Question about Nikon Coolpix P50 Digital Camera
Lens won't go back in
Nikon Coolpix P50
I tried to turn my camera off once, and without dropping it or anything, it says lens error, and leaves the lens out and open. Anyone know how to fix it?
t00nz
  • 4738 Answers
SOURCE: lens error
The following blog outlines some repair options for a lens error:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Dec 23, 2007
BillB-SA
  • 2761 Answers
SOURCE: "Lens Error" on Nikon Coolpix S230
Sorry, but there's no simple DIY fix, and any homebrew repair attempts will likely make the damage worse. Your camera's warranty won't cover the damage, so I suggest that you take it to a local camera shop (NOT the camera department in a chain store) or contact customer service via the nikon.com web site to arrange repair. Be sure to get a firm price before you commit to anything though. The fix can easily approach the price of a new camera, and repairs typically only carry a 30-day warranty.
Posted on Dec 28, 2009
  • 11967 Answers
SOURCE: lens is stuck out and camera will not turn on
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jan 31, 2010
  • 102366 Answers
SOURCE: nikon coolpix p50, lense error,
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 22, 2010
  • 11967 Answers
SOURCE: CAMERA SAYS LENS ERROR, HASNT BEEN DROPPED/ HIT,
Posted on Jun 07, 2010
How do I correct lens cover error?
nikon coolpix s52 lens cover error Questions & Answers ...
www.fixya.com > Forum > Tags
Nikon COOLPIX S51 Digital Camera When I turn the camera on the lens cover willnot slide open. The screen displays a message that say "Lens Cover Error!
Nikon COOLPIX S52 Digital Camera - Fixya
www.fixya.com/support/p926575-nikon_coolpix_s52_digital_camera
Recent Nikon COOLPIX S52 Digital Camera questions, problems & answers. Free expert DIY tips, support, ... How do I correct lens cover error? Nikon COOLPIX.
Fixing a nikon S52 camera lens cover?? PLEASE HELP!!!? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Apr 4, 2011 - ... broke my lens cover on my nikon coolpix s52. when i try to turn it on it says Lens cover error and has a ... Can i fix it myself? What would be the approximate cost of repairs? ... How to fix Nikon Coolpix L6 digital camera lens?
Lens Error message ' Nikon Knowledgebase
Aug 31, 2015 | Nikon COOLPIX S52 Digital Camera
My nikon coolpix p50 shows lens error all the time,how can i repair it myself?
A lens error can be caused by physical damage to the mechanism that controls the lens, or debris that is interfering with the operation of the lens.
This article may be able to help you with a "do it yourself" solution.
In the event that your problem is due to physical damage and not just dirt or debris, you will need to take it to a local camera repair shop for troubleshooting-- though with most consumer digital cameras, labor and parts cost of a repair can easily exceed the value of the camera.
Mar 05, 2011 | Nikon Coolpix P50 Digital Camera
Lens error
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
May 27, 2010 | Nikon Coolpix S210 Digital Camera
The lens won't go back in and the camera won't stay on, saying lens error
Feb 18, 2010 | Nikon Coolpix P50 Digital Camera
Lens error
Not really anything that can be done without taking it apart and fixing. Problem is then getting it back together!
I always suggest to friends that they buy a camera without the extending lens for just this reason.
You can try sending to Nikon or taking it to a repair shop. Most likely will be $100 or so to get it fixed. Or, they will tell you it's not worth fixing.
Aug 23, 2009 | Nikon Coolpix S210 Digital Camera
Nikon coolpix p50, lense error, camera won't work lens stuck.
May 28, 2008 | Nikon COOLPIX L18 Digital Camera
Camera
Anything you would try to do yourself would void your warranty. I suggest taking the camera back and see if they won't give you a replacement.
Usually, zoom errors occur when the lens is extended and gets bumped or dropped. Liquid and or sand can also cause these problems
Jan 02, 2008 | Nikon COOLPIX L10 Digital Camera
Nikon Coolpix L12 It has a constnat lens error screen
mine has that too....urgh i need to take pics cuz im going on vacation too....joy
Dec 31, 2007 | Nikon COOLPIX S9 Digital Camera
Dropped camera and now lens will not move
This worked for my camera, Nikon Coolpix L10!! I'm so happy I didn't go out and buy another camera!!!
Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. Error E30 means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Kathy
Dec 10, 2007 | Nikon COOLPIX L3 Digital Camera
Nikon Coolpix P50 Digital Camera Logo
128 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
