Samsung wa456 bad lid switch - Washing Machines
My Samsung washer model wa456 will not spin all the way out with even just a few clothes in it and shakes really had, what do I do?
Washers have a switch which disengages the motor if the load is unbalanced. An unbalanced load will cause the drum to spin irradically and bangs against its bumpers Either you are not loading it correctly or one or more of the flexible supports that keep the drum centered, are broken or disconnected.
Feb 15, 2017 | Samsung Washing Machines
I have a Samsung WA13G7Q1 top loader giving me a DE on LCD when spin cycle starts then just stops.
DE is an error relating to the lid switch/lock not working, if it cant sense the lids shut it wont spin, it could be as simple as the magnet in the lid has moved or the more likely cause is the lid switch has died, it will require further inspection or you could just order the lid switch and see how it goes
Jan 28, 2017 | Samsung Washing Machines
WA456. Why is it constantly becoming unbalanced?
Is it set up level on its feet? Can you slide a piece of rubber under each foot?
Jul 17, 2015 | Samsung Washing Machines
Samsung top load gets to final spin and bangs around like crazy, then it will stop, refill, drain, and start that process all over again. I've leveled it over and over, but that doesn't seem to help.
Washing machines have springs to keep the tub centered. If one or more of those springs has come off or has broken, you'd get exactly those symptoms.
Jun 08, 2015 | Washing Machines
While the machine was spinning i opened the lid and shoved another article in and now the machine doesnt spin anymore? my machine is a Samsung WA13G7Q1
There is a switch under the rim which the lid actuates -- when the lid is up the switch is opened to prevent the machine from spinning -- there is a "post" on the lid which pushes this switch when the lid closes -- sounds like this lid switch is malfunctioning -- perhaps loose, or broken, or maybe burned contacts -- more info, let me know.
Charlie
Jan 29, 2011 | Samsung Washing Machines
Samsung P801 will fill up with water but not go into wash cycle. Took motor out and it bench tested fine. What's next?
ther is a chance that either the timer control board or door lock switch has gone bad .i would first check the door lock or lid switch
Sep 27, 2009 | Samsung Washing Machines
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
