Question about John Deere Toys
Where do i find the grease fitting on my 2014 john deere 410 extended hoe
4 Suggested Answers
  • 4 Answers
SOURCE: I tried to put grease in the front to loosing up
its not worth the trouble of taking your steering apart to grease it.grease would effect how well your machine turns.
Posted on Aug 30, 2009
emissionwiz
  • 77202 Answers
SOURCE: How do I change the track tension seal in a John Deere Dozer 450 series?
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
This is for car and truck problems.
Posted on Sep 19, 2012
  • 3519 Answers
SOURCE: What type of fuel does a John Deere 410 Backhoe take diesal or gasoline?
Probably diesel.
Look at the engine.
If there are spark plugs it takes gas.
Posted on Jun 20, 2015
My John Deere x320 forward pedal sticks
I have ran into this before. It's time consuming to fix. You have to pull the body of the mower loose and take the pedal completely apart. Clean it and grease it then put it back on, it will work fine then. They need to put grease fittings on those pedals.
Nov 28, 2016 | John Deere Garden
Where is the serial number located on a john deere 510d backhoe..so i can find out the year of the backhoe
Diane, JD 510D VIN# Location: On older models plate is attached on outside of frame behind either left or right front wheel. On newer models VIN plate is attached just above left (Highway) side cylinder arm. Same location as Caterpillar. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://cppsocal.org/wp-content/uploads/2014/04/Heavy_Equipment_Catalog_Vol_5.pdf
https://www.oswca.org/uploads/combatting-heavy-equipment-theft-2015.pdf
Thread where is Serial number for 1977 John Deere 510 hoe
Serial number plate location for john deere 510d backhoe Google Search
Jun 20, 2016 | John Deere Garden
How to change a pulley on a John Deere 48 c mower deck
You must remove the deck from under the mower by removing all clips and connectors to the main mower under body. There are 3 small bolts attaching each pully wheel to the deck body. If you are lucky the bolts will remove correctly. I recommend that you use a liquid wrench product on the bolts. The new pully should have grease fittings which the factory units do not. Also the bolts cut in to the metal holes if removed bolts came out cleanly. You may have to drill out the broken bolts then screw in the new ones. Make sure you grease the new pulleys. I replaced all three rather than wait. The original ones did not have grease fittings and they will wear in two..
Oct 12, 2014 | John Deere Garden
John deere belt routing
hoe's dont replace belts... they take them off !!!
Aug 21, 2014 | John Deere Garden
Do the gy21098 spindles for my La145 lawn mower deck come pre greased or do I need to add grease after installing
When changing spindles I always add at least 7 or 8 pumps of grease from the grease gun. Usually John Deere does not ship anything with grease. Daniel.
Sep 10, 2011 | John Deere 22HP VTwin 48" Riding Mower
I bought 135A used without the owners manual. He told me I need to greese it, maybe each time I use it. Please help me get a free owner's manual so I don't ruin this machine. I paid 950$ for it.
The only thing that would probably need greasing are the spindles on the front wheels. There should be grease (zerk) fittings on the outside of the wheel axles inside the wheel itself. Not greasing them won't kill your mower. Of course, the manual has ALL the lubrication points listed in a chart in it.
John Deere makes it a little challenging to get a manual, but you have the specs and here is the link. I think you can order a paper version , but this link is to download an electronic version for free. The printed version will cost you.
http://www.deere.com/en_US/ProductCatalog/HO/servlet/servlet/com.deere.u90785.cce.productcatalog.view.servlets.PublicationsSearchServlet?tM=HO
Jun 14, 2011 | John Deere 22HP Hydrostatic 42" Riding...
Parking brake wont release on a 310e back hoe, replaced the parking brake switch and that was no help
Sounds like the whole stop brake system is seized up. Lot of wd40 and elbow grease should do it.Good luck.
Mar 25, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Toys Logo
16 people viewed this question
Top John Deere Toys Experts
Jim Goldsmith
Jim Goldsmith
J.D. Browning
J.D. Browning
Wayne Fellows
Wayne Fellows
Are you a John Deere Toy Expert? Answer questions, earn points and help others
