Bluetooth problem...
I'm not sure about LGs, but I know you can't set a Motorola to be permanently visable, it hides itself after 1 min. LGs might do something similar. Either way, you only need it to be visible to pair it. Once it is paired with the headset or "bluetooth earphone", the phone doesn't need to be visable to connect to paired devices. To pair a bluetooth headset, refer to the manual of the headset on how to put it in "Pairing Mode", then go on the phone to add a new device with bluetooth, and find the headset. There will probably be a code you need to input on the phone. It should also be in the manual of the headset.
