Question about Plumbing
Shollow well pump does not maitain pump presure water trickels after a few seconds.
  • 28 Answers
The foot valve faulty at bottom of the water line at the bottom of the well most likely has gone bad. Or a leak anywhere in the water system from the pump to the well.
Posted on Jun 24, 2009
Tank full of hot water,faucets deliver only cold,water trickels into tank with rapid intermittend pump action
1) Copy following link:
http://waterheatertimer.org/Crossover.html
2) Add comment with clear description of water heater, fuel type, and pump?
Is this a pump problem or water heater problem?
Is this a water well pump?
Are you getting good stream of cold water at tap?
Which water heater do you have?
Is the heater new?
Or older heater that stopped working.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 27, 2012 | Atwood 10 Gallon Gas/Electric Water Heater...
Have 3/4 hourse shollow well pump. When I turn more than one thing on such as outside hose and inside faucet, trips the pressure switch on pump, and has to be reset.
The switch you have on the pump with a reset lever is a low water pressure switch that will trip when a load is on the pump like a leak or no water in well and switch will trip to save life of pump. One way to get around this is to install a regular pressure switch and it shouldn't trip out.
Advantage of a low water switch is to save the pump and it constantly triping can be frustrating and I have changed some to put a regular switch in to avoid having to go offen to reset switch.
Aug 02, 2011 | Wayne Water Systems Plumbing
My Moen faucet will not maitain the same water flow after being on for about 3 seconds.
Hello
Try to unscrew the tip off the faucet.
The tip is where the water comes out there is a strainer in there that gets blocked with debri.
Just rinse it out and reinstall.
Thanks
Jan 23, 2010 | Moen Plumbing
How far will a 1/2 horse shollow well pump pull water from a sorce? Not vertical, but horizonal?
To be very effective 60 meters horizontal and 20 meters
vertical distance from a water source free from pipeline leaks.
Oct 03, 2009 | Flotec Corrosion Resistant Shallow Well...
Slow cold water flow won't go back to full flow
I think the water inlet valve is nearly stopped up with sediment in the screen filter where the supply hose screws to the valve.Cut the water off at the hose and disconnect and look for the screen. The hot water usually doensn't do this because the water has time to settle everything out while it's in the hot water heater.
Aug 15, 2009 | Washing Machines
1986 sei 1200 goldwing It will start from ignition on,fuel pump runs for a few seconds,fuel light goes out,every thing normal-no LED diagnostic lights.When it starts it will run for about 3-5 seconds &...
check the fuel filter it sounds like it's pluged and causing too much back presure this is causing an over load in the fuel pump causing it to stop working or to presure lock
Aug 03, 2009 | 1986 Honda GL 1200 Aspencade Gold Wing
Water barely trickels in
Could be low water pressure, test by opening the cold tap/faucet on the nearest sink.
Hoses could be kinked, or taps not open or clogged with grime, also there may be filters washers fitted to the hoses, on either end.
Or the valves in the machine could be faulty.
Jul 04, 2009 | Washing Machines
My ge smartwater was running very slow ao i changed all three filters, now it runs normally for a couple of seconds then it just trickels out.
The tank was full of water . The blatter in the tank was empty so I pumped six pounds of air into it and it works great.
Mar 25, 2009 | General Electric GE SmartWater Household...
The water hose keeps bursting while welding aluminum
The probable caures is due to the coolant pressure, do'nt turn this full on, if it's from the mains tap turn on and notice a trickel from the outlet, one half turn of the tap should be ok depending on the water presure. If its from a recirculation tank check the vale govener inside the tank. The torch data will indicate the coolant pressure
Dec 30, 2008 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
Plumbing Logo
69 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
