Question about Pioneer DVL-700
Dvl-700 won't power on
Laser disc player
2 Suggested Answers
ekmoetweet
  • 124 Answers
SOURCE: Pioneer DVL-700. Unit Plays LD
The dvd's are not spinning up correctly. If the belt inside is worn this will cause cd's to play but dvd's fail. open up and replce belt (small black rubber running on motor)
Posted on May 13, 2011
I insert disc, but after a little while, disc ejects without even playing. Help!
happen to all disc?
if so, check the 'home' sensor for the tray. need to open up and take a look.
Jun 14, 2014 | Pioneer DVL-V888 DVD Player
Did not read discs
get a disc cleaner, use the cleaner and see if the wight cord is hooked up to the wight plug in and plugged in correctly.
Dec 11, 2013 | Pioneer DVL-909 DVD Player
Hi, I need a pioneer dvl-909 service manual that tells how to replace the loading belt. Thanks, Bill
Try to see if the drawers are blocked by something either inside or outside of the case.
Mar 17, 2012 | Pioneer DVL-909 DVD Player
Pioneer DVL-700. Unit Plays LD Discs & CD's fine but will not play any DVD Videos.
May 11, 2011 | Pioneer DVL-700
I am not getting color on the screen, only black and white. I haven't used this player in awhile.
Please let me know the input mode you are using. If it is component, then it is very much possible that you have swapped the yellow plugs(YPbYPr) . Try swapping the plugs and see if resolves the issue. If it doesn't then please provide the input mode info that I have requested
Let me know what happened,
Sai.
Jan 03, 2010 | Pioneer DVL-909 DVD Player
No power at all.
replaced d105 it shorted
May 19, 2009 | Pioneer DVL-V888 DVD Player
LD Repeats itself every 15 seconds in play, DVD's play fine.
This solution should help or at least decrease the occurances.
It has worked for me.
The problem seems to be that the original manufacturer lubrication on the glide rails and on the glide track has lost it's viscosity causing the Laser Pick-up Head gliding process to bind causing video to repeat at any random binding point.
Open the top cover and play a Laser Disc.
Manually change from Side "A" to Side "B".
Observe how the Laser Pick-up Head glides on the track and on the glide rail.
Stop play mode and remove the Laser Disc.
With the tray open, unplug the power at the power electrical cord. Now with the power removed and the tray left open, take a "Q-Tip"™ and spray some ""WD-40"­™ on the "Q-Tip"™.
Now gently tap the saturated "Q-Tip"™ along the full length of both the upper and bottom glide rails as well as the glide tracks.
Repeat this process.
Be careful not to touch or lube the Laser Pick-up Head with the "Q-Tip"™.
If you do touch the Laser Pick-up Head, just gently clean it with another "Q-Tip"™ saturated with alcohol.
When finished, reconnect the power and play a Laser Disc.
Manually change From "SIDE "A" to SIDE "B" about three times to spread the "WD-40"™ evenly and ease the gliding process.
This solution should help.
Feb 08, 2009 | Pioneer DVL-919 DVD Player
Disc Tray Won't Open
Sounds like a belt is slipping.
wont open, wont close, makes clicking/grinding noises etc.
http://www.llamma.com/xbox/Repairs/thompson_dvd_tray.htm
Jan 25, 2008 | Pioneer DVL-909 DVD Player
Tray won't open
It could be electrical or mechanical. Without checking there is no way to be sure. You can get the service manual for your model for 10.00 at the following link. That should get the problem taken care off.
http://www.electronicsrepair.net/dvd9.shtml
Pioneer DVL-700 Logo
18 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
