Follow this steps
1.Press the LIST button to obtain the list of
programs that have been recorded to the
box.
2.Use the arrow keys on the remote to
locate the program you'd like to remove.
3.Press the "OK/SEL" key to select the
menu.
4.Use the arrow keys to select the menu
option called "Delete Show". You'll have
to press the down arrow once to bring the
cursor to "Delete Show".
5.Press the "OK/SEL" button to delete it.
6.Confirm your choice. Use the arrow keys
again, to select the "Yes" choice, when
the box asks whether you are sure you'd like
to remove the program recording from the
list, and press the "OK/SEL" button to confirm
the selection of the removal of the program.
It is hard to tell at this distance what the recorder is doing, but one possibility is this: When you set the recorder for a program which actually starts later or earlier than the advertised time, it is sometimes possible for the recorder to pick up and use the title from the program that came before or after the one you want.
So the recording is still the one you want, but it shows the wrong title in the list.
To ungroup contacts please go to: Apps > People > Select and touch Groups at the top of the screen > Touch the group name you wish to delete >Touch Menu >Touch OK to confirm. This will not delete the contacts registered on the Group.
These answers should be in the instruction manual. If you've not got one go to the manufacturer's website, enter Customer Support or Technical Support and you'll find usually easy steps to follow to get a free download.
Highest value observed: 76 Lowest Value: 9 Standard deviation from the ungrouped data: 15.25 Frequency: Mean: 46.94 Standard deviation from grouped data: 15.40
I am unfamiliar with this unit. If you have scart connecters on both, connect av2 on the tv to av in on the recorder. set the recorder to record from av source. You should now record a program, I think the static is the fact that composite is out from the dvd only, not an input, and in on the tv, not an output.
You can look at each item in the Groupitems collection of a group. Those are the shapes if they are grouped.:
Sub group() For Each one In ActiveSheet.Shapes If one.GroupItems.Count > 0 Then For Each one2 In one.GroupItems MsgBox (one2.Name) Next End If Next End Sub
When in timeshift, press record on the remote (every time you push "record" 30 minutes are added) and make sure the program you are recording is not macro protected. If your program has already finished rewind to the beginning of the program and push record the correct number of times to cover your program and then press stop on the remote. It should then be at the bottom of your hard drive list.
I have exactly the same problem. The difference with mine is that mine actually starts up - thsn won't shut off until I manually when I set it to record when I'm away.
