Question about Jet jsm-204 metal shear
Does anyone know where to buy replacement blades for the Jet JSM 204 pneumatic shear?
    Genius:
  • 2,432 Answers
Depends where you live. Email www.trick-tools.com they have then in stock.
Posted on Mar 28, 2015
I have a 2 blade cub cadet and it pushes snow like a blade but the fan part that blows snow out shoot is spinning. Why wont the agars spin?
The simple solution is the replaceable shear pins in the front auger have sheared. This is normal and protects the snow blower from major repairs. I suggest going to youtube and search "replace shear pins on Cub Cadet snow blower." There are a dozen videos that will help you troubleshoot and make the repair.
Feb 08, 2017 | Cub Cadet Garden
While mowing the drive belt tightner spring broke. I bought a replacement but the blades will not engage. The drive belt has been routed properly. it seems as though the blade's drive shaft will not spin.
Check and see if the shear pin has broken. If the pulleys spin but not the blades then the shear pin in the pulley or shaft has broken.
Mar 30, 2015 | Garden
Sheared keyin fly wheel now acts locked up
you my friend have a bent crankshaft replace engine or buy new lawn mower do that less of headach in the long run
Aug 26, 2014 | Garden
Anyone know how I change the cutting disc please? I know this sounds really basic but I can't jam it as I turn the key tool.
here is a generic image of common die grinders. I imagine your's is the same. Now you need to "Jam the shank with the tool numbered
37 above. Its the slotted wrench. Once its properly secured you should be able to use a flat head screwdriver to loosen the retaining screw.
Sep 01, 2013 | Jet Wmh Tool Group JSM - 522 Angle Head...
Governor
Please explain what you mean here in more detail ,is this a static generator type engine or a air compressor driven by a diesel engine ?.If i knew more about the problem i may but only may come up a solution
Jul 15, 2013 | Porter Cable PTX6 18 Gauge Pneumatic Shear
After removing float bowl i can't get main jet to unscrew to get to nozzle
i have used a little heat to get them to release not to much they melt fast
Jul 11, 2012 | Garden
Motor works but doesnt turn spindle with blade on it
you may have (probably) put something in there that wouldn't chop or grind, and the blade wasn't able to turn. When this occurs, a safety feature called a 'shear pin' breaks. The shear pin passes through on side of the base of the blade, through the motor shaft, and out the other side of the base of the blade. The pieces of the shear pin have to be removed, and replaced with a new pin. A common roll pin of the appropriate diameter should do the trick. Bear in mind the shear pin is a 'pressed fit', so removal of the old bits may be difficult. But it can be done.
Feb 06, 2010 | Microwave Ovens
Blade doesn't turn with motor
Hi Dean,
I'm not aware of a shear pin, but it makes sense that there would be one. It's not something you look for unless, well, it shears.
It would also make sense that it would be located on the drive train.
I'd take off the guard and blade, then inspect the drive wheel mount to the motor. Remember, if it turns out to be a shear pin, you're also looking for the reason it sheared.
Make sure the other wheel spins freely. Nothing is binding. that sort of thing.
Best regards
Mike
Dec 19, 2009 | Milwaukee Tool Milwaukee 6230 Deep Cut...
Mower hit a big rock and stoped running
If you hit something hard enough to partially shear the key on the blade adapter, you did shear the key on the flywheel, and it will need to be replaced for the engine to run properly.
Apr 11, 2009 | Garden
Corona professional long-handled hedge shear
try tightening the nut and bolt that hold the shears
Nov 16, 2008 | Corona Hedge Shear 10 1/2" Blade Aluminum...
Jet jsm-204 metal shear Logo
638 people viewed this question
Top Jet Cutter Tools Experts
JOHN LAPIER
Are you a Jet Cutter Tool Expert? Answer questions, earn points and help others
