Question about Wacom Cintiq Computers & Internet
Pen driver fail - Cintiq Wacom Computers & Internet
Why won't Dell s510 pen calibrate?
Needs an updated Driver. Update from the Device Manager on the Control Panel, or it is just a bad pen, take it back if it is bad
Sep 10, 2015 | Dell Computers & Internet
My Dell Centrino laptop does not recognize the device: Transcend 16 GB JF V60 Pen Drive, what can I do?
Hi Anonymous,
There is a possibility that the flash drive might have failed. Try using the Flash drive on a different computer and if the same works then you may have to download drivers as suggested by Steve Butterworth.
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
Jun 28, 2015 | Dell Computers & Internet
No Calibration for Wacom Pen
Sounds like your pen has problems, after so many attempts to calibrate the pen fail your tablet will automatically shut that feature off. I would suggest getting a new pen if possible and recalibrate it. The wire or fiber optic cable, which ever it has is bad to break where it bends down into the pen. Also the sensor in the end of the pen could have gone bad. I would contact the manafacturer on it and see what their tech's advise.
Mar 07, 2014 | Wacom Cintiq 13HD 13.3" Interactive Pen...
When installing numark dj io during installation it always says unfortunately the installation failed. (Error: Timeout - 0x0005)
check all usb connections, with any other device like pen drive, if pen drive is working perfectly , then go to " control panal" go to "add or remove programme " and uninstall any " ASIO drivers or softwares" . and restart the PC and install the device and software, drivers as told in the product manual.
if still have problem - change the RAM of your PC,
best of luck and KEEP SMILING .aaarwind
Jan 14, 2011 | Numark DJ/iO Sound Card
My pc is not detecting my pen drive .tell me what to do my pc is compaq 6710b.Is any driver missing
Pen drives don't need drivers. Try the pen in another pc - if there is not recognized then you are sure that the pen drive has failed. Can't be repaired, buy a new one.
Nov 02, 2010 | HP Compaq 6710b Notebook
Tablet not recognizing pen unless pressing down with it.
Hi, i browsed the Net in three languages to find the solution for this problem but nothing helped, then, accidentally, i bumped into the solution that helped me. I tried everything the same way you did but nothing helped. Since I use the russian version of Windows I do not know how these options might be named in english, but I think you'll understand. In Control Panel there is, as you know, the setup for pen and tablet input (with a picture of a pen) - in it there is a setup for Gestures (the middle one) - in it i disabled the gestures a long time ago. But today i tried turning it ON and went for training of these gestures (the option in blue letters at the very bottom) - and during the training my pen started hovering normally again after half a month of this problem. So I left the gestures enabled after completing the training and it still works fine. Hope it helps you,
Jan 18, 2010 | Genius G-Pen F610 (31100050100)
Pen drive issue
Try a totally independant PC away from the ones you tried....if no go drive has failed and data will be lost sorry.
Jan 07, 2010 | Kingston (SDCZ2-512-A10-KT)...
Fujitsu Stylistic 3500 Pen calibration in XP Tablet Edition
Well there is a few ways to try to fix it first with a usb mouse check that the resolution is at it's native pixel count. This can be found on the manufacture website. If it is already at that resolution ensure that the CIC XPen drivers are installed. Those should have placed a recalibration program in the control panel. If those both fail, try uninstalling the drivers and restarting, then reloading the drivers. Hope this helps! food luck and godspeed!
Jan 11, 2009 | Fujitsu Stylistic 3500 Tablet PC
Will a Bamboo Pen work on a Toshiba tablet pc M200
^The question is NOT asking about a USB thumb drive, and a lot of people seem to have failed to understand this.
This is a comprehensive forum thread regarding digitizers that work with Penenabled Tablet PCs: http://forum.tabletpcreview.com/showthread.php?t=12695
I don't believe Bamboo pens work.
Dec 26, 2008 | Toshiba Portege M200 Tablet PC
Pen pressure and scale problems
I also use Intuos 3 tablet, did you already try replacing the tip and reconfiguring the pen to the screen? You can find this in the driver software, it synchronizes the pen and tablet.
If you already tried that, does the problem only occur in Photoshop? Also, check your brush preferences, you can go back to your default settings and see. If talking to Wacom fails, you might have a bad pen or tablet.
Jul 07, 2008 | Wacom Intuos3 4x5
Computers & Internet Logo
43 people viewed this question
Top Wacom Computers & Internet Experts
toddmat
Level 1 Expert
jasbo
jasbo
Ed Mac
Are you a Wacom Computer and Internet Expert? Answer questions, earn points and help others
