Question about Jura Capresso 560 Electric Burr Grinder
Capresso grinder bean container
Container doesn't fit on base for some reason
  • 60 Answers
SOURCE: fill beans message keeps coming up on jura capresso impressa s9
You need to open the grinder, it`s probably packed with old fine powdered coffee that blocks the outlet. Clean this out and try again. Since it works normal when you use pre-ground coffee, there shouldn`t be any problems with any other parts.
Let me know if you want a description for have to open and clean the grinder.
Posted on Jun 02, 2009
  • 60 Answers
SOURCE: I have a jura capresso S7. I am finding water in
This is normal, after each cycle the brew unit will empty the drainvalve for excess water, this will ensure that the water used for each new cup is fresh from the watertank.
Posted on Jul 27, 2009
SOURCE: Jura E9 grinder spins but does not grind
I had a similar problem, and solved it by turning the grinder by hand against resistance. Apparently the grinder wasn't really turning during the cycle and needed to be cleared. If your beans are "hopping" this may be a different problem.
Posted on Aug 14, 2009
Testimonial: "Grinder is turning but old bean oil is clogging it. Stirring beans on next brewing after drying the grinder was also customer services recommendation"
SOURCE: my jura impressa c9 coffee machine keeps tellnd me
I just called their customer service 800-220-5701 with the same problem.
There's a point at the bottom of the chute where you can add ground coffee that tends to clog, especially if water gets in there. Access is from underneath - - remove the bottom tray and reach in - - it's not the hinged flap opening (that's the first thing you'll feel) but if you leave that closed and reach behind it, there's a silver-dollar sized area you're supposed to try to access and clean using a dry cloth. Once that's done you're supposed to try vacuuming from the top and then let it dry for a day or two.
Posted on Dec 22, 2010
SOURCE: My Jura Capresso Impressa E8 is leaking water
I have the same problem with my E9 and I have traced it to the diaphragm unit that is just distal to the pump itself. Apparently, the diaphragm is secured with a steel band (not stainless since it is rusty) that may hold seals or O-rings that break down. You can observe it leaking when pressure applied during brewing. The question is: can a new unit be ordered and if so, where?
Posted on Nov 05, 2011
I can't brew coffee, when machine is turned on it makes a loud noise like endless spinning. sounds like it is coming from the brew/tamping area
foreign element perhaps the grinder is bad though. First try using a small vacuum that will allow adequate control of vacumming up the bean container. remove all the beans etc. the bean container must be emptied. then look at what the vacuum removed, any foreign objects? if you see 1 or more it's likely fixed. otherwise remove any inside cover/guides in the bean container you should now look directly at the grinder wheels with flashlight, as there may instead be a foreign substance or a defect preventing the grinder from processing the beans. if a defect then it may require factory service. gl
May 28, 2015 | Jura Capresso Impressa Z5 Espresso/Coffee...
How do I dismatle the grinder on my Krups espresseria automatic
I suspect that as you have only managed to remove 2 screws from the beans container that this is going to be quite a task for you but here goes.
1) Remove the button from grinder adjustment by pulling or levering upwards
2) Lift beans container off
3) Remove front trim panel (square frame like a picture frame at front) Done by removing drip dray and thumping frame upwards with heel of your hand.
4) Undo 2 outer screws at top front of top housing
5) Undo screw in middle at back under where beans container was
6) Lift off top housing, you may need to rock & flex it a bit to release rear clips
7) Put knob back in & turn grinder adjustment fully right (clockwise)
8) You now need to mark that part of the grinder top that goes between knob and grinder so that you will be able to put it on exactly as it is now. Then remove that part from the top of the grinder
9) Now you can turn the top of the grinder anti clockwise further than the adjustment knob was moving it.
10) Once you have turned it as far as it will go you will be able to lift (with wriggling) the top part of the grinder out.
11) Cleaning out will be done with a small screwdriver and vacuum cleaner with nosey parker attachment fitted.
Dec 29, 2014 | Krups Coffee Makers & Espresso Machines
How to clean jura C5 grinder
How to access grinder itself? Where is it? My Jura C5 doesn't grind coffee beans at all. Firstly grinder has started with starnge noise and then stopped with alarm "no beans", now it doesn't start at all..
Mar 06, 2012 | Jura Capresso Impressa Coffee Makers &...
Keeps saying fill beans container when already full
The machine understant that there is not any beans in the container by the mesuring how easily the grinder motor rotates. If there is not any beans in the grinder motor rotates freely. In your case means that the beans from container are blocked to enter down to the grinders disk plates or they partialt enter, so the motor runs more freely and machine understant that there ae not enough beens. So you need to remove the beans and container and by the use of a vaccum cleaner remove all remainings from the grinders entrance and funel. You can also use a brush to remove any coffe oils and remianing so the bean can easily slide inside the grinder.
Jun 25, 2011 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Hmm, I have Capresso Infinity Burr Grinder #560, and I accidentally placed the upper burr back in upside down. Now it is stuck. I do not see the "black section with a long slot" around the blade.
Yes! I had the same issue with putting the burr in upside down and then twisting it an effectively "locking" it in there incorrectly. I tried the "knife" solution that worked for some people here, but it was placing the bean container back on and twisting counter clockwise that did the trick!
So glad I found this thread and didn't give up trying to fix my burr grinder (which we love).
Thanks to jaybayca!
Jan 08, 2011 | Jura Capresso 560 Electric Burr Grinder
I accidentally placed the upper burr in upside down. Now it is wedged in and I can't get it out. Any suggestions?
I've posted this in a few other places on this site (there are many ways to ask the same question), but try putting the clear bean container back on and untwisting as if to unlock it -- the problem isn't just that we put the upper burr in upside down, but then we locked it into place with the bean container. More info at http://www.fixya.com/support/t4009992-upper_burr_stuck_upside_down or try Capresso at 800.220.5701.
Cannot remover the coffee grinder from machine.
Remove Coffee Maker's top cover. Slide coffee bean container off (after emptying it of coffee beans). Remove fixing screws (normally philips) securing the bean container platform. Remove grinder's bean intake rubber seal. Unscrew the grinder's fine/course selector, paying close attention to where it was originally fixed, from factory. 4 rubber bushing are anchoring the grinder in place, which can be seen from the front of the Coffee Maker (w/ door opened). Wiggle each rubber bushing through, as you pull grinder from the top. Grinder should come loose, after unplugging wires. - Good Luck
Nov 13, 2010 | Miele Coffee System
Aug 14, 2009 | Jura Capresso Impressa E9 Espresso Machine...
I cleaned my Breville grinder and tried to put it back together but the bean container will not fit back in. Please help.
This might be it. On the bean container there is a white dart and the word 'align'. The same dart and word appear on the top of the grinder. Align the two darts and the bean container should drop right in.
Dec 13, 2008 | Breville Conical Burr Coffee Grinder -...
Coffeee beans won't feed into grinder
Push the coffe brew button again. It should take right off and grind again.
Jul 15, 2007 | Saeco Magic De Luxe Espresso Machine
Jura Capresso 560 Electric Burr Grinder Logo
96 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Steve
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
