
Icom f5021 blows power fuse Does it have a protection diode
    Genius:
  • Icom Master
  • 1,795 Answers
Should have one where the power wires come into the set. For the price of this radio it better have one.But thats not nessarily why it blows the fuses.It could be a power transistor thats blown or even the driver for it.Could also be an IC circuit.
Posted on Aug 13, 2014
Does cam have wrong polarity protection
All devices that are electronic and are not OEM have a diode in the unit that protects against polarity reversal. If it is ever hooked up wrong, the diode will short and the fuse will blow, the unit will not power back on until the diode is replaced.
Sep 25, 2016 | Radio Communications
Hi. My uhf band cp 200 won't power up because it was placed in a charger .Please tell me what protection diodes I need to replace, and it's proximal location. Thank You.
Chargers have higher voltage ratings than the one it charges. It also lacks the needed filters to supply the exact direct current which damaged your equipment but first check if it blows up your fuses when you connect the power supply. If it does check for Zener Diodes usually connected to the mains of the equipment to simulate the simple crowbar effect of protection. If it does not blow up your main fuse then the fuse might be in the circuit board of your base unit. Zener Diodes are cased in striped crystal that short circuits itself when applied with reverse or higher voltage rating power supplies. You will need a multimeter positioned at continuity to test this. Remove it and replace the fuse then apply power, it will light up but remember to replace the damaged part for protection.
Feb 23, 2016 | Radio Communications
Manuals free download
Go at site mods.dk (Member Maintenance, it is free)
Jun 06, 2013 | Icom Cs-f5021 Programming/cloning Software...
Repairable smart charger?
There maybe a fuse inside the unit, most reverse polarity is protected by a diode though. It is a sacrificial diode that blows out when hooked up wrong. If you have an external fuse and that keeps blowing, chaces are the diode is bad.
May 05, 2013 | Go Power GPSC-12-10A 10 Amp Smart Charger
How to program scan in the software
OBD2
OBDii
Best Car Diagnostic Tool
This websit about:
AUTOCOM
Auto Engine Diagnostic Tool
Auto Injector Cleaner
Auto OBD Tool
Auto OBD Tools
May be able to help you!
Dec 27, 2012 | Icom Cs-f5021 Programming/cloning Software...
Programming a cs-f5021
G'day,
I have the answer to your query here:
Join yahoo group specific to your radio Make/Model, the technicians there will be only to happy to answer any question you may have regarding your radio, PLUS, you cand download manuals, schematis and wait for it, SOFTWARE for your radio, all this is free.
I hope you found my answer helpful.
Best regards,
Peter
Can anyone please help me with my superstar red 3900 has i have changed the audio chip and protection diode and i have still got no recieve what could the problem be thanks
No RX or No Audio?
Could be blown protection diodes or if no audio a faulty capacitor close to the audio chip!
The protection diodes can blow if you were close by someone with a high power transmitter, then the diodes would blow kinda like a fuse to protect the rig, result no RX symptom!
Replacing the diodes will cure that problem, located close to the rear of the rig.
Sep 06, 2011 | Superstar SS-3900EGHPA CB Radio
Power input problem. Keeps blowing fuses, checked cord and it is good, have continuity across positive and return pins of the receptacle...pulled the covers and did not see anything that was obviously...
There should a small diode located near the power input line, "black in color with band on the one end" chances are it is shorted, blowing the fuse. This is a protection diode preventing a positive/negative mix up, if this turns out to be the problem check to make sure the audio is working, if not! you must replace the ic chip.
May 20, 2011 | Cobra 148 GTL 120-Channels Base CB Radio
How come it blows 30 amp atc fuse instantly even with the system off
check connections are hooked up properly if it blowin the fuse with it off sounds like something is really wrong on inside get it checked out
Jun 04, 2010 | Kicker KX200.2 Car Audio Amplifier
B;owing fuses, wont power up, just smokes
Try checking the reverse protection diode. This diode would normally be connected right after the power connector and would be the biggest diode inside. One way to verify if this is defective and causing the fuse to blow is even with the power switch at the OFF position, the fuse will still blow.
If on the other hand, the reverse protection diode is good and fuse will not blow when power switch is at OFF, then the short/defective component is inside. There would only be two (2) major components that can cause the fuse to blow with the power switch to ON, the final transistor and/or the audio IC.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 06, 2008 | Cobra 29 LTD CB Radio
Icom F5021 Vhf Mobile 50w 128ch W Magnetic Antenna Logo
55 people viewed this question
Top Icom Radio Communications Experts
peter0911
Steve
Are you an Icom Radio Communication Expert? Answer questions, earn points and help others
