Question about Watches
Things remembered danbury clock - Watches
Nisshin Elgin design Anniversary Clock repair Manual
No such thing exists. Take it to your local jeweler or a clock repairer.
There is a video in the links. The sites that say they have manuals don't and a very suspect.
Nisshin Elgin design Anniversary Clock repair Manual Google Search
Oct 16, 2017 | Elgin Watches
Danbury clock 'things remembered'. How do I access the battery? I cannot figure out how to find the battery. The battery is dead after two years and I need to replace it. It is not obvious how to...
The things remembered clock is just tension fit in the housing. Easiest way to get it out is to get a plastic suction cup. Press the suction cup onto the face of the clock and pull and jiggle till the clock comes out. This way you wont gouge up the wood trying to pry the clock out with a screwdriver. It takes an N cell battery: https://en.wikipedia.org/wiki/N_battery
Jan 31, 2014 | Watches
The clock is just tension fit in the housing. Easiest way to get it out is to get a plastic suction cup. Press the suction cup onto the face of the clock and pull and jiggle till the clock comes out. This way you wont gouge up the wood trying to pry the clock out with a screwdriver. It takes an N cell battery: https://en.wikipedia.org/wiki/N_battery
Danbury book clock, how do you take clock out to put in battery?
Oct 20, 2013 | Watches
How to you change the battery in a danbury book clock
The clock is just tension fit in the housing. Easiest way to get it out is to get a plastic suction cup. Press the suction cup onto the face of the clock and pull and jiggle till the clock comes free. This way you wont gouge up the wood trying to pry the clock out with a screwdriver. It takes an N cell battery: https://en.wikipedia.org/wiki/N_battery
Jul 30, 2013 | Watches
How do I set a Danbury pocket watch with date display
If it is this pocket watch, then the crown (the bit you turn to wind the watch) has 3 positions. Position 1 is when the crown is pushed in all the way. Position 3 is when the crown is pulled out as far as it will go. In between position 1 and position 3 is a place where the crown will stop, this is position 2.
To set the day of the week, pull the crown out to position 3 to set the time. When you set the time, the bottom dial with also turn to set the hour on the 24 hour clock, if you turn the crown enough to cycle through a whole day the day of the week dial will also turn. Keep turning the crown until the time is set on the proper day of the week.
To set the date, pull the crown out to position 2, and turn it clockwise until the hand on the date dial points to the correct date.
Hope this helps!
Sep 01, 2012 | Watches
Minute hand on Braun AB1A has curved up stopping second hand
The whole front square face of the clock has 4 little nails which are located in the middle of each side (inside and next to the edge of the joint), so you have to carefully insert a screwdriver and lever the front out. After this you have to remove the hands (remember to set the clock and alarm hand to 12:00 before taking those away). The face will be loose, and you'll have access to the mechanism. Clean the alarm contact (look for a double silver metal arm that touches an small bronze stick. Alarm button can be release by gently lever the little nail that shows in the center when button is up at clock's backside.
Cheers from Argentina
Jul 04, 2012 | Braun Ab1a Alarm Clock - Black By Rams &...
How do you control how fast or slow a grandfather clock runs ? Does lowering the pendelum disc make it faster or slower ? Thank you !!!
The longer the pendulum the slower it will swing, so lowering it will slow the clock down.
Feb 10, 2011 | Watches
The glass front of my beatles clock broke.
you just go to a clock store and look for the same thing and just buy it.
Mar 08, 2010 | Seiko Clocks Melodies In Motion QXM135BRH...
Lost my Breitling Jupiter Pilot Bezel whilst drunk over Christmas
Unfortunately Breitling do not supply any parts to private owners, but you can try. Here is the contact details:
Breitling Usa Inc. (US Distributor)
Hangar 7
206 Danbury Road
Wilton, CT 06897
sales@breitlingusa.com
Toll-Free: 1(800)641-7343
Telephone: 1(203)762-1180
Facsimile: 1(203)762-1178
The other way is to try to find it on Ebay.
Leave rating, please.
Jan 05, 2009 | Breitling Watches
Watches Logo
15 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
