Question about Jandy Laars Lt 400,000 Btu Heater
Pressure switch light is flashing heater is not igniting
Heater made loud noise like its going to blow up
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Jandy Master
  • 1,448 Answers
Check pressure switch or copper tube to it to see if clogged
Posted on Nov 06, 2014
3 Suggested Answers
  • 760 Answers
SOURCE: My Jandy Laars LX 400,000 BTU heater flashes "low pressure"
Once you try to ignite three times in succession, and the heater doesn't sense the presence of flame, the heater goes into "lockout" mode and must be reset to fire. This can be done by pressing and releasing the mode button so that the heater is turned off then returned to the desired mode. So if you were going to "jumper" the pressure switch, (connecting two wires together) make sure you do the reset also. Make sure you don't operate like this, if your pump quit, you could have a melt down. Also If you have anything connected to the fireman switch, it is in series with the pressure switch,and woud display the same thing. There is a terminal with two white wires, if there is a jumper there, then nothing conected, but if there is something connected, make sure it is closed. Also be sure your code was for Water pressure and not air pressure switch. You can download manuals at: www.jandy.com
Posted on Jul 27, 2010
adamh294
  • 310 Answers
SOURCE: Heater will run when the
Replace the pressure switch and look for a disconnected ground
Posted on Mar 17, 2011
Furnace noise
Hello, that means your orfice isn't adjusted close enought to your pilot, needs to be adjusted by a service tech. can blow up the house if doesn't light.
Dec 01, 2015 | Heating & Cooling
Cozy dual wall heater, makes loud noise and shakes heart when it starts
check gas pressure, natural gas 3.5 and propane 11, also if you have stainless steel burners drill out the first series of holes on the carry over tube to match other holes use 1/64 drill bit.
Feb 27, 2015 | Cozy Heating & Cooling
No ignition
Restart the unit as soon as you see the inducer fan on jump the 2 wires the pressure switch. Your burner should stay on and go through it sequences. If it go through it that pressure switch need replace and make sure your inducer pull under the vaccum of the pressure switch.
Feb 04, 2014 | Goodman GMS90703BXA Heater
Problem with furnace not kicking on.
could be one of a few diff issues. firstly, the air pressure switch may be failing. check to ensure the inducer motor is providing enough air flow for the air switch to close. if inducer motor isn't creating enough air flow the faults is within the motor. If the airflow is enough, then fault maybe the air switch. you also need to check for any blockage in the exhaust. ensure no debris is blocking the vent going to outside
Jan 21, 2014 | Goodman Heating & Cooling
I have a Big Maxx heater and it won't stop blowing and won't heat. The fan just keeps running! Anyone know what could be wrong?
Your pressure switch may not be activating (ie closing and making contacts) This means you could have a blocked flue, clogged pressure switch tube or a bad pressure switch. The pressure switch is a safety feature to ensure your exhaust is not blocked and operating correctly. Find owners manual. Look at trouble shooting section. Open cabinet and look for error code light. If blinking 3 times, try "jumping" the pressure switch. To jump pressure switch you need to clear code be turning off power. When the unit/thermostat calls for heat the power vent fan starts first, this is when you need to jump the pressure switch. You need to do this in sequence. That is the unit first starts the power vent exhaust thus activating the pressure switch allowing the ignition cycle to the burners and heat. So the power vent fan needs to start first BEFORE you put the jumper on to bypass the pressure switch. Once the jumper is on it will call for ignition after approx 30 seconds. If ignites your problem is one of the 3 stated at the opening of this paragraph
Mar 21, 2013 | Mr. Heater Natural Gas Garage Heater -...
Pdc spa heating only to 95 3 lighrs blinking
You have a Gecco pack in your spa. 3 blinking lights indicate low flow in your heater. If it's heating to 95 then you have an intermittent issue in pressure switch or your pump is about to go and it's barely pressurizing the heater tub enough to get the heater to turn on. If you're not hearing a loud noise from your pump on the way out, chances are that you have a bad pressure switch. Get the model number off your control pack and call the guys at the link below. They will have the pressure switch you are looking for.
http://www.spapartsdepot.com/category/pressure_switches/
Feb 23, 2013 | Pool & Spa
Rheen PVW50 Hot Water Heater Making Buzzing Noise and Doesn't Light
Why is it always Rheem problems?
