Question about Sharp AR-M257 Black and White Copier
How do i fix a misfeed on a sharp ar-m257 - Sharp AR-M257 Black and White Copier
  • 163 Answers
SOURCE: Misfeeds
DEAR SIR WHERE YOU REMPVE THE PAPER IN THE MACHINE THAT SECTION THERE IS PAPER PATH SENSOR ,THAT SENSOR POSITION IS ABNORMAL PLEAZ CHECK THE SENSOR OF THAT SECTION WHERE YOU REMOVED THE PAPER
Posted on Sep 16, 2007
  • 990 Answers
SOURCE: misfeed trouble with sharp ar-337
Dear sir;I suggest you go to simulation mode 30 & 40 to find out which sensor got problem procedure as follow;
1, press "program", "interupt" "clear", "interupt"
2, enter 30, press "start", enter 01, pres start again,then all the sensor light in the paper path are on the abnormal one blinking.
3, repeat same step for 30 sub 02 that's for paper path in the feed section.
4, repeat same step for simulation 40 sub code 01,that's for by-pass paper path sensor.
After you done those procedure you will find out which sensor block out or defect, good luck.
HAVE A HAPPY HOLIDAY !!!
Posted on Dec 20, 2008
007tech
  • 95 Answers
SOURCE: AR-M257 service code L1-00
L1-00 is determined as "scanner feed trouble". The scanner unit (which holds the mirrors) is not moving as it should be. There are a few possibilities. Firstly, does the mirror unit move when the copier is turned on? if not it could be a disconnected/broken scanner wire or bad drive motor or simply dirt/debris or a loose wire binding the unit up.
If the unit moves on power up then it could be a bad sensor or a bad board not registering the signal from the sensor.
You can check the operation of these items in SIM mode : press the following keys one after the other "P" "*" "C" "*" then press 1 and enter/copy button and you'll see the option available.
I hope that helps.
Posted on Mar 31, 2009
  • 143 Answers
SOURCE: i have a sharp ar-m257 has a service code H4-20.
Your main heater lamp has gone bad.
Posted on Aug 01, 2009
  • 118 Answers
SOURCE: How do I get to the black toner reading on a Sharp AR-M257 copier
Hold down the Copy button and you should see a readout for the total copies printed from the copier and the percentage of toner left in the unit.
Posted on Aug 28, 2009
Previous admin no longer here, no one knows web password for AR-M257. How to reset?
Maybe order the service manual
http://www.servicemanuals.net/ServiceManual/SHARP/ARM237/572062/detail.aspx
Jan 09, 2015 | Sharp Ar-M257
How to fix error codes h4-00 on a sharp ar m257
This is a low fuser temperature error.
You should be able to reset it by doing the following at the panel.
Hit Pound, star, C, Star
enter 14, then touch start
execute on the screen
the machine will reboot and the code should go away.
if the problem persists you may need some maintenance.
If you're in Houston we'd be happy to help you out.
Skelton Business Equipment Houston Copiers
Jul 30, 2014 | Sharp AR-M257 Black and White Copier
Sharp AR-M257 clearing user names in scan feature
Please log in machine with you browser with machine ip address
and user name and password is admin and Sharp and go to address book and remove anything you do not want.
Dec 04, 2013 | Sharp AR-M257 Black and White Copier
Code #H4-01 is displayed on the screen of my Sharp AR-M257. What does this code mean and how do I fix the problem?
Your fuser is not warming up. Try clearing with Sim code 14. If the problem comes back, one of your 2 fuser lamps is broken or your thermistor is covered with toner.
Oct 31, 2013 | Sharp AR-M257 Black and White Copier
What is the default username/password on a Sharp AR-M257 copier?
The default username/password is
admin ( all lower case)
Sharp ( capitol S, the rest lower case).
Hope this helps.
Jan 05, 2011 | Sharp AR-M257 Black and White Copier
I have a sharp ar-m257 copier. my copies were
There are a few thing's > have you cleaned the optic's > clean the primary charge unit in the drum unit > how old is the drum & developer? Also, is the copier calling for for "Maint's Req"
Apr 05, 2010 | Sharp AR-M257 Black and White Copier
Sharp AR-M257 Black and White Copier Logo
37 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
