Question about Echo Pb - 413t Backpack Blower
My echo leaf blower will not start. How do I check to see if it is getting spark
    Problem Solver:
  • 15 Answers
Pull the plug out, connect it to the wire and lay the plug against the metal engine. Pull the starter cord and watch for spark at the plug.
Posted on Sep 22, 2014
localwonder
  • 6784 Answers
SOURCE: oil gas mixture of model pb-2100 echo leaf blower
GAS-- Use 89 octane r+m over 2 (mid grade or higher) This gasoline known to be good quality. Gasoline may contain up 10 15% MTBE (methyltertiary-butyl ether). Gasohol containig methyl alcohol is not approved.
TWO STROKE OIL-- 50: 1 is usable.
please rate and god bless.
Posted on Mar 27, 2009
  • 267 Answers
SOURCE: echo pb 200 leaf blower want start
Turn on ignition switch, Choke, prime bulb 5 times (or until fuel flows), hold throttle down and pull starter cord sharply until it tries to start, then place choke in mid position pull cord sharply again until it runs then move choke to off when it will allow it.
Also you can go to toro.com then customer care, then manuals and parts then type in model no. and download an owners manual.
Posted on Apr 06, 2009
SOURCE: Need to replace fuel filter
Fuel filter is located inside the fuel tank. You have to make a hook out of about 10" of stiff wire (wire coat hanger works perfect) Hook end should be about 1/2" wide. Remove the fuel cap, insert the wire hook and snag the fuel supply tube with the filter attached to the end. Pull it back through the fuel filler opening, replace the filter and reinsert.
Posted on Apr 15, 2009
  • 148 Answers
SOURCE: Echo leaf blower is bogging down at full throttle,
Have you tried cleaning the carb?
Posted on Aug 24, 2009
Testimonial: "Thanks for the suggestion, that sounds like what it may be. "
97F350diesel
  • 1326 Answers
SOURCE: I have a Echo PB 2601 made a loud bang then stoped working.
Sounds like it has seized up. If the pull cord won't pull then the motor is locked up. Did you run gas/oil mix for the fuel its a 2 cycle motor...
Posted on Sep 25, 2009
Not getting any spark on my echo leaf blower pb 251. any suggestions
wire to the stop switch broken or grounded out
faulty coil
coils seldom fail so check out all the wires to and from the switch
Aug 19, 2016 | Echo Garden
How do i check spark on my echo leaf blower
You can take a spark plug tester and plug one end into the spark plug wire and the place the other end on the spark plug and pull the starter rope and see if there is a spark present. Hope this helps.
May 15, 2014 | Echo Pb-2100 Pb 2100 Leaf Blower Fuel Gas...
Echo blower wont start
ignition coil fixed my still backpack last fall
Apr 02, 2013 | Echo Pb265l 25.4cc Gas Powered 158 Mph Low...
My echo pb265l doesn't start
first check for spark when it first dies then see if its getting fuel start there
Apr 18, 2012 | Garden
Echo leaf blower..cranks fine, idles fine, will not throttle up.
Sounds like restricted exaust. Remove the muffler and start it, see if that fixes it. If yes clean remaining carbon from exaust port. And clean spark arestor screen.
Nov 03, 2010 | Echo Gas Blower 135 MPH390 CFM Blower...
My echo pb-2100 gas blower has no spark and wont start whats anyone has an idea whats the problem
no spark sounds like the coil, but check the connections and any corrossion in the wires
Oct 13, 2010 | ECHO, Inc. PB-251C Handheld Blower
It wont start.
You might want to make sure that you have enough 'sparks' at the plug tips. And also make sure your
magneto is clean, and dry.
Nov 19, 2009 | Echo Pb - 413t Backpack Blower
Motor not accelerate past idle, bogs down...
yes,check your spark arrestor screen in the muffler
Apr 22, 2009 | ECHO, Inc. Shred n Vac
Echo Pb - 413t Backpack Blower Logo
280 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
