Question about Saws
Hello I have a black & decker circular saw amp 11 that ime trying to put back together but it won't fall back n to place so I was wondering how it would fall back n to place ...
rowdy45176
  • 2176 Answers
SOURCE: I can't tighten the blade on the saw.
are both flanges in place and on correctly?? That would be the first thing that I would look for.
Posted on Dec 30, 2009
al_kupchella
  • 843 Answers
SOURCE: How can I change the circular saw in my Back &
Unplug it and loosen the bolt in the middle of the blade. It's a standard thread, so turn it lefty-loosey. But you need to hold the blade from turning. That's easy by putting a screwdriver in front of a blade tooth, under the sole plate. Let the sole plate prevent the screwdriver from rising up with the blade as you turn the bolt. If your current blade has small teeth (like a plywood blade) then you can raise the sole plate as for a maximum depth of cut, then push the saw against the front edge of a workbench (or block of wood somehow held still) as if you were going to cut it. Before you remove the bolt, take note of the exact orientation of the washer (or washers)so you can replace them the same way.
Posted on Jun 18, 2010
Testimonial: "Thank you very much; more or less what husband had tried to do, but none the less he's going to try again, according to your instructions. Will let you know the result later. J"
seddy29732
  • 147 Answers
SOURCE: I have a black &
Sounds like the axle is stripped out. Does the motor keep running or does it stop also? you may want to strip it down and see if there is a flat spot on the axle that may be rounded off or if there is a setscrew missing.
Posted on Apr 29, 2011
  • 454 Answers
SOURCE: How do i lock
Almost all circular saws have a button or lever you push in to lock the motor shaft. You will have to hold that button or lever in while you turn the shaft, there will be one certain spot where it will lock.
Posted on May 25, 2011
rowdy45176
  • 2176 Answers
SOURCE: how do I replace the
first find out what wire guage it is and then remove the handle half, making note of where the wires go, you might want to take a picture for ease of reassembly and then remove the old one and replace it making sure not to pinch the wiring.
Posted on Aug 04, 2011
My black a nd decker circular saw just stopped functioning midway inuse
It is hard to say at this distance what is wrong. If it is oldish, the motor brushes may be worn down. It could be that a wire has come loose from a terminal in it, or a contact has broken in the on/off switch assembly. All those things have happened to me at one time or another.
Jan 18, 2015 | BLACK and DECKER POWER TOOLS Black And...
Need parts for Black and Decker circular saw model 7390
Go to
http://www.ereplacementparts.com/black-and-decker-7390-type-circular-saw-parts-c-4167_4252_12157.html
Jan 24, 2013 | BLACK and DECKER POWER TOOLS Black And...
I need a switch for my black & decker 7 1/4 worm drive saw model 7395 type 1
That tool was discontinued in 1980 and parts are obsolete. You may be able to use a Skil 77 worm drive switch as many of the circular saw switches were configured the same. The switches are usually marked with a 1 and 2 on the back so make sure the wires are put on correctly as some will have the 1 on one side (top and bottom terminals) while others are on the top or bottom (next to each other).
Aug 05, 2012 | Black & Decker 7 - 1/4" Heavy Duty...
Looking for replacement blades for Black & Decker Zip Saw
Its on ebay http://www.ebay.com/itm/NEW-BLACK-DECKER-ZIP-SAW-11-PIECE-CUTTING-SET-74-691-/260888941452
only 15.00
Apr 02, 2012 | Saws
Manual for black and decker circular saws #7301 type A
Okay im restoreing an old Black&Decker circular saw 7 1/4 volt 120ac Amps 9.0 Type A Rpm 4900 now im putting it back togather and i need help Ive got evrything else down patt just what the saw blade sets on there's like a lil motor that is togather where the blade goes and has teeth all around it and connects to the big motor it has a pin there ive found that just when i put it all togather there's a gap there and dont know why ive took my time and went from one screw to next easy and still does the same thing i thought maybe something was in the way where the two plates screw down but there is nothing in the way any idea's help me please
Jan 12, 2012 | Black & Decker Saws
I have a black and decker CS1000. How do you tighten or loosen blade. There is no spindle lock that I can find.
If you can't find a spindle lock you can unplug the tool and find a piece of wood and put the blade against it and loosen and also tighten the blade, but most newer saws have a spindle lock located in the gear housing somewhere.
Sep 18, 2011 | Black & Decker CS1012 7-1/4" 12 Amp...
I am trying to install a blade on a circular 18 vold cordless circular saw and cannot remove the bolt that holds the blade in place. Is there a way to lock it down.
some saws have a button to hold down that will lock the blade in place. if yours doesnt have the button, try putting a screwdriver in one of the cutouts or on the blade tip itslef and lock it in position. your problem may be that the screw on the saw is actually reverse threaded. they usually are reverse threaded.
Dec 24, 2010 | Black & Decker Saws
Bought my black and decker circular saw in july 2009 stopped working and still has warranty Ace hardware where I puchased the saw will not exchange saw says I need to send it to the company but, I didn't...
you would need to send it to a Dewalt service center or any authorized Dewalt service center for warranty repair, The exchange period is usually 30 days. If you need to give me your city, state and zip and I will try and find one close to you.
Oct 28, 2009 | Black & Decker CS1012 7-1/4" 12 Amp...
Saws Logo
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
