Question about iLive Bluetooth Speaker System
ISB23B need help figuring out how to sync with my computer and get the sound to come through my wireless speakers
Can't sync my JBL SB400 subwoofer to the soundbar??....it flashes blue and goes back to orange. Sound bar works but can't pair sub!..HELP!!
PAIRING THE JBL SB400 FOR WIRELESS OPERATION
After turning the soundbar and subwoofer on for the first time, you will need to "pair" the subwoofer and soundbar so they both operate at the same wireless frequency. To pair the units, press the Wireless Pairing switches on both units within 30 seconds of each other. The units will communicate with each other and operate at the same frequency.
May 21, 2015 | JBL Audio Players & Recorders
The bose is paired to my computer. I can control the music on the computer through the Bose, so I know it's paired. However, Im not getting sound through the bose system.
You need to make sure your computer is using the correct audio device output, this should help:
http://www.7tutorials.com/how-change-default-playback-recording-audio-device
Jan 20, 2015 | Bose SoundLink Wireless Mobile Speaker
IM NOT GETTING SOUND THROUGH MY OUTDOOR SPEAKERS,
Are they wireless? If so you need to sync them to the broadcast unit.
Feb 05, 2012 | Audio Players & Recorders
HOW TO ENABLE BLUETOOTH IN THIS NOTEPAD ?
The Acer Aspire is a high-performance laptop that includes a fast processor, widescreen display and an internal wireless card. In addition to these premium features, certain models also include one-touch Bluetooth access. If you have an Acer, enabling the Bluetooth is very easy and will only take a few seconds.
1.Turn on your computer and wait for Windows to fully boot. Then log in as an administrator. You will not be able to use Bluetooth under a non-administrator account.
2.Press the button with the Bluetooth symbol on the left side of the computer. This will launch the Bluetooth utility. From here you can sync and manage Bluetooth peripherals.
3.Press the Bluetooth button again to disable Bluetooth. This will disable all connections, but the utility will save your settings so the same devices will sync with the computer again when Bluetooth is re-enabled.
I hope you may find it very helpful.
Aug 25, 2011 | Acer Aspire One PC Notebook
Speakers won't produce sound. All the computer settings are activated. everything is at full sound. Can't figure out why it will not pick up sound. Even the sound settings are configured correctly.
if your computer came with a motherboard disk the sound drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control
panel,administrive tools,computer management,device manager,sound video and game controllers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 04, 2010 | Yamaha YST-M7 Computer Speakers
I recently needed to reboot my computer back to factory setting due to what I figure was a virus now my speakers won't work. I have speakers labeled Logitech X-530 do I need a disk to add this as new...
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Nov 07, 2010 | Logitech X-530 Computer Speakers
Got a new computer and now sounds only come out of the computer speakers...can't figure out how to get sound back through my Bose speakers?
there are a number of things that could be the problem
hope this helps
Oct 24, 2010 | Bose Companion 5 Multimedia Speaker System...
Need info to sync my intec wireless nunchuk
send an email to
customerservice@inteclink.com
requesting a manual or guide for the wireless nunchuk and they should send you one immediately.
Don't forget to include your mailing address.
Mar 31, 2009 | Video Game Consoles & Games
3 speakers working, 3 not!
CHECK THE CONTROL PANAL CHECK THE FOLLOWING FOLDERS
DEVICE MANAGER
NETWORKING AND SHARING
SOUND
WINDOWS FIREWALL & WINDOWS DEFENDER
SYNC CENTER IF THEY ARE PLUG AND PLAY DEVICES
ROD
Feb 12, 2009 | Logitech X-530 Computer Speakers
No sound from built-in speakers
You should reinstall the audio driver. Go to this link. Copy and paste this link on your address bar.
http://www.jlaforums.com/viewtopic.php?t=4613077&start=0&postdays=0&postorder=asc&highlight=
*I hope this helps you.
Jan 07, 2009 | Toshiba Satellite A105 Notebook
iLive Bluetooth Speaker System Logo
64 people viewed this question
Top iLive Audio Players & Recorders Experts
cwradio73
Andrew Taylor
Andrew Taylor
Are you an iLive Audio Player and Recorder Expert? Answer questions, earn points and help others