Every water heater problem is Rheem.
And Rheem doesn't post any service manuals, like the other two big manufacturers, AO Smith-American, and Bradford White.
Copy following link for troubleshoot by gas control valve.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Scroll up and find pressure switch heading among links.
You can install gas control valve yourself.
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
Sep 06, 2012 | Rheem Water Heaters
Dayton 3VE59 Gas Utility/Portable Heater won't ignite, power and gas to unit
Just repaired one of these, problem was that main gas valve was not opening, valve is controlled by a vacuum switch, vacuum is created as fan blows air down tube past bent up metal flap near front bottom of heater (slight low pressure zone created). If vacuum switch is miss adjusted it will not close when fan is running and no gas flows. this is easy to check as vacuum switch also has a pressure port on it. With gas disconnected, remove bottom cover, locate vacuum switch (it has a hose clear plastic hose connected to it, in opposite corner is another hose connection, attach a length of hose to it that you can blow lightly into. With heater plugged in and no gas connected (USE CAUTION OF WIRE!!!), turn heater on you should hear after a few seconds the ignition and then a loud click as the gas valve opens, if no click blow lightly into end of your added tube, if you now hear a click the gas valve just opened. if you stop blowing you might hear the gas valve click again as it re-closes. If this is the case the vacuum switch needs to be adjusted slightly. THIS switch is hear for your safety, Adjust at your own risk!!! This can be done with a screw drive in the top, rotate screw slightly while checking if the fan alone causes enough vacuum to make the switch work. DO NOT over adjust. check safety operation before hooking up gas by placing a piece of cardboard or wood over the air intake and the exhaust to block airflow, if the air flow is blocked you should hear the gas valve drop out and reconnect as air flow is reestablished. Hope this helps
Jan 12, 2011 | Dayton (3VE56) Gas Utility Heater
Adjust resonance screw makes loud noise on start up
I'm not sure what you mean "adjust resonance screw". I'm going to guess the adjustment screw your talking about is under at screw cover and is the appliance regulator screw. It adjust the gas input to your burners. Too low pressure is caused by backing the screw off and can result in delayed ignition or a "loud noise". It's really a small explosion caused by built up gas and damage your heater. Too high of pressure is caused by turning the screw in too far and can over-fire the heater which is also dangerous. I'm assuming you burn natural gas because with propane the appliance regulator is wide open. Your gas company may come and use a manometer to set the manifold pressure to factory settings (3.5 to 4.0 W.C.) for you. Otherwise, turn the screw back in until the ignition is not delayed and the loud noise is replaced by a nice quick ignition. Good luck.
Jan 02, 2010 | Empire DV-215 Direct Vent Natural Gas...
MODEL # GMS80903BNA. MY FAN COMES ON BUT THE
Turn the heat up and observe the flash code....there's a legend in the furnace,or in the blower compartment that tells you what the flash sequence means...or in the Manual...........The flash code is likely for the Pressure switch...this part can either be defective or your Vent or Air intake could be blocked with Leaves,rodents,kids rocks etc...check the vent outside and look for obstructions and see that the air coming out the exhaust seems to be normal...........find the pressure switch which is round and has usually a grey small hose coming from the pressure switch and going to the furnace body or the exhaust fan....pull the hose off the opposite end (not the pressure switch...with the power off)...and slightly **** and blow repeatedly...(Really) and you will here the switch clicking....do this several times at least...make sure you're activating the switch by hearing the clicking.....Turn the furnace back on and see if it works...if it does you need a new Pressure switch...if it doesn't your vent could still be blocked or the switch could still be defective02f491c.jpg
Nov 13, 2009 | Goodman GDS80703ANA Open Flame Mid-Size...
Jandy Laars Lt 400,000 Btu Heater Logo
85 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
